  • 3397阅读
  • 3回复
[SandForce]OCZ PCB-0135-X01 8*PF412 AL1144 [复制链接]
离线znd
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-05-08
我有类似的问题。
原始 Ocz PCB-0135-X01 03-2011 和 8 * PF412 AL1144。
请看看下面的日志。
同样的情况与22186。
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 04/25/2016 08:03:14] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
                      argv[4]: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22214.0.driveconfig
                      argv[5]: OCZ-AGILITY3
                      argv[6]: 5e83a97e00000000
                      argv[7]: log=/home/root/Desktop/Agility3/60/process
[Mon 04/25/2016 08:03:14] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Mon 04/25/2016 08:03:20] - Issuing a discovery command for device: '1:0:0:0'
[Mon 04/25/2016 08:03:25] - Discovery command completed...
[Mon 04/25/2016 08:03:25] - Waiting 5 seconds for the system to settle...
[Mon 04/25/2016 08:03:30] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Mon 04/25/2016 08:03:30] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
      Configuration File = /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22214.0.driveconfig
              Serial No. = OCZ-AGILITY3
         World Wide Name = 5e83a97e00000000
[Mon 04/25/2016 08:03:30] - Successfully received the IDENTIFY data from the drive...
[Mon 04/25/2016 08:03:30] - Validating Manufacturing Firmware Package: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
[Mon 04/25/2016 08:03:50] - Successfully opened the package: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/FW_PPRO_5_8_2_Release.906190.release.0.mfp
[Mon 04/25/2016 08:03:50] - file  /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22214.0.driveconfig Loaded successfully
[Mon 04/25/2016 08:03:50] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 04/25/2016 08:03:50] - B01 Power Management configuration request detected
[Mon 04/25/2016 08:03:50] - Successfully extracted *.DriveConfig file: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22214.0.driveconfig
[Mon 04/25/2016 08:03:50] - Extracted Config_ID: 1 (22214) in DriveConfig file: /home/root/Desktop/FW_PPRO_5_8_2_Release.906190.release--0/Configuration_Files/22214.0.driveconfig
[Mon 04/25/2016 08:03:50] - Extracted SerialOutputControl: 0
[Mon 04/25/2016 08:03:50] - Searching for flashware image for configuration 22214
[Mon 04/25/2016 08:03:50] - Manifest found for configuration 22214
[Mon 04/25/2016 08:03:50] - Flashware image extracted: 22214_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Mon 04/25/2016 08:03:50] - Searching for manufacturing image for configuration 22214
[Mon 04/25/2016 08:03:50] - Manufacturing image extracted: 22214_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Mon 04/25/2016 08:03:50] - Proceeding in ROM mode, download feature 3...
[Mon 04/25/2016 08:08:42] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  147.712110]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[  147.712118] ata2.00: status: { DRDY }
[  147.712130] ata2: hard resetting link
[  157.712041] ata2: softreset failed (1st FIS failed)
[  157.712058] ata2: hard resetting link
[  167.712052] ata2: softreset failed (1st FIS failed)
[  167.712068] ata2: hard resetting link
[  202.713040] ata2: softreset failed (1st FIS failed)
[  202.713058] ata2: limiting SATA link speed to 1.5 Gbps
[  202.713067] ata2: hard resetting link
[  207.867299] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  207.867315] ata2.00: link online but device misclassifed
[  212.867045] ata2.00: qc timeout (cmd 0xec)
[  212.867066] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  212.867074] ata2.00: revalidation failed (errno=-5)
[  212.867086] ata2: hard resetting link
[  222.867037] ata2: softreset failed (1st FIS failed)
[  222.867050] ata2: hard resetting link
[  232.868037] ata2: softreset failed (1st FIS failed)
[  232.868050] ata2: hard resetting link
[  267.868037] ata2: softreset failed (1st FIS failed)
[  267.868053] ata2: hard resetting link
[  273.023088] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  273.023103] ata2.00: link online but device misclassifed
[  283.023046] ata2.00: qc timeout (cmd 0xec)
[  283.023068] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  283.023076] ata2.00: revalidation failed (errno=-5)
[  283.023091] ata2: hard resetting link
[  293.023039] ata2: softreset failed (1st FIS failed)
[  293.023054] ata2: hard resetting link
[  303.024040] ata2: softreset failed (1st FIS failed)
[  303.024057] ata2: hard resetting link
[  338.024039] ata2: softreset failed (1st FIS failed)
[  338.024058] ata2: hard resetting link
[  343.180052] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  343.180066] ata2.00: link online but device misclassifed
[  373.180059] ata2.00: qc timeout (cmd 0xec)
[  373.180081] ata2.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  373.180089] ata2.00: revalidation failed (errno=-5)
[  373.180095] ata2.00: disabled
[  373.180129] ata2: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x6 frozen t4
[  373.180138] ata2: SError: { HostInt }
[  373.180150] ata2: hard resetting link
[  383.180037] ata2: softreset failed (1st FIS failed)
[  383.180051] ata2: hard resetting link
[  393.181040] ata2: softreset failed (1st FIS failed)
[  393.181057] ata2: hard resetting link
[  428.182041] ata2: softreset failed (1st FIS failed)
[  428.182059] ata2: hard resetting link
[  433.385065] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  433.385079] ata2.00: link online but device misclassifed
[  433.385126] ata2: EH complete
[Mon 04/25/2016 08:08:42] - End of Genesis manufacturing log.
[Mon 04/25/2016 08:08:42] - Exiting...
[Mon 04/25/2016 08:08:42] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线527945545
只看该作者 1楼 发表于: 2016-05-08
离线924011476
只看该作者 2楼 发表于: 2016-05-08
离线znd
只看该作者 3楼 发表于: 2016-05-09
