SF2281 主控 OCZ的板子,前段时间掉盘了,主板不认盘, flash 是镁光 MT29F64G08CFACA 16颗 120G
开卡用的文件是 27082 公开的 522版本 那个文件 失败 日志如下 希望大神给分析下 看看 是不是 flash 坏了一个 ?
要怎么解决 ?
Starting command:[/root/Desktop/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 6:0:0:0 "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig" 123 3 LOG="/mnt/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 10/17/2016 10:58:06] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 6:0:0:0
argv[3]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
argv[4]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig
argv[5]: 123
argv[6]: 3
argv[7]: LOG=/mnt/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
[Mon 10/17/2016 10:58:06] - Instructing the operating system to purge any existing cached data for device: '6:0:0:0'
[Mon 10/17/2016 10:58:11] - Issuing a discovery command for device: '6:0:0:0'
[Mon 10/17/2016 10:58:16] - Discovery command completed...
[Mon 10/17/2016 10:58:16] - Waiting 5 seconds for the system to settle...
[Mon 10/17/2016 10:58:21] - Device designation string '6:0:0:0' is mapped to node '/dev/sg2'
[Mon 10/17/2016 10:58:21] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
Configuration File = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig
Serial No. = 123
World Wide Name = 3
[Mon 10/17/2016 10:58:21] - Successfully received the IDENTIFY data from the drive...
[Mon 10/17/2016 10:58:21] - Validating Manufacturing Firmware Package: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 10/17/2016 10:58:23] - Successfully opened the package: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 10/17/2016 10:58:23] - file /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig Loaded successfully
[Mon 10/17/2016 10:58:32] - B01 Power Management configuration request detected
[Mon 10/17/2016 10:58:32] - B01 Power Management conforms to hardware version 0x0
[Mon 10/17/2016 10:58:32] - Successfully extracted *.DriveConfig file: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig
[Mon 10/17/2016 10:58:32] - Extracted Config_ID: 1 (27082) in DriveConfig file: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27082.0.driveconfig
[Mon 10/17/2016 10:58:32] - Extracted SerialOutputControl: 0
[Mon 10/17/2016 10:58:32] - Searching for flashware image for configuration 27082
[Mon 10/17/2016 10:58:32] - Manifest found for configuration 27082
[Mon 10/17/2016 10:58:32] - Flashware image extracted: 27082_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_4C_1D_S_PP_R01088_s512.vic
[Mon 10/17/2016 10:58:32] - Searching for manufacturing image for configuration 27082
[Mon 10/17/2016 10:58:32] - Manufacturing image extracted: 27082_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_4C_1D_S_PP_R01088_s512.vic
[Mon 10/17/2016 10:58:32] - Proceeding in ROM mode, download feature 3...
[Mon 10/17/2016 10:58:32] - Successfully downloaded MFB to the drive...
[Mon 10/17/2016 10:58:32] - Waiting (5 sec) for the drive to settle...
[Mon 10/17/2016 10:58:37] - Successfully received the IDENTIFY data from the drive...
[Mon 10/17/2016 10:58:37] - Firmware revision reported to be: '522ABBM0'. This indicates MFB download was successful.
[Mon 10/17/2016 10:58:37] - Successfully enabled SMART capabilities...
[Mon 10/17/2016 10:58:39] - Successfully issued a diagnostic unlock...
[Mon 10/17/2016 10:58:41] - Performing the flash test of block 0 (0x0000)...
[Mon 10/17/2016 10:58:43] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 4
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0002 | N3 | WARNING |
| 0 | 0 | 0 | 1 | 0x0002 | N3 | WARNING |
| 0 | 0 | 0 | 2 | 0x0002 | N3 | WARNING |
| 0 | 0 | 0 | 3 | 0x0042 | N3,N6 | WARNING |
| 0 | 1 | 0 | 0 | 0x0002 | N3 | WARNING |
| 0 | 1 | 0 | 1 | 0x0002 | N3 | WARNING |
| 0 | 1 | 0 | 2 | 0x0002 | N3 | WARNING |
| 0 | 1 | 0 | 3 | 0x0003 | N1,N3 | WARNING |
| 0 | 2 | 0 | 0 | 0x0043 | N1,N3,N6 | WARNING |
| 0 | 2 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 2 | 0 | 2 | 0x0022 | N3,N5 | WARNING |
| 0 | 2 | 0 | 3 | 0x0042 | N3,N6 | WARNING |
| 0 | 3 | 0 | 0 | 0x0022 | N3,N5 | WARNING |
| 0 | 3 | 0 | 1 | 0x0022 | N3,N5 | WARNING |
| 0 | 3 | 0 | 2 | 0x0002 | N3 | WARNING |
| 0 | 3 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 1 | 0 | 0 | 0 | 0x0003 | N1,N3 | WARNING |
| 1 | 0 | 0 | 1 | 0x0002 | N3 | WARNING |
| 1 | 0 | 0 | 2 | 0x0002 | N3 | WARNING |
| 1 | 0 | 0 | 3 | 0x0002 | N3 | WARNING |
| 1 | 1 | 0 | 0 | 0x0002 | N3 | WARNING |
| 1 | 1 | 0 | 1 | 0x0002 | N3 | WARNING |
| 1 | 1 | 0 | 2 | 0x0003 | N1,N3 | WARNING |
| 1 | 1 | 0 | 3 | 0x0043 | N1,N3,N6 | WARNING |
| 1 | 2 | 0 | 0 | 0x0002 | N3 | WARNING |
| 1 | 2 | 0 | 1 | 0x0022 | N3,N5 | WARNING |
| 1 | 2 | 0 | 2 | 0x0003 | N1,N3 | WARNING |
| 1 | 2 | 0 | 3 | 0x0002 | N3 | WARNING |
| 1 | 3 | 0 | 0 | 0x0042 | N3,N6 | WARNING |
| 1 | 3 | 0 | 1 | 0x0002 | N3 | WARNING |
| 1 | 3 | 0 | 2 | 0x0042 | N3,N6 | WARNING |
| 1 | 3 | 0 | 3 | 0x0002 | N3 | WARNING |
Total Number of test results: 32
Number of failures: 1
Number of Passed with warnings: 30
No. Passed without warnings: 1
[Mon 10/17/2016 10:58:43] - End of Genesis manufacturing log.
[Mon 10/17/2016 10:58:43] - Exiting...
[Mon 10/17/2016 10:58:43] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 7
