  • 4610阅读
  • 10回复
[SandForce]sf2281错误  FATAL_ERROR: Could not get the IDENTIFY data from the drive [复制链接]
离线ppop123
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-05-03
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 05/02/2017 @ 10:02:54
                  End Time: Tue, 05/02/2017 @ 10:05:22
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 18:0:0:0
                  argv[3]: /root/ssd/mpt/FW_PPRO_6_0_4_Release.1032185.release--123456/FW_PPRO_6_0_4_Release.1032185.release.123456.mfp
                  argv[4]: /root/ssd/mpt/27714.123456.driveconfig
                  argv[5]: 0
                  argv[6]: 0
                  argv[7]: LOG=/root/ssd/mpt/0_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/ssd/mpt/0_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 05/02/2017 10:02:54] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 18:0:0:0
                      argv[5]: 0
                      argv[6]: 0
[Tue 05/02/2017 10:02:54] - Instructing the operating system to purge any existing cached data for device: '18:0:0:0'
[Tue 05/02/2017 10:02:59] - Issuing a discovery command for device: '18:0:0:0'
[Tue 05/02/2017 10:03:04] - Discovery command completed...
[Tue 05/02/2017 10:03:04] - Waiting 5 seconds for the system to settle...
[Tue 05/02/2017 10:03:09] - Device designation string '18:0:0:0' is mapped to node '/dev/sg2'
[Tue 05/02/2017 10:03:09] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/ssd/mpt/FW_PPRO_6_0_4_Release.1032185.release--123456/FW_PPRO_6_0_4_Release.1032185.release.123456.mfp
      Configuration File = /root/ssd/mpt/27714.123456.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Tue 05/02/2017 10:03:10] - Successfully received the IDENTIFY data from the drive...
[Tue 05/02/2017 10:03:10] - Validating Manufacturing Firmware Package: /root/ssd/mpt/FW_PPRO_6_0_4_Release.1032185.release--123456/FW_PPRO_6_0_4_Release.1032185.release.123456.mfp
[Tue 05/02/2017 10:03:17] - Successfully opened the package: /root/ssd/mpt/FW_PPRO_6_0_4_Release.1032185.release--123456/FW_PPRO_6_0_4_Release.1032185.release.123456.mfp
[Tue 05/02/2017 10:03:17] - file  /root/ssd/mpt/27714.123456.driveconfig Loaded successfully
[Tue 05/02/2017 10:03:26] - B01 Power Management configuration request detected
[Tue 05/02/2017 10:03:26] - B01 Power Management conforms to hardware version 0x0
[Tue 05/02/2017 10:03:26] - Successfully extracted *.DriveConfig file: /root/ssd/mpt/27714.123456.driveconfig
[Tue 05/02/2017 10:03:26] - Extracted Config_ID: 1 (27714) in DriveConfig file: /root/ssd/mpt/27714.123456.driveconfig
[Tue 05/02/2017 10:03:26] - Extracted SerialOutputControl: 0
[Tue 05/02/2017 10:03:26] - Searching for flashware image for configuration 27714
[Tue 05/02/2017 10:03:26] - Manifest found for configuration 27714
[Tue 05/02/2017 10:03:26] - Flashware image extracted: 27714_fw_cl_mlc_Toshiba_64Gb_TH58TEG9DDJBA89_2Q_2C_2D_PP_R01411_s512.vic
[Tue 05/02/2017 10:03:26] - Searching for manufacturing image for configuration 27714
[Tue 05/02/2017 10:03:26] - Manufacturing image extracted: 27714_mf_mlc_Toshiba_64Gb_TH58TEG9DDJBA89_2Q_2C_2D_PP_R01411_s512.vic
[Tue 05/02/2017 10:03:26] - Proceeding in ROM mode, download feature 3...
[Tue 05/02/2017 10:03:27] - Successfully downloaded MFB to the drive...
[Tue 05/02/2017 10:03:27] - Waiting (5 sec) for the drive to settle...
[Tue 05/02/2017 10:03:32] - Successfully received the IDENTIFY data from the drive...
[Tue 05/02/2017 10:03:32] - Firmware revision reported to be: '604ABBM0'.  This indicates MFB download was successful.
[Tue 05/02/2017 10:03:32] - Successfully enabled SMART capabilities...
[Tue 05/02/2017 10:03:34] - Successfully issued a diagnostic unlock...
[Tue 05/02/2017 10:03:36] - Performing the flash test of block 0 (0x0000)...
[Tue 05/02/2017 10:03:39] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 2
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 32
[Tue 05/02/2017 10:03:39] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 468862128
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 15000 (0x3A98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Tue 05/02/2017 10:04:08] - FORMAT command completed...
[Tue 05/02/2017 10:04:08] - Waiting (2 sec) for the drive to settle...
[Tue 05/02/2017 10:04:10] - Setting up the stamp information through CDU command...
[Tue 05/02/2017 10:04:14] - Waiting (2 sec) for the drive to settle...
[Tue 05/02/2017 10:04:16] - Downloading the flashware to the drive... feature 3
[Tue 05/02/2017 10:04:18] - Successfully downloaded flashware to the drive...
[Tue 05/02/2017 10:04:18] - Waiting (15 sec) for the drive to settle...
[Tue 05/02/2017 10:05:22] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Tue 05/02/2017 10:05:22] - End of Genesis manufacturing log.
[Tue 05/02/2017 10:05:22] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Tue, 05/02/2017 @ 10:02:54 </Start_Time>
        <End_Time> Tue, 05/02/2017 @ 10:05:22 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 18:0:0:0
                  argv[5]: 0
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> /root/ssd/mpt/0_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Tue 05/02/2017 10:05:22] - Overall Result for Device: /dev/sg2 ****** FAIL ******
离线k1503
只看该作者 1楼 发表于: 2017-05-03
离线binghaha
只看该作者 2楼 发表于: 2017-05-03
离线binghaha
只看该作者 3楼 发表于: 2017-05-03
离线binghaha
只看该作者 4楼 发表于: 2017-05-04
离线saiyifu
只看该作者 5楼 发表于: 2017-08-31
离线saiyifu
只看该作者 6楼 发表于: 2017-09-01
离线smallwolf
只看该作者 7楼 发表于: 2017-09-01
离线527945545
只看该作者 8楼 发表于: 2017-09-01
离线haaker
只看该作者 9楼 发表于: 2017-10-26
