  • 23569阅读
  • 19回复
[ARM]技术贴:GD32F103   vs   STM32   性能测试比较 [复制链接]
离线huaweiwx
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-03-29
为了做GD32F103 和 STM32   性能比较,做了块makerlab sun arduino兼容板子,芯片为stm32f103vct6:
并在arduino同一core代码下编译进行三个方面的比较
1  读10000次端口,放入一个unit16_t 数组内;
2  1 到 10000累加;
3 10000次翻转led灯(尽管我们肉眼看不到,但示波或逻辑分析仪可以抓到;
代码如下:
  1. #include <GpioDirector.h>
  2. //GD32 test huaweiwx@sina.com
  3. // the setup function runs once when you press reset or power the board
  4. #define LED  LED_BUILTIN  //LED_BUILTIN: PC13
  5. //#define LED 13 //vct6 sun !!目标板子上的具体led 位置!!
  6. #define BUFFERSIZE 10000
  7. uint16_t buffer[BUFFERSIZE + 1];
  8. void setup() {
  9.   // initialize digital pc13 as an output.
  10.   pinMode(LED, OUTPUT);
  11. //  Serial.begin(9600);//
  12.   digitalWrite(LED, LOW);  // toggle the LED
  13. }
  14. // the loop function runs over and over again forever
  15. void loop() {
  16. //取得led 端口地址
  17.   gpio_dev *dev  = PIN_MAP[LED].gpio_device;
  18.   uint8 pin = PIN_MAP[LED].gpio_bit;
  19. //volatile 防止优化,强制每次重新读取变量;
  20.   volatile  uint32_t start, e, r;
  21.
  22.   uint32_t i;
  23.   digitalWrite(LED, LOW);  // toggle the LED
  24.   delay(500);
  25.   //read port
  26.   start = micros();
  27.   for (i =  BUFFERSIZE; i != 0; i--) {
  28.     buffer[i] = PINA;
  29.   };
  30.   e = micros() - start;
  31.   //stm32f103vct6  72M  ram 2500 flash 3058
  32.   //gd32f103ret6   72M  ram 2927 flash 1946
  33.   //gd32f103ret6  120M  ram 1754 flash 1168
  34.   Serial.print("read port Tus=");
  35.   Serial.println(e, DEC);
  36.   //add
  37.   r = 0;
  38.   start = micros();
  39.   for (uint32_t j =  10000; j != 0; j--) {
  40.     r = r + j;
  41.   };
  42.   e = micros() - start;
  43.   //stm32f103vct6  72M  ram 1112 flash 1251
  44.   //gd32f103ret6   72M  ram 2927 flash 1113
  45.   //gd32f103ret6 120M  ram 1754 flash 667
  46.   Serial.print("add Tus=");
  47.   Serial.println(e, DEC);
  48.   //toggle
  49.   start = micros();
  50.   for (uint32_t j =  10000; j != 0; j--) {
  51.     dev->regs->ODR ^= (1U << pin);
  52.   };
  53.   e = micros() - start;
  54.   //stm32f103vct6  72M  ram 2224 flash 1669
  55.   //gd32f103ret6   72M  ram 2927 flash 1113
  56.   //gd32f103ret6  120M  ram 1754 flash 667
  57.   Serial.print("Toggle led Tus=");
  58.   Serial.println(e, DEC);
  59.   digitalWrite(LED, HIGH);  // toggle the LED
  60.   delay(500);
  61. }
分别在ram内跑和在flash内跑,结果如下:
1 读端口10000次(直接读端口地址寄存器):
  stm32f103vct6  72M  ram 2500us   flash 3058us
   gd32f103ret6    72M   ram  2927us  flash 1946us
   gd32f103ret6   120M  ram 1754us   flash 1168us
  stm在ram内跑 要比在flash内跑快
GD 在ram内跑要比在flash内跑慢,这也是以前多次验证的结果;
但GD在flash内的速度比stm 在ram中跑的速度还有快,宣传上所说0等待不是吹的;
GD还可以超频,在120M主频运行条件下快stm 接近300% ;这一比较,GD胜;
2 内存变量运算10000次加法(结果设置为 volatile 防止优化,取得真实运算次数):
   stm32f103vct6  72M  ram 1112us  flash 1251us
   gd32f103ret6   72M  ram 2927us  flash 1113us
   gd32f103ret6  120M  ram 1754us flash 667us
由于两个变量都在ram内,所以同频率在ram跑的速度正好和上述结果相反,stm 快 gd 接近 300%
当然超频120M在flash内跑弥补了这一缺陷;运算方面,不考虑超频,STM胜出
3 翻转led 10000次(寄存器直接操作)
  这方面 在ram跑和在flash跑,各有千秋,stm gd 持平;
4 综合:
  stm32 ram块,因此涉及大量变量运行,显然要快于GD;
   GD flahs操作特快,因此对于运算量小但代码量大的显然占了优势;
   但GD32F103可以超频到120M,这样基本从性能上可以超出stm32F103;
结论: 1上述测速程序无论在ram上跑还是在flash上跑,只有stm完全可以;而在gd上, 发现在ram跑,代码写地址不能超过 0x20005000,即20k(含代码和需要初始化的变量);因此上述程序在gd的ram上跑,我是分段编译下载到gd上的测试的,而stm上可以一次测完;
       2 在GD ram内跑,串口仍然halt(死机),而stm 则没有问题,网上也有这个反映,不知是否是gd的一个从ram 取指的bug?所以程序输出是usb转串口;
       3 有资料介绍,gd的ram是挂在外部总线上映射到内部地址0x20000000,所以慢了。能做好flash的,不一定能做好ram;
       4 当然 GD的adc实在不怎么的。这是众所周知的,输入内阻那么低,要测电压,除非是测低内阻的电源,否则需加运放跟随;
       5 我们玩玩,gd还是有性价比高的,做产品,那就要正对这些分析了。
本帖最近打赏记录:共14条打赏 ,M币+44
12
离线wang_00008
只看该作者 1楼 发表于: 2016-03-29
本帖最近打赏记录:共1条打赏 ,M币+3
离线蓝_猫
只看该作者 2楼 发表于: 2016-03-29
离线zylmp
只看该作者 3楼 发表于: 2016-03-29
离线thinkabout44
只看该作者 4楼 发表于: 2016-03-29
离线rzlx
只看该作者 5楼 发表于: 2016-03-29
离线hongo
只看该作者 6楼 发表于: 2016-03-29
离线xktx09
只看该作者 7楼 发表于: 2016-03-29
离线benli
只看该作者 8楼 发表于: 2016-03-29
离线kinneng
只看该作者 9楼 发表于: 2016-03-29
