  • 2124阅读
  • 8回复
[SandForce]请教大神sf2281有个flash坏了怎么找出来 [复制链接]
离线tyy19890927
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-07-07
怎么确定在板子上的位置
<?xml version = "1.0"?>
<Genesis_Log>
     factory bad block.-----------------------------------------------------------------------------
+------+------+------+------+--------+--------------------------------------------+---------+| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
-----------------------------------------------------------------------------  Total Number of test results: 16
            Number of failures: 1                               Number of Passed with warnings: 0
      No. Passed without warnings: 15                      -----------------------------------------------------------------------------
[Wed 07/06/2016 22:07:13] - End of Genesis manufacturing log.[Wed 07/06/2016 22:07:13] - Exiting...
    </Log_Body>
    <Overa
[ 此帖被tyy19890927在2016-07-07 07:57重新编辑 ]
本帖最近打赏记录:共1条打赏专家+1
离线xiaowhite
只看该作者 1楼 发表于: 2016-07-07
离线527945545
只看该作者 2楼 发表于: 2016-07-07
本帖最近打赏记录:共1条打赏M币+3
离线jacythomas
只看该作者 3楼 发表于: 2016-07-07
离线924011476
只看该作者 4楼 发表于: 2016-07-07
离线tyy19890927
只看该作者 5楼 发表于: 2016-07-07
离线huqiaqia
只看该作者 6楼 发表于: 2016-07-08
回 tyy19890927 的帖子
离线tyy19890927
只看该作者 7楼 发表于: 2016-07-08
回 huqiaqia 的帖子
离线tyy19890927
只看该作者 8楼 发表于: 2016-07-08
回 huqiaqia 的帖子
