  • 21950阅读
  • 23回复
[存储]希捷ST2000LM015笔记本硬盘2T.7MM 90g,单碟OR双碟 [复制链接]
离线a19930925
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-12-08
本次投票已结束
最多可选1项,共有19人参与,
3(15.79%)
16(84.21%)
0(0%)
首先这只是个简单普通的投票2.0 Drive Specifications
Unless otherwise noted, all specifications are measured under ambient conditions, at 25°C, and nominal power. For convenience, the phrases the
drive and this drive are used throughout this manual to indicate the following drive models:
The specification summaries listed in the following tables are for quick reference. For details on specification measurement or definition, refer to the
appropriate section of this manual.
Table 1 Drive Specifications Summary
Drive Specification ST2000LM015 ST1000LM048 ST500LM030
Formatted capacity (1) 2TB 1TB 500GB
Guaranteed sectors 3,907,029,168 1,953,525,168 976,773,168
Heads 4 2
Disks 2 1
Bytes per sector 512 (logical) / 4096 (physical)
Recording density 2276 Kb/in
Track density 580 Ktracks/in avg答案已出 感谢指教
[ 此帖被a19930925在2016-12-09 12:48重新编辑 ]
离线a19930925
只看该作者 1楼 发表于: 2016-12-08
[ 此帖被a19930925在2016-12-09 12:49重新编辑 ]
离线looknew
只看该作者 2楼 发表于: 2016-12-08
离线a19930925
只看该作者 3楼 发表于: 2016-12-08
回 looknew 的帖子
离线lookingliudi
只看该作者 4楼 发表于: 2016-12-08
离线mirocus
只看该作者 5楼 发表于: 2016-12-08
离线a19930925
只看该作者 6楼 发表于: 2016-12-08
回 mirocus 的帖子
离线1214962088
只看该作者 7楼 发表于: 2016-12-08
离线adsl_95
只看该作者 8楼 发表于: 2016-12-08
离线a19930925
只看该作者 9楼 发表于: 2016-12-08
回 adsl_95 的帖子
