  • 2408阅读
  • 7回复
[SandForce]金士顿 V300 120G 开卡日志,求助! [复制链接]
离线nymz
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-08-03
Starting command:[/home/Nansen/Downloads/soft/SF_Genesis -PROCESS_SSD 0:0:0:0 "/home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp" "/home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig" 123 456  LOG="/home/Nansen/Downloads/123_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 08/03/2017 14:06:44] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                      argv[4]: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig
                      argv[5]: 123
                      argv[6]: 456
                      argv[7]: LOG=/home/Nansen/Downloads/123_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Thu 08/03/2017 14:06:44] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Thu 08/03/2017 14:06:49] - Issuing a discovery command for device: '0:0:0:0'
[Thu 08/03/2017 14:06:55] - Discovery command completed...
[Thu 08/03/2017 14:06:55] - Waiting 5 seconds for the system to settle...
[Thu 08/03/2017 14:07:00] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Thu 08/03/2017 14:07:00] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig
              Serial No. = 123
         World Wide Name = 456
[Thu 08/03/2017 14:07:00] - Successfully received the IDENTIFY data from the drive...
[Thu 08/03/2017 14:07:00] - Validating Manufacturing Firmware Package: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Thu 08/03/2017 14:07:05] - Successfully opened the package: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Thu 08/03/2017 14:07:05] - File : /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig in processing ...
[Thu 08/03/2017 14:07:05] - file  /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig Loaded successfully
[Thu 08/03/2017 14:07:05] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 08/03/2017 14:07:05] - B01 Power Management configuration request detected
[Thu 08/03/2017 14:07:05] - Successfully extracted *.DriveConfig file: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig
[Thu 08/03/2017 14:07:05] - Extracted Config_ID: 1 (22214) in DriveConfig file: /home/Nansen/Downloads/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22214.123456.edriveconfig
[Thu 08/03/2017 14:07:05] - Extracted SerialOutputControl: 0
[Thu 08/03/2017 14:07:05] - Searching for flashware image for configuration 22214
[Thu 08/03/2017 14:07:05] - Manifest found for configuration 22214
[Thu 08/03/2017 14:07:05] - Flashware image extracted: 22214_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Thu 08/03/2017 14:07:05] - Searching for manufacturing image for configuration 22214
[Thu 08/03/2017 14:07:05] - Manufacturing image extracted: 22214_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Thu 08/03/2017 14:07:05] - Proceeding in ROM mode, download feature 3...
[Thu 08/03/2017 14:07:05] - Successfully downloaded MFB to the drive...
[Thu 08/03/2017 14:07:05] - Waiting (5 sec) for the drive to settle...
[Thu 08/03/2017 14:07:10] - Successfully received the IDENTIFY data from the drive...
[Thu 08/03/2017 14:07:10] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Thu 08/03/2017 14:07:10] - Successfully enabled SMART capabilities...
[Thu 08/03/2017 14:07:12] - Successfully issued a diagnostic unlock...
[Thu 08/03/2017 14:07:14] - Performing the flash test of block 0 (0x0000)...
[Thu 08/03/2017 14:07:15] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 0    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  Total Number of test results: 8
            Number of failures: 8
         Number of Passed with warnings: 0
      No. Passed without warnings: 0
[Thu 08/03/2017 14:07:15] - End of Genesis manufacturing log.
[Thu 08/03/2017 14:07:15] - Exiting...
[Thu 08/03/2017 14:07:15] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 7
上面的Flash TEST有问题,一般是什么情况?
[ 此帖被nymz在2017-08-03 15:19重新编辑 ]
离线527945545
只看该作者 1楼 发表于: 2017-08-03
离线nymz
只看该作者 2楼 发表于: 2017-08-03
离线john_chuck
只看该作者 3楼 发表于: 2017-08-03
离线2017shuma
只看该作者 4楼 发表于: 2017-08-03
离线eboy998
只看该作者 5楼 发表于: 2017-08-04
离线stasiz
只看该作者 6楼 发表于: 2017-08-04
离线if5lp
只看该作者 7楼 发表于: 2017-08-09
