  • 2209阅读
  • 5回复
[SandForce]SF2281 海力士颗粒 4贴128G已经找到适合的固件,出问题,求解! [复制链接]
离线biyu2008
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-03-08
下面是错误代码。英语不好,求大神帮看看,怎么解决,貌似是硬件问题,接口还是什么来着的。
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Wed 03/08/2017 20:54:22] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /root/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
                      argv[4]: /root/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/Configuration_Files/22282.12345600.driveconfig
                      argv[5]: 123
                      argv[6]: 456
                      argv[7]: LOG=/root/ssd/Genesis/Logs/123_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Wed 03/08/2017 20:54:22] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Wed 03/08/2017 20:54:27] - Issuing a discovery command for device: '1:0:0:0'
[Wed 03/08/2017 20:54:33] - Discovery command completed...
[Wed 03/08/2017 20:54:33] - Waiting 5 seconds for the system to settle...
[Wed 03/08/2017 20:54:38] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Wed 03/08/2017 20:54:38] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
      Configuration File = /root/ssd/mpt/FW_SF-2000_MP_5-0-7_Client--12345600/Configuration_Files/22282.12345600.driveconfig
              Serial No. = 123
         World Wide Name = 456
[Wed 03/08/2017 20:54:38] - Successfully received the IDENTIFY data from the drive...
离线eboy998
只看该作者 1楼 发表于: 2017-03-08
离线biyu2008
只看该作者 2楼 发表于: 2017-03-08
离线biyu2008
只看该作者 3楼 发表于: 2017-03-08
离线527945545
只看该作者 4楼 发表于: 2017-03-09
离线biyu2008
只看该作者 5楼 发表于: 2017-03-09
