  • 2609阅读
  • 5回复
[SandForce]2281开卡失败,请教大家 [复制链接]
离线cgh1688
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-06-14
2281开64G镁光CFACB,用的27079号固件,开卡失败了,跟论坛其他朋友的比较好像是下载MFB失败
另外说明一下,我是下载论坛上的文件,FW文件夹里面是空的
因为没下载到5.2.2固件
所以直接把下载的5.2.2的MPT文件夹复制到MPT文件夹里,应该可以直接用吧?
然后生成27079.0的固件文件
附上日志文件:
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Wed, 06/14/2017 @ 18:14:33
                  End Time: Wed, 06/14/2017 @ 18:15:23
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
                  argv[5]: 0
                  argv[6]: 0
                  argv[7]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/0_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/0_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 06/14/2017 18:14:33] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 0
                      argv[6]: 0
[Wed 06/14/2017 18:14:33] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Wed 06/14/2017 18:14:38] - Issuing a discovery command for device: '0:0:0:0'
[Wed 06/14/2017 18:14:43] - Discovery command completed...
[Wed 06/14/2017 18:14:43] - Waiting 5 seconds for the system to settle...
[Wed 06/14/2017 18:14:48] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Wed 06/14/2017 18:14:48] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Wed 06/14/2017 18:14:48] - Successfully received the IDENTIFY data from the drive...
[Wed 06/14/2017 18:14:48] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Wed 06/14/2017 18:15:05] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Wed 06/14/2017 18:15:05] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig Loaded successfully
[Wed 06/14/2017 18:15:05] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 06/14/2017 18:15:05] - B01 Power Management configuration request detected
[Wed 06/14/2017 18:15:05] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
[Wed 06/14/2017 18:15:05] - Extracted Config_ID: 1 (27079) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
[Wed 06/14/2017 18:15:05] - Extracted SerialOutputControl: 0
[Wed 06/14/2017 18:15:05] - Searching for flashware image for configuration 27079
[Wed 06/14/2017 18:15:05] - Manifest found for configuration 27079
[Wed 06/14/2017 18:15:05] - Flashware image extracted: 27079_fw_cl_mlc_Micron_64Gb_MT29F64G08CFACBWP_2Q_2C_1D_PP_R01631_s512.vic
[Wed 06/14/2017 18:15:05] - Searching for manufacturing image for configuration 27079
[Wed 06/14/2017 18:15:05] - Manufacturing image extracted: 27079_mf_mlc_Micron_64Gb_MT29F64G08CFACBWP_2Q_2C_1D_PP_R01631_s512.vic
[Wed 06/14/2017 18:15:05] - Proceeding in ROM mode, download feature 3...
[Wed 06/14/2017 18:15:23] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[   99.877615] ata1.00: failed command: STANDBY IMMEDIATE
[   99.877622] ata1.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[   99.877623]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[   99.877625] ata1.00: status: { DRDY ERR }
[   99.877628] ata1.00: error: { ABRT }
[   99.877635] ata1.00: device reported invalid CHS sector 0
[   99.877757] sd 0:0:0:0: [sda] START_STOP FAILED
[   99.877759] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[   99.877763] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[   99.877767] sd 0:0:0:0: [sda] Add. Sense: No additional sense information
[   99.877861] ata1.00: disabled
[  104.885279] ata1: hard resetting link
[  105.341211] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  105.341581] ata1.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  105.341591] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[  105.344634] ata1.00: configured for UDMA/133
[  105.344652] ata1: EH complete
[  105.344925] scsi 0:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  105.350806] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  105.358975] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  105.358978] sd 0:0:0:0: [sda] 4096-byte physical blocks
[  105.359204] sd 0:0:0:0: [sda] Write Protect is off
[  105.359207] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  105.359231] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  105.360170]  sda: unknown partition table
[  105.363396] sd 0:0:0:0: [sda] Attached SCSI disk
[  138.704224] ata1.00: exception Emask 0x10 SAct 0x0 SErr 0x90000 action 0xe frozen
[  138.704237] ata1: SError: { PHYRdyChg 10B8B }
[  138.704246] ata1.00: failed command: DOWNLOAD MICROCODE
[  138.704263] ata1.00: cmd 92/03:23:00:00:02/00:00:00:00:00/00 tag 0 pio 17920 out
[  138.704267]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x14 (ATA bus error)
[  138.704274] ata1.00: status: { DRDY }
[  138.704296] ata1: hard resetting link
[  139.438727] ata1: SATA link down (SStatus 0 SControl 300)
[  144.438154] ata1: hard resetting link
[  144.754185] ata1: SATA link down (SStatus 0 SControl 300)
[  144.754204] ata1: limiting SATA link speed to 1.5 Gbps
[  149.754080] ata1: hard resetting link
[  150.072999] ata1: SATA link down (SStatus 0 SControl 310)
[  150.073016] ata1.00: disabled
[  150.073036] ata1: EH complete
[  150.073053] ata1.00: detaching (SCSI 0:0:0:0)
[  150.075278] sd 0:0:0:0: [sda] Stopping disk
[  150.075623] sd 0:0:0:0: [sda] START_STOP FAILED
[  150.075626] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[Wed 06/14/2017 18:15:23] - End of Genesis manufacturing log.
[Wed 06/14/2017 18:15:23] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Wed, 06/14/2017 @ 18:14:33 </Start_Time>
        <End_Time> Wed, 06/14/2017 @ 18:15:23 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 0
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/0_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Wed 06/14/2017 18:15:23] - Overall Result for Device: /dev/sg0 ****** FAIL ******
离线binghaha
只看该作者 1楼 发表于: 2017-06-14
离线cgh1688
只看该作者 2楼 发表于: 2017-06-14
回 binghaha 的帖子
离线cgh1688
只看该作者 3楼 发表于: 2017-06-14
回 binghaha 的帖子
离线binghaha
只看该作者 4楼 发表于: 2017-06-15
回 cgh1688 的帖子
离线cgh1688
只看该作者 5楼 发表于: 2017-06-15
回 binghaha 的帖子
