  • 6600阅读
  • 12回复
[SandForce]近来没事又DIY一个 SF2281 128G完工了 [复制链接]
离线llm2323
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-06-09
最近在坛友处购买了一片建兴128G mSATA一片(颗粒是TH58TEG8DDJBA8C),由于没有mSATA接口,所以不知好坏,正好手头有一片SF2281的板子,拆颗粒上SF2281
拆颗粒
颗粒 植珠
准备DIY SF2281板
焊好颗粒
开卡一次成功
颗粒不错全部PASS
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27336.0.driveconfig
              Serial No. = 20160609
         World Wide Name = 881979
[Thu 06/09/2016 20:11:31] - Successfully received the IDENTIFY data from the drive...
[Thu 06/09/2016 20:11:31] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Thu 06/09/2016 20:11:48] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Thu 06/09/2016 20:11:48] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27336.0.driveconfig Loaded successfully
[Thu 06/09/2016 20:11:48] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 06/09/2016 20:11:48] - B01 Power Management configuration request detected
[Thu 06/09/2016 20:11:48] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27336.0.driveconfig
[Thu 06/09/2016 20:11:48] - Extracted Config_ID: 1 (27336) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27336.0.driveconfig
[Thu 06/09/2016 20:11:48] - Extracted SerialOutputControl: 0
[Thu 06/09/2016 20:11:48] - Searching for flashware image for configuration 27336
[Thu 06/09/2016 20:11:48] - Manifest found for configuration 27336
[Thu 06/09/2016 20:11:48] - Flashware image extracted: 27336_fw_cl_mlc_Toshiba_64Gb_TH58TEG7DDJBA4C_2Q_2C_1D_PP_R01406_s512.vic
[Thu 06/09/2016 20:11:48] - Searching for manufacturing image for configuration 27336
[Thu 06/09/2016 20:11:48] - Manufacturing image extracted: 27336_mf_mlc_Toshiba_64Gb_TH58TEG7DDJBA4C_2Q_2C_1D_PP_R01406_s512.vic
[Thu 06/09/2016 20:11:48] - Proceeding in ROM mode, download feature 3...
[Thu 06/09/2016 20:11:48] - Successfully downloaded MFB to the drive...
[Thu 06/09/2016 20:11:48] - Waiting (5 sec) for the drive to settle...
[Thu 06/09/2016 20:11:53] - Successfully received the IDENTIFY data from the drive...
[Thu 06/09/2016 20:11:53] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Thu 06/09/2016 20:11:53] - Successfully enabled SMART capabilities...
[Thu 06/09/2016 20:11:55] - Successfully issued a diagnostic unlock...
[Thu 06/09/2016 20:11:56] - Performing the flash test of block 0 (0x0000)...
[Thu 06/09/2016 20:11:58] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
在SATAⅡ测试
完工!
[ 此帖被llm2323在2016-06-10 05:48重新编辑 ]
本帖最近打赏记录:共9条打赏 ,M币+38 ,专家+1
离线懒虫包子
只看该作者 1楼 发表于: 2016-06-09
离线jlzswu
只看该作者 2楼 发表于: 2016-06-09
离线llm2323
只看该作者 3楼 发表于: 2016-06-09
离线527945545
只看该作者 4楼 发表于: 2016-06-09
离线huakun888
只看该作者 5楼 发表于: 2016-06-09
本帖最近打赏记录:共1条打赏 ,M币+3
离线sclwindows
只看该作者 6楼 发表于: 2016-06-12
离线perter
只看该作者 7楼 发表于: 2016-06-12
回 sclwindows 的帖子
离线ringlys0
只看该作者 8楼 发表于: 2016-06-12
离线janhou
只看该作者 9楼 发表于: 2016-06-13
