  • 1998阅读
  • 4回复
[SandForce]2281开卡,第2种失败,再次请教大家 [复制链接]
离线cgh1688
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-06-15
昨天开2281的64G镁光CFACB卡在25%处,坛友指教虚焊,用放大镜终于看到一个脚没焊上,没想到又遇到第2次失败
又要请教大家了!
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Thu, 06/15/2017 @ 11:03:21
                  End Time: Thu, 06/15/2017 @ 11:04:04
             OverallResult: FAIL
                  ExitCode: (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
                  argv[5]: 40128115
                  argv[6]: 0
                  argv[7]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/40128115_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/40128115_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 0
                DeviceName: /dev/sg0
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 06/15/2017 11:03:21] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 40128115
                      argv[6]: 0
[Thu 06/15/2017 11:03:21] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Thu 06/15/2017 11:03:26] - Issuing a discovery command for device: '0:0:0:0'
[Thu 06/15/2017 11:03:32] - Discovery command completed...
[Thu 06/15/2017 11:03:32] - Waiting 5 seconds for the system to settle...
[Thu 06/15/2017 11:03:37] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Thu 06/15/2017 11:03:37] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
              Serial No. = 40128115
         World Wide Name = 0
[Thu 06/15/2017 11:03:37] - Successfully received the IDENTIFY data from the drive...
[Thu 06/15/2017 11:03:37] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Thu 06/15/2017 11:03:54] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Thu 06/15/2017 11:03:54] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig Loaded successfully
[Thu 06/15/2017 11:03:54] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 06/15/2017 11:03:54] - B01 Power Management configuration request detected
[Thu 06/15/2017 11:03:54] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
[Thu 06/15/2017 11:03:54] - Extracted Config_ID: 1 (27079) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27079.0.driveconfig
[Thu 06/15/2017 11:03:54] - Extracted SerialOutputControl: 0
[Thu 06/15/2017 11:03:54] - Searching for flashware image for configuration 27079
[Thu 06/15/2017 11:03:54] - Manifest found for configuration 27079
[Thu 06/15/2017 11:03:54] - Flashware image extracted: 27079_fw_cl_mlc_Micron_64Gb_MT29F64G08CFACBWP_2Q_2C_1D_PP_R01631_s512.vic
[Thu 06/15/2017 11:03:54] - Searching for manufacturing image for configuration 27079
[Thu 06/15/2017 11:03:54] - Manufacturing image extracted: 27079_mf_mlc_Micron_64Gb_MT29F64G08CFACBWP_2Q_2C_1D_PP_R01631_s512.vic
[Thu 06/15/2017 11:03:54] - Proceeding in ROM mode, download feature 3...
[Thu 06/15/2017 11:03:54] - Successfully downloaded MFB to the drive...
[Thu 06/15/2017 11:03:54] - Waiting (5 sec) for the drive to settle...
[Thu 06/15/2017 11:03:59] - Successfully received the IDENTIFY data from the drive...
[Thu 06/15/2017 11:03:59] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Thu 06/15/2017 11:03:59] - Successfully enabled SMART capabilities...
[Thu 06/15/2017 11:04:01] - Successfully issued a diagnostic unlock...
[Thu 06/15/2017 11:04:02] - Performing the flash test of block 0 (0x0000)...
[Thu 06/15/2017 11:04:04] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0180 | N7,N9                                      |    FAIL |
| 0    | 0    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 0    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0180 | N7,N9                                      |    FAIL |
| 1    | 0    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 2    | 0x0180 | N7,N9                                      |    FAIL |
| 1    | 0    | 0    | 3    | 0x0180 | N7,N9                                      |    FAIL |
| 1    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 3    | 0x0063 | N1,N3,N5,N6                                | WARNING |
  Total Number of test results: 16
            Number of failures: 4
         Number of Passed with warnings: 12
      No. Passed without warnings: 0
[Thu 06/15/2017 11:04:04] - End of Genesis manufacturing log.
[Thu 06/15/2017 11:04:04] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Thu, 06/15/2017 @ 11:03:21 </Start_Time>
        <End_Time> Thu, 06/15/2017 @ 11:04:04 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 40128115
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/40128115_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 0 </Port_Number>
        <Device_Name> /dev/sg0 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Thu 06/15/2017 11:04:04] - Overall Result for Device: /dev/sg0 ****** FAIL ******
离线john_chuck
只看该作者 1楼 发表于: 2017-06-15
本帖最近打赏记录:共1条打赏M币+3
离线cgh1688
只看该作者 2楼 发表于: 2017-06-15
回 john_chuck 的帖子
离线cgh1688
只看该作者 3楼 发表于: 2017-06-15
回 john_chuck 的帖子
本帖最近打赏记录:共1条打赏M币+3
离线gu_572101993
只看该作者 4楼 发表于: 2017-06-15
回 cgh1688 的帖子
