  • 9850阅读
  • 11回复
[电源]拆拆更快乐:拆自己的索尼W390相机的原装充电器! [复制链接]
离线kernel32
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2010-07-11
原装的随机带的锂电池充电器:型号:BC-CSN
输出:4.2V  0.25A
产地:中国。
内部的MIP2k2芯片资料如下:
High-Performance IPD for Battery Chargers
Featuring built-in frequency jitter necessary for EMI,
while also conserving power during standby!
MIP2Kx Series
Overview
拆拆更快乐:拆自己的索尼W390相机的原装充电器!   MIP2Kx series is a high-performance IPD designed for 15W battery chargers and featuring built-in frequency jitter function at PWM control. It features built-in protection circuits necessary for compact power source charger circuitry. This allows a significant reduction in externally connected parts. It provides PWM control when a normal load is applied and intermittent control with low load. This results in greater efficiency for very low to maximum loads, while also conserving power during standby.
Features
  • Built-in jitter function
  • Built-in charge protection circuit
    Built-in overheating, load shorting and overvoltage protection circuits
Applications
Chargers (for DSC, etc.), AC adapter
Lineup
Type No.Output *1Characteristic
VDSSILIMITR (DS) ONfoscΔffM
MIP2K2 *2Up to 5W700V0.35A16.5Ω100kHz5.5kHz260Hz
MIP2K3Up to 8W0.50A10Ω
MIP2K4Up to 10W0.70A
MIP2K5 *2Up to 13W1.0A
*1 The electric power mentioned above depends on the transformer specification and ambient conditions. The information should be used only as a guide. When using it within a case, output electric power may be decided by heat of IPD.
*2 All characteristic values are only for reference (still under development).
google翻译后:
高性能电池充电器知识产权署
配备内置EMI的频率抖动必要,
在待机状态,同时也节省电力!
高性能电池充电器知识产权署
MIP2Kx Series
MIP2Kx系列
Overview
概观
MIP2Kx系列是一个高性能的知识产权署为15W的电池充电器设计,并具有内置的频率抖动功能在PWM控制。它具有内置的保护电路所需的小型电源充电器电路。
这使得连接显着减少了外部零件。PWM控制时,它提供了一个正常的负荷和低负荷间歇应用控制。
这将导致更大的效率非常低,最高负荷,同时也保护在备用电源。
Features
特点
    内置抖动功能
    内置充电保护电路
    内置过热,负载短路和过电压保护电路
Applications
应用
充电器(用于数码相机等),AC适配器
Lineup
阵容
Type No.
型号
Output *1
输出* 1
Characteristic
特征
VDSS
减振钢板
ILIMIT
ILIMIT
R (DS) ON
住宅(副局长)关于
fosc
fosc
Δf
变化Δf
fM
调频
MIP2K2 *2
MIP2K2 * 2
Up to 5W
截至5瓦
700V
700伏特
0.35A
0.35A
16.5Ω
16.5Ω
100kHz
100kHz的
5.5kHz
5.5kHz
260Hz
260Hz
MIP2K3
MIP2K3
Up to 8W
截至8条
0.50A
0.50A
10Ω
10Ω
MIP2K4
MIP2K4
Up to 10W
高达10W的
0.70A
0.70A
MIP2K5 *2
MIP2K5 * 2
Up to 13W
高达13瓦特
1.0A
1.0安培
* 1上述电力依赖于变压器规格和环境条件。
该信息应仅作为参考。
当使用在一个情况下,输出的电力可以由知识产权署的热量。
* 2所有特征值仅供参考(仍在开发)。
离线kernel32
只看该作者 1楼 发表于: 2010-07-11
本帖最近打赏记录:共6条打赏
离线kernel32
只看该作者 2楼 发表于: 2010-07-11
离线kernel32
只看该作者 3楼 发表于: 2010-07-11
离线ujjl
只看该作者 4楼 发表于: 2010-07-11
离线kernel32
只看该作者 5楼 发表于: 2010-07-11
离线無心之過
只看该作者 6楼 发表于: 2010-07-11
离线fenglei1
只看该作者 7楼 发表于: 2010-07-11
离线swqqwsswq
只看该作者 8楼 发表于: 2010-07-11
离线kof-1997
只看该作者 9楼 发表于: 2010-07-11
