Array
  • 1386阅读
  • 0回复
[SandForce]SF开卡求助(问题已经解决,删帖) [复制链接]
离线xuesajiutian
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-03-07
问题已经解决,删帖
2017-03-07 18:33:32 : Drive started
2017-03-07 18:33:32 : Found drive for slot 0 at adapter 0, device 0
2017-03-07 18:33:35 : Start Force MFB download
2017-03-07 18:34:00 : Running Flash Test
Flash Test Results
+    Bus |     CE |    Die |   Lane |      Results       +
|      0 |      0 |      0 |      0 |  0001     Passed   |
|      0 |      0 |      0 |      1 |  0001     Passed   |
|      0 |      0 |      0 |      2 |  0001     Passed   |
|      0 |      0 |      0 |      3 |  0001     Passed   |
|      0 |      1 |      0 |      0 |  0374     Failed   |
|      0 |      1 |      0 |      1 |  0364     Failed   |
|      0 |      1 |      0 |      2 |  0364     Failed   |
|      0 |      1 |      0 |      3 |  0001     Passed   |
|      1 |      0 |      0 |      0 |  0001     Passed   |
|      1 |      0 |      0 |      1 |  0001     Passed   |
|      1 |      0 |      0 |      2 |  0001     Passed   |
|      1 |      0 |      0 |      3 |  0001     Passed   |
|      1 |      1 |      0 |      0 |  0180     Passed   |
|      1 |      1 |      0 |      1 |  0374     Failed   |
|      1 |      1 |      0 |      2 |  0001     Passed   |
|      1 |      1 |      0 |      3 |  0364     Failed   |
2017-03-07 18:34:00 : Flash Test Failed
2017-03-07 18:34:00 : Failed for Flash Test
请问大神,如何判断是虚焊或者连焊导致的Flash不过,还是Flash坏块太多呢,
[ 此帖被xuesajiutian在2017-03-08 14:40重新编辑 ]
Array
