  • 4593阅读
  • 15回复
[SandForce]sf2281 开卡出错Process exited with code 18求助(已解决) [复制链接]
离线llm2323
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-05-07
金士顿2281蓝板 JS29F32B08JCME2开卡至83%出现错误Process exited with code 18
不知是什么原因
Starting command:[/root/soft/SF_Genesis -PROCESS_SSD 4:0:0:0 "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig" 20160507 0  LOG="/root/mpt/log/20160507_llm_DATETIMESTAMP_4.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sat 05/07/2016 20:52:27] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 4:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig
                      argv[5]: 20160507
                      argv[6]: 0
                      argv[7]: LOG=/root/mpt/log/20160507_llm_DATETIMESTAMP_4.0.0.0_PROCESS_SSD_RESULT.log
[Sat 05/07/2016 20:52:27] - Instructing the operating system to purge any existing cached data for device: '4:0:0:0'
[Sat 05/07/2016 20:52:32] - Issuing a discovery command for device: '4:0:0:0'
[Sat 05/07/2016 20:52:38] - Discovery command completed...
[Sat 05/07/2016 20:52:38] - Waiting 5 seconds for the system to settle...
[Sat 05/07/2016 20:52:43] - Device designation string '4:0:0:0' is mapped to node '/dev/sg1'
[Sat 05/07/2016 20:52:43] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig
              Serial No. = 20160507
         World Wide Name = 0
[Sat 05/07/2016 20:52:43] - Successfully received the IDENTIFY data from the drive...
[Sat 05/07/2016 20:52:43] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sat 05/07/2016 20:52:58] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sat 05/07/2016 20:52:58] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig Loaded successfully
[Sat 05/07/2016 20:52:58] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sat 05/07/2016 20:52:58] - B01 Power Management configuration request detected
[Sat 05/07/2016 20:52:58] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig
[Sat 05/07/2016 20:52:58] - Extracted Config_ID: 1 (22675) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/22675.0.driveconfig
[Sat 05/07/2016 20:52:58] - Extracted SerialOutputControl: 0
[Sat 05/07/2016 20:52:58] - Searching for flashware image for configuration 22675
[Sat 05/07/2016 20:52:58] - Manifest found for configuration 22675
[Sat 05/07/2016 20:52:58] - Flashware image extracted: 22675_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_PP_R00428_s512.vic
[Sat 05/07/2016 20:52:58] - Searching for manufacturing image for configuration 22675
[Sat 05/07/2016 20:52:58] - Manufacturing image extracted: 22675_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_PP_R00428_s512.vic
[Sat 05/07/2016 20:52:58] - Proceeding in ROM mode, download feature 3...
[Sat 05/07/2016 20:52:58] - Successfully downloaded MFB to the drive...
[Sat 05/07/2016 20:52:58] - Waiting (5 sec) for the drive to settle...
[Sat 05/07/2016 20:53:03] - Successfully received the IDENTIFY data from the drive...
[Sat 05/07/2016 20:53:03] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Sat 05/07/2016 20:53:03] - Successfully enabled SMART capabilities...
[Sat 05/07/2016 20:53:06] - Successfully issued a diagnostic unlock...
[Sat 05/07/2016 20:53:07] - Performing the flash test of block 0 (0x0000)...
[Sat 05/07/2016 20:53:08] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 2    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 3    | 0    | 3    | 0x0062 | N3,N5,N6                                   | WARNING |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 16
      No. Passed without warnings: 0
[Sat 05/07/2016 20:53:08] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Sat 05/07/2016 20:53:42] - FORMAT command completed...
[Sat 05/07/2016 20:53:42] - Waiting (2 sec) for the drive to settle...
[Sat 05/07/2016 20:53:44] - Setting up the stamp information through CDU command...
[Sat 05/07/2016 20:53:47] - Waiting (2 sec) for the drive to settle...
[Sat 05/07/2016 20:53:49] - Downloading the flashware to the drive... feature 3
[Sat 05/07/2016 20:53:51] - Successfully downloaded flashware to the drive...
[Sat 05/07/2016 20:53:51] - Waiting (15 sec) for the drive to settle...
[Sat 05/07/2016 20:54:06] - Successfully received the IDENTIFY data from the drive...
[Sat 05/07/2016 20:54:06] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '306ABBR0', indicating flashware download has failed.
[Sat 05/07/2016 20:54:06] - End of Genesis manufacturing log.
[Sat 05/07/2016 20:54:06] - Exiting...
[Sat 05/07/2016 20:54:06] - Overall Result for Device: /dev/sg1 ****** FAIL ******
已解决:
在SATSA2中测试
[ 此帖被llm2323在2016-05-08 18:13重新编辑 ]
本帖最近打赏记录:共1条打赏 ,M币+5
离线llm2323
只看该作者 1楼 发表于: 2016-05-07
离线john_chuck
只看该作者 2楼 发表于: 2016-05-07
离线perter
只看该作者 3楼 发表于: 2016-05-07
离线llm2323
只看该作者 4楼 发表于: 2016-05-07
离线perter
只看该作者 5楼 发表于: 2016-05-07
离线k1503
只看该作者 6楼 发表于: 2016-05-07
离线llm2323
只看该作者 7楼 发表于: 2016-05-07
[ 此帖被llm2323在2016-05-07 19:05重新编辑 ]
离线527945545
只看该作者 8楼 发表于: 2016-05-07
离线llm2323
只看该作者 9楼 发表于: 2016-05-07
回 527945545 的帖子
