  • 2540阅读
  • 3回复
[SandForce]新人求救,2281开5-0-7成功后再次升5-2-2升过了? [复制链接]
离线huang888
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-05-15
提示如下:
Starting command:[/root/Desktop/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 15:0:0:0 "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.edriveconfig" 1234 444  LOG="/mnt/1234_localhost.localdomain_DATETIMESTAMP_15.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 05/15/2016 01:00:42] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 15:0:0:0
                      argv[3]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.edriveconfig
                      argv[5]: 1234
                      argv[6]: 444
                      argv[7]: LOG=/mnt/1234_localhost.localdomain_DATETIMESTAMP_15.0.0.0_PROCESS_SSD_RESULT.log
[Sun 05/15/2016 01:00:42] - Instructing the operating system to purge any existing cached data for device: '15:0:0:0'
[Sun 05/15/2016 01:00:47] - Issuing a discovery command for device: '15:0:0:0'
[Sun 05/15/2016 01:00:52] - Discovery command completed...
[Sun 05/15/2016 01:00:52] - Waiting 5 seconds for the system to settle...
[Sun 05/15/2016 01:00:57] - Device designation string '15:0:0:0' is mapped to node '/dev/sg3'
[Sun 05/15/2016 01:00:57] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg3
    MFP Package Filename = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.edriveconfig
              Serial No. = 1234
         World Wide Name = 444
[Sun 05/15/2016 01:00:57] - Successfully received the IDENTIFY data from the drive...
[Sun 05/15/2016 01:00:57] - FATAL_ERROR: This drive is already running MFB, please perform a force-download to enter in to the ROM mode first.  Genesis can not process drive in the current state... (0x10090020:SF_GENESIS_ALREADY_RUNNING_MFB_ERROR)
[Sun 05/15/2016 01:00:57] - End of Genesis manufacturing log.
[Sun 05/15/2016 01:00:57] - Exiting...
[Sun 05/15/2016 01:00:57] - Overall Result for Device: /dev/sg3 ****** FAIL ******
Process exited with code 18
离线watson
只看该作者 1楼 发表于: 2016-05-16
离线huang888
只看该作者 2楼 发表于: 2016-05-20
回 watson 的帖子
离线527945545
只看该作者 3楼 发表于: 2016-05-20
