  • 2822阅读
  • 2回复
[鑫创]主控TC58NC6688/SSS6690-B0求解决。 [复制链接]
离线liucanan
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-03-26
失败报告:
Device 1:0xB0
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D5-94-32-76-54-0B-00
CE-1, Flash ID=98-D5-94-32-76-54-0B-00
Found BACKUP Table (000001BB-0003)
Found BACKUP Table (000002BB-0005)
  Original Bad Block - 0:0x0001
  Original Bad Block - 0:0x0002
  Original Bad Block - 0:0x0004
  Original Bad Block - 0:0x031C
  Original Bad Block - 0:0x0343
  Original Bad Block - 0:0x0413
  Original Bad Block - 0:0x051D
  Original Bad Block - 0:0x054C
  Original Bad Block - 0:0x063B
  Original Bad Block - 0:0x07CD
  Original Bad Block - 0:0x07E7
  Original Bad Block - 1:0x0000
  Original Bad Block - 1:0x002D
  Original Bad Block - 1:0x01C6
  Original Bad Block - 1:0x03C4
  Original Bad Block - 1:0x04E7
  Original Bad Block - 1:0x079B
Defect Table shows 4151 Good blocks, 17 Bad blocks
SafeErase (0,2084)
  Erase failed Block - 0:0:0x0001
  Erase failed Block - 0:0:0x0002
  Erase failed Block - 0:0:0x0004
  Erase failed Block - 0:0:0x031C
  Erase failed Block - 0:0:0x0343
  Erase failed Block - 0:0:0x0413
  Erase failed Block - 0:0:0x051D
  Erase failed Block - 0:0:0x054C
  Erase failed Block - 0:0:0x063B
  Erase failed Block - 0:0:0x07CD
  Erase failed Block - 0:0:0x07E7
  ---> Max Bad of Plane (4,7)
SafeErase (1,2084)
  Erase failed Block - 1:0:0x0000
  Erase failed Block - 1:0:0x002D
  Erase failed Block - 1:0:0x01C6
  Erase failed Block - 1:0:0x03C4
  Erase failed Block - 1:0:0x04E7
  Erase failed Block - 1:0:0x079B
  ---> Max Bad of Plane (3,3)
  ---> Max BAD/DIE = 7
Total good blocks after SCAN: 4151 / 4168, Bad block=17
==> 2-Plane mode
Max. Bad Block Allowed = 252(17)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 7 (63),4168,1,2
RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x0003,0x0005
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
--- Download ISP Code:D:\1\ISP_CODE\6690_B1-A_20090602_V151A_D6FA.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
SN=0012F01DBD30F631A5DF14E3
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0003:79.
Total=0,CDROM=0, PublicArea=-128, SecureArea=0
Create SECURE(CDROM=0,Public=2097151 MB,Secure=0 MB)
DOS check fail- LBA(0x00000000): 0000=FA,00
### Err: SECURE failed(40).
哪位大神能解决!
离线liucanan
只看该作者 1楼 发表于: 2016-04-02
离线zwent
只看该作者 2楼 发表于: 2016-06-12
