  • 4603阅读
  • 26回复
[工仪]韩国万用表 Protek 506 [复制链接]
离线liquidator
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-12-10
韩国万用表 Protek 506
Protek 506
功能比较多,性能却很差,用一用就误差奇大。
有人懂怎么调一下吗?
黑孔装错了。
万用表 Protek 506 功能和性能如下
3-3/4 Digit,4K count, Dual Disp.,True RMS,RS232C
Features
  • Dual display for frequency,AC voltage and Temperature measurements
  • 10 MHz frequency counter and decibel measurement.
  • True RMS AC voltage and current readings
  • RS-232 interface and software for downloading measurements to a
    PC(model 506 only)
  • 10 memory locations and analog bar graph
  • Time and Stop watch mode with Alarm
  • Min., Max., Avg and Relative mode
  • Capacitance and Inductance measurement
  • Temperature measurement in Centigrade and Fahrenheit
  • Frequency generator, logic probe function and back light
  • Auto power off and "keep on" modes
Specifications
Volts DC
Ranges (5)400mV to 1000V
Best Resolution0.1mV
Accuracy±(0.5% Rdg + 2D)
Volts AC
Ranges (5)400mV to 750V
Accuracy±(1.5% Rdg + 5D)
DC Current
Ranges400μA, 400mA, 20A
Best Resolution0.1μA
Accuracy±(1% Rdg + 2D)
AC Current
Accuracy±(1.5% Rdg + 2D), 50Hz to 100Hz
Resistance
Ranges (6)400W to 40MW
Best Resolution0.1W
Decibel
Ranges (4)-31.6 to + 59.71dB
Best Accuracyμ0.5dB
Continuity
BuzzerSound at < 100W .
Display Will ReadShrt when R < 100W
Open when R > 100W
Diode
Display Will ReadShrt when V < 0.5V
Good when V = 0.5V to 1V
Open when V > 1V
Frequency
Ranges (4)10kHz to 10MHz
Best Resolution1Hz
Accuracy±(0.01% Rdg x 1D)
Sensitivity1.5V RMS
Temperature
Range-17 to 1200°C (0 to 2000°F)
Resolution1°C and 1°F
Accuracy±(3% Rdg + 3D)
Logic Probe
TLL Level Display Will ReadLo when V is < 0.8V
Hi when V is > 2.0V
W when V is 0.8V to 2.0V
Capacitance
Range0 to 100°F
Resolution0.01°F
Accuracy±(3% Rdg + 5D)
Inductance
Range0 to 100H
Resolution0.01H
Miscellaneous
Signal Out2048Hz, 4096Hz, 8192Hz Square wave
Timer Range1 second to 10 hours
RS-232 Interface1200bps, 9 Pin Connector
General Specifications
Size8.0" H x 3.6" W x 1.5" D
Weight1 lb.
Power9V battery
Supplied AccessoriesManual, Test leads, Holster, Temp adapter, "K" type temp probe, RS-232 cable and Software
[size=; font-size: 1.5em,1.5em]Protek 506 Product Specifications Summary:
(for full specs please see the full specs tab or the data sheet)
Multimeters Template
TypeDigital
StyleHand-Held
True RMS What's This?Yes
Maximum Voltage AC750 V
Resolution AC Volts0.1 mV
Maximum Voltage DC1000 V
Resolution DC Volts0.1 mV
Maximum Current AC What's This?20 A
Resolution AC Current0.1 uA (0.00010 mA)
Maximum Current DC20 A
Resolution DC Current0.1 uA (0.00010 mA)
Basic Accuracy V DC± 0.5% Rdg + 2D
# Digit Display What's This?3.75
Counts What's This?4000 .
BacklightYes
Manual/Autoranging What's This?Manual
ResistanceYes
FrequencyYes
Continuity What's This?Yes
CapacitanceYes
TemperatureYes
Peak HoldNo
Intrinsically Safe What's This?No
Wireless DisplayNo
Data Hold What's This?No
Low-Pass Filter What's This?No
韩国万用表 Protek 506
本帖最近打赏记录:共15条打赏M币+52
12
离线liquidator
只看该作者 1楼 发表于: 2016-12-10
本帖最近打赏记录:共11条打赏M币+37
12
离线zbajim
只看该作者 2楼 发表于: 2016-12-10
本帖最近打赏记录:共1条打赏M币+3
只看该作者 3楼 发表于: 2016-12-10
本帖最近打赏记录:共1条打赏M币+3
离线wjhwpp
只看该作者 4楼 发表于: 2016-12-10
本帖最近打赏记录:共1条打赏M币+3
离线yueyuan158
只看该作者 5楼 发表于: 2016-12-10
本帖最近打赏记录:共1条打赏M币+3
离线mrlei
只看该作者 6楼 发表于: 2016-12-10
离线lookball
只看该作者 7楼 发表于: 2016-12-10
本帖最近打赏记录:共1条打赏M币+3
离线liquidator
只看该作者 8楼 发表于: 2016-12-10
离线hover_730
只看该作者 9楼 发表于: 2016-12-10
