  • 2371阅读
  • 8回复
[网络]电信CDMA微功率直放站、信号放大器 [复制链接]
离线clw9981
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-10-11
Introduction
signalwing corporation J1F series is designed for family type mini individual user design repeater. J1F Series Mini Repeater offers not only elegant versatile design of appearance but also contribute outstanding performance for indoor coverage problem solution. It amplifies signals between a mobile and a BTS for indoor applications where are located in shadowing areas blocked by obstructions or impediments. The J1F Series Mini Repeater works sufficiently to optimize cell coverage for any relevant system in GSM, CDMA or WCDMA and can be applied to variable options of band selective or dual band.Built-in service antenna concept is exceptional for quick installation by excluding routing and wiring procedure.It is well harmonized to all kinds of environments in the networks.
Product Features
1、Antenna isolation testing 2、Automatic gain control
3、Intelligent mode setting 4、Uplink sleep mode
5、To prevent the oscillation shutdown 6、Built-in service antenna
7、Cost-effective for practical solutions 8、Low interference
Uplink
Downlink
Maximum Gain
824-849MHz
890-915MHz
1920-1980MHz
869-894MHz
935-960MHz
2110-21700MHz
Maximum Gain
65dB±3dB
70dB±3dB
Output Power
≧13dBm
≧07dBm
Digital attenuation (inside)
25dB in step of 1dB
Maximum input power(non-destructive)
0dBm(CW Signal)
Spurious
Emission
9kHz~150KHz
≦ -36dBm/1 kHz
150kHz~30MHz
≦ -36dBm/10 kHz
30MHz~1GHz
≦ -36dBm/100 kHz
1 GHz ~ Flow - 10 MHz
≦ -30dBm/1 MHz
Flow - 10 MHz ~ Fhigh + 10 MHz
≦ -15dBm/1 MHz
Fhigh + 10 MHz ~12.75 GHz
≦ -30dBm/1 MHz
Frequency Stability
≦±0.01ppm
Error Vector Magnitude
≦ 10%
Auto Gain Control(AGC)
≧25dB
Noise Figure
≦ 6dB
Return loss
≦-10dB
Group Delay
≦ 1μs
Power Consumption
8W
Power Supply
DC 6V/3A
2、Mechanical specification
Dimensions
103.5*83.5*49.4 mm
Weight
≦800g
Impedance
(Nominal)50Ω
I/O Connector
SMA-female
3、Environmental specification
IP Rating
IP30
Operating Temperature
-10℃ ~50℃
4、Monitoring specification
2、Alarm
specification
LED indication
Power LED
DC ON/OFF
AGC LED
ALC1~5dB,red
output power
Noraml /OFF
Alarm Red/When output power over 3dBm
ISO LED
ISO red,Antenna isolation is  lower than the isolation for equipment installation, repeater will adjust the gain automatically without necessary of position adjusting for antennas.
电信CDMA微功率直放站、信号放大器
本帖最近打赏记录:共3条打赏 ,M币+9
离线放下
只看该作者 1楼 发表于: 2016-10-11
离线云月缘
只看该作者 2楼 发表于: 2016-10-11
回 放下 的帖子
离线clw9981
只看该作者 3楼 发表于: 2016-10-11
本帖最近打赏记录:共2条打赏 ,M币+8
离线ok2ok
只看该作者 4楼 发表于: 2016-10-11
离线tulips
只看该作者 5楼 发表于: 2016-10-11
离线sckocn
只看该作者 6楼 发表于: 2016-10-11
离线7365259
只看该作者 7楼 发表于: 2016-10-11
离线clw9981
只看该作者 8楼 发表于: 2017-05-06
