  • 6719阅读
  • 26回复
[SandForce]用JS29F16B08JCNE1开不过,是什么原因。高手指教 [复制链接]
离线75106zxs
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-04-04
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Sun, 04/03/2016 @ 23:58:58
                  End Time: Mon, 04/04/2016 @ 00:00:22
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22824.0.driveconfig
                  argv[5]: Tigo
                  argv[6]: s500
                  argv[7]: 120G
                  argv[8]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Tigo s500_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Tigo s500_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 04/03/2016 23:58:58] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: Tigo
                      argv[6]: s500
                      argv[7]: 120G
[Sun 04/03/2016 23:58:58] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 04/03/2016 23:59:03] - Issuing a discovery command for device: '0:0:0:0'
[Sun 04/03/2016 23:59:08] - Discovery command completed...
[Sun 04/03/2016 23:59:08] - Waiting 5 seconds for the system to settle...
[Sun 04/03/2016 23:59:13] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 04/03/2016 23:59:13] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22824.0.driveconfig
              Serial No. = Tigo
         World Wide Name = s500
[Sun 04/03/2016 23:59:13] - Successfully received the IDENTIFY data from the drive...
[Sun 04/03/2016 23:59:13] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 04/03/2016 23:59:16] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 04/03/2016 23:59:16] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22824.0.driveconfig Loaded successfully
[Sun 04/03/2016 23:59:16] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 04/03/2016 23:59:16] - B01 Power Management configuration request detected
[Sun 04/03/2016 23:59:16] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22824.0.driveconfig
[Sun 04/03/2016 23:59:16] - Extracted Config_ID: 1 (22824) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22824.0.driveconfig
[Sun 04/03/2016 23:59:16] - Extracted SerialOutputControl: 0
[Sun 04/03/2016 23:59:16] - Searching for flashware image for configuration 22824
[Sun 04/03/2016 23:59:16] - Manifest found for configuration 22824
[Sun 04/03/2016 23:59:16] - Flashware image extracted: 22824_fw_cl_slc_Intel_64Gb_PF29F64G16MCNE_2Q_2C_1D_PP_R00800_s512.vic
[Sun 04/03/2016 23:59:16] - Searching for manufacturing image for configuration 22824
[Sun 04/03/2016 23:59:16] - Manufacturing image extracted: 22824_mf_slc_Intel_64Gb_PF29F64G16MCNE_2Q_2C_1D_PP_R00800_s512.vic
[Sun 04/03/2016 23:59:16] - Proceeding in ROM mode, download feature 3...
[Mon 04/04/2016 00:00:22] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  146.457602] ata1.00: failed command: STANDBY IMMEDIATE
[  146.457610] ata1.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[  146.457611]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  146.457616] ata1.00: status: { DRDY ERR }
[  146.457619] ata1.00: error: { ABRT }
[  146.457628] ata1.00: device reported invalid CHS sector 0
[  146.457643] sd 0:0:0:0: [sda] START_STOP FAILED
[  146.457646] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  146.457651] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[  146.457657] sd 0:0:0:0: [sda] Add. Sense: No additional sense information
[  146.457750] ata1.00: disabled
[  151.461426] ata1: hard resetting link
[  151.766031] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  151.767017] ata1.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  151.767022] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  151.772691] ata1.00: configured for UDMA/133
[  151.772699] ata1: EH complete
[  151.772828] scsi 0:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  151.774267] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  151.774271] sd 0:0:0:0: [sda] 4096-byte physical blocks
[  151.774348] sd 0:0:0:0: [sda] Write Protect is off
[  151.774352] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  151.774386] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  151.775674] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  151.776296]  sda: unknown partition table
[  151.785881] sd 0:0:0:0: [sda] Attached SCSI disk
[  170.712028] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  170.712035] ata1.00: failed command: DOWNLOAD MICROCODE
[  170.712043] ata1.00: cmd 92/03:21:00:00:02/00:00:00:00:00/00 tag 0 pio 16896 out
[  170.712045]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[  170.712049] ata1.00: status: { DRDY }
[  170.712057] ata1: hard resetting link
[  176.066026] ata1: link is slow to respond, please be patient (ready=0)
[  180.758027] ata1: COMRESET failed (errno=-16)
[  180.758034] ata1: hard resetting link
[  186.112028] ata1: link is slow to respond, please be patient (ready=0)
[  190.804021] ata1: COMRESET failed (errno=-16)
[  190.804028] ata1: hard resetting link
[  196.158024] ata1: link is slow to respond, please be patient (ready=0)
[  225.840028] ata1: COMRESET failed (errno=-16)
[  225.840037] ata1: limiting SATA link speed to 1.5 Gbps
[  225.840040] ata1: hard resetting link
[  230.888019] ata1: COMRESET failed (errno=-16)
[  230.888026] ata1: reset failed, giving up
[  230.888030] ata1.00: disabled
[  230.888052] ata1: EH complete
[Mon 04/04/2016 00:00:22] - End of Genesis manufacturing log.
[Mon 04/04/2016 00:00:22] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sun, 04/03/2016 @ 23:58:58 </Start_Time>
        <End_Time> Mon, 04/04/2016 @ 00:00:22 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: Tigo
                  argv[6]: s500
                  argv[7]: 120G
        </Input_Parameters>
        <Log_File> /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/Tigo s500_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 04/04/2016 00:00:22] - Overall Result for Device: /dev/sg0 ****** FAIL ******
离线sjzjiawei
只看该作者 1楼 发表于: 2016-04-04
本帖最近打赏记录:共2条打赏M币+8
离线huakun888
只看该作者 2楼 发表于: 2016-04-04
本帖最近打赏记录:共2条打赏M币+6
离线perter
只看该作者 3楼 发表于: 2016-04-04
离线924011476
只看该作者 4楼 发表于: 2016-04-04
离线527945545
只看该作者 5楼 发表于: 2016-04-04
本帖最近打赏记录:共1条打赏M币+3
离线75106zxs
只看该作者 6楼 发表于: 2016-04-04
离线75106zxs
只看该作者 7楼 发表于: 2016-04-04
回 sjzjiawei 的帖子
离线gmc
只看该作者 8楼 发表于: 2016-04-04
离线sjzjiawei
只看该作者 9楼 发表于: 2016-04-04
回 75106zxs 的帖子
