  • 2764阅读
  • 5回复
[SandForce]16贴CBAAA,帮忙看看是有片闪存坏块过多还是焊接问题 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-07-09
OCZ标准2281 TSOP板子,能找出哪片闪存问题吗
问题log红色标记了
[Sat 07/09/2016 04:45:38] - Successfully received the IDENTIFY data from the drive...
[Sat 07/09/2016 04:45:38] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sat 07/09/2016 04:45:42] - Successfully opened the package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Sat 07/09/2016 04:45:42] - file  /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22189.123456.driveconfig Loaded successfully
[Sat 07/09/2016 04:45:51] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sat 07/09/2016 04:45:51] - B01 Power Management configuration request detected
[Sat 07/09/2016 04:45:51] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22189.123456.driveconfig
[Sat 07/09/2016 04:45:51] - Extracted Config_ID: 1 (22189) in DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22189.123456.driveconfig
[Sat 07/09/2016 04:45:51] - Extracted SerialOutputControl: 0
[Sat 07/09/2016 04:45:51] - Searching for flashware image for configuration 22189
[Sat 07/09/2016 04:45:51] - Manifest found for configuration 22189
[Sat 07/09/2016 04:45:51] - Flashware image extracted: 22189_fw_cl_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_S_PP_R00714_s512.vic
[Sat 07/09/2016 04:45:51] - Searching for manufacturing image for configuration 22189
[Sat 07/09/2016 04:45:51] - Manufacturing image extracted: 22189_mf_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_S_PP_R00714_s512.vic
[Sat 07/09/2016 04:45:51] - Proceeding in ROM mode, download feature 3...
[Sat 07/09/2016 04:45:52] - Successfully downloaded MFB to the drive...
[Sat 07/09/2016 04:45:52] - Waiting (5 sec) for the drive to settle...
[Sat 07/09/2016 04:45:57] - Successfully received the IDENTIFY data from the drive...
[Sat 07/09/2016 04:45:57] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Sat 07/09/2016 04:45:57] - Successfully enabled SMART capabilities...
[Sat 07/09/2016 04:45:59] - Successfully issued a diagnostic unlock...
[Sat 07/09/2016 04:46:00] - Performing the flash test of block 0 (0x0000)...
[Sat 07/09/2016 04:46:03] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
  N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0375 | N1,N4,N5,N6,N8,N10                         |    FAIL |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 1    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
  Total Number of test results: 16
            Number of failures: 1
         Number of Passed with warnings: 15
      No. Passed without warnings: 0
[Sat 07/09/2016 04:46:03] - End of Genesis manufacturing log.
[Sat 07/09/2016 04:46:03] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Sat, 07/09/2016 @ 04:45:23 </Start_Time>
        <End_Time> Sat, 07/09/2016 @ 04:46:03 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[1]: -PROCESS_SSD
                  argv[2]: 7:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22189.123456.driveconfig
                  argv[5]: 123
                  argv[6]: 456
                  argv[7]: LOG=/root/mpt/log/123_localhost.localdomain_DATETIMESTAMP_7.0.0.0_PROCESS_SSD_RESULT.log
        </Input_Parameters>
        <Log_File> /root/mpt/log/123_localhost.localdomain_DATETIMESTAMP_7.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 3 </Port_Number>
        <Device_Name> /dev/sg3 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Sat 07/09/2016 04:46:03] - Overall Result for Device: /dev/sg3 ****** FAIL ******
[ 此帖被大概没人注册在2016-07-09 13:58重新编辑 ]
离线jacythomas
只看该作者 1楼 发表于: 2016-07-09
离线527945545
只看该作者 2楼 发表于: 2016-07-09
本帖最近打赏记录:共1条打赏M币+3
只看该作者 3楼 发表于: 2016-07-09
离线testpoint
只看该作者 4楼 发表于: 2016-07-09
离线aeiou88_2000
只看该作者 5楼 发表于: 2016-07-10
