  • 2595阅读
  • 8回复
[SandForce]SF-2281开卡错误日志 [复制链接]
离线taotaohua
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-09-07
有没有大神指点一下呢
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Fri, 09/08/2017 @ 06:56:34
                  End Time: Fri, 09/08/2017 @ 06:57:26
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 1:0:0:0
                  argv[3]: /root/SF2000/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
                  argv[4]: /root/SF2000/mpt/rom/22167.123456.driveconfig
                  argv[5]: 111111111111
                  argv[6]: 1200320045006200
                  argv[7]: LOG=/root/SF2000/mpt/log/111111111111_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/SF2000/mpt/log/111111111111_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 09/08/2017 06:56:34] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 1:0:0:0
[Fri 09/08/2017 06:56:34] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Fri 09/08/2017 06:56:39] - Issuing a discovery command for device: '1:0:0:0'
[Fri 09/08/2017 06:56:44] - Discovery command completed...
[Fri 09/08/2017 06:56:44] - Waiting 5 seconds for the system to settle...
[Fri 09/08/2017 06:56:49] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Fri 09/08/2017 06:56:49] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/SF2000/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
      Configuration File = /root/SF2000/mpt/rom/22167.123456.driveconfig
              Serial No. = 111111111111
         World Wide Name = 1200320045006200
[Fri 09/08/2017 06:56:49] - Successfully received the IDENTIFY data from the drive...
[Fri 09/08/2017 06:56:49] - Validating Manufacturing Firmware Package: /root/SF2000/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
[Fri 09/08/2017 06:56:50] - Successfully opened the package: /root/SF2000/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--123456/FW_SF-2000_B01_MP1-refresh_3-1-9.123456.mfp
[Fri 09/08/2017 06:56:50] - file  /root/SF2000/mpt/rom/22167.123456.driveconfig Loaded successfully
[Fri 09/08/2017 06:56:50] - Warning:  Unable to query diagnostics information to perform power management settings check
[Fri 09/08/2017 06:56:50] - B01 Power Management configuration request detected
[Fri 09/08/2017 06:56:50] - Successfully extracted *.DriveConfig file: /root/SF2000/mpt/rom/22167.123456.driveconfig
[Fri 09/08/2017 06:56:50] - Extracted Config_ID: 1 (22167) in DriveConfig file: /root/SF2000/mpt/rom/22167.123456.driveconfig
[Fri 09/08/2017 06:56:50] - Extracted SerialOutputControl: 0
[Fri 09/08/2017 06:56:50] - Searching for flashware image for configuration 22167
[Fri 09/08/2017 06:56:50] - Manifest found for configuration 22167
[Fri 09/08/2017 06:56:50] - Flashware image extracted: 22167_fw_cl_mlc_Intel_64Gb_JS29F64G08AAME1_2Q_1C_1D_PP_R00689_s512.vic
[Fri 09/08/2017 06:56:50] - Searching for manufacturing image for configuration 22167
[Fri 09/08/2017 06:56:50] - Manufacturing image extracted: 22167_mf_mlc_Intel_64Gb_JS29F64G08AAME1_2Q_1C_1D_PP_R00689_s512.vic
[Fri 09/08/2017 06:56:50] - Proceeding in ROM mode, download feature 3...
[Fri 09/08/2017 06:56:51] - Successfully downloaded MFB to the drive...
[Fri 09/08/2017 06:56:51] - Waiting (5 sec) for the drive to settle...
[Fri 09/08/2017 06:56:56] - Successfully received the IDENTIFY data from the drive...
[Fri 09/08/2017 06:56:56] - Firmware revision reported to be: '319ABBM0'.  This indicates MFB download was successful.
[Fri 09/08/2017 06:56:56] - Successfully enabled SMART capabilities...
[Fri 09/08/2017 06:56:58] - Successfully issued a diagnostic unlock...
[Fri 09/08/2017 06:56:59] - Performing the flash test of block 0 (0x0000)...
[Fri 09/08/2017 06:57:00] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 8
      No. Passed without warnings: 0
[Fri 09/08/2017 06:57:00] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 94608000
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Fri 09/08/2017 06:57:19] - FORMAT command completed...
[Fri 09/08/2017 06:57:19] - Waiting (2 sec) for the drive to settle...
[Fri 09/08/2017 06:57:21] - Setting up the stamp information through CDU command...
[Fri 09/08/2017 06:57:24] - Waiting (2 sec) for the drive to settle...
[Fri 09/08/2017 06:57:26] - Downloading the flashware to the drive... feature 3
[Fri 09/08/2017 06:57:26] - FATAL_ERROR: Could not download flashware to the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[ 1287.988919] sd 1:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 1287.988926] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 1287.989005] sd 1:0:0:0: [sdb] Write Protect is off
[ 1287.989011] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1287.989044] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1287.989708] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1287.989981]  sdb: unknown partition table
[ 1288.000153] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1318.238676] sd 1:0:0:0: [sdb] Stopping disk
[ 1318.238797] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 1318.238810] ata2.00: irq_stat 0x40000001
[ 1318.238819] ata2.00: failed command: STANDBY IMMEDIATE
[ 1318.238839] ata2.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[ 1318.238843]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[ 1318.238852] ata2.00: status: { DRDY ERR }
[ 1318.238859] ata2.00: error: { ABRT }
[ 1318.238883] ata2.00: device reported invalid CHS sector 0
[ 1318.239150] sd 1:0:0:0: [sdb] START_STOP FAILED
[ 1318.239159] sd 1:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1318.239169] sd 1:0:0:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
[ 1318.239182] sd 1:0:0:0: [sdb] Add. Sense: No additional sense information
[ 1318.239303] ata2.00: disabled
[ 1323.241322] ata2: hard resetting link
[ 1323.545777] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1323.545968] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[ 1323.545981] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f68304e0), AE_NOT_FOUND
[ 1323.546792] ata2.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[ 1323.546802] ata2.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 1323.550372] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[ 1323.550383] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f68304e0), AE_NOT_FOUND
[ 1323.552484] ata2.00: configured for UDMA/133
[ 1323.552496] ata2: EH complete
[ 1323.552710] scsi 1:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[ 1323.553176] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1323.553353] sd 1:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 1323.553364] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 1323.553495] sd 1:0:0:0: [sdb] Write Protect is off
[ 1323.553504] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1323.553560] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1323.554051]  sdb: unknown partition table
[ 1323.564337] sd 1:0:0:0: [sdb] Attached SCSI disk
[Fri 09/08/2017 06:57:26] - End of Genesis manufacturing log.
[Fri 09/08/2017 06:57:26] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Fri, 09/08/2017 @ 06:56:34 </Start_Time>
        <End_Time> Fri, 09/08/2017 @ 06:57:26 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 1:0:0:0
        </Input_Parameters>
        <Log_File> /root/SF2000/mpt/log/111111111111_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Fri 09/08/2017 06:57:26] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线527945545
只看该作者 1楼 发表于: 2017-09-08
离线taotaohua
只看该作者 2楼 发表于: 2017-09-08
回 eboy998 的帖子
离线2017shuma
只看该作者 3楼 发表于: 2017-09-08
离线2017shuma
只看该作者 4楼 发表于: 2017-09-08
离线eboy998
只看该作者 5楼 发表于: 2017-09-08
回 2017shuma 的帖子
离线2017shuma
只看该作者 6楼 发表于: 2017-09-08
回 eboy998 的帖子
离线taotaohua
只看该作者 7楼 发表于: 2017-09-09
回 2017shuma 的帖子
离线2017shuma
只看该作者 8楼 发表于: 2017-09-09
回 taotaohua 的帖子
