  • 5295阅读
  • 14回复
求助:新买的朗科U235 主控3s6691量产后0字节了 [复制链接]
离线wwwmirage
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-01-01
主控 sss6691
芯片上的字为  115t051lf
                              hvpf4F5
                               1034
                       115T051LF 3S
详见图片
请问我应该用什么软件量产~~
拆开后在芯片边上还有一组数据不知是什么意思
PBU458M02
2010.09.20
图片上可以看清楚的
Starting Time: 17:17:33
Device 1:0xB3
 MP Version:2.162
 INI_File_Name:
 Random delay 0 msec
 --- Download MP ISP ---
 CE-1, Flash ID=98-D7-94-32-76-55-0C-00
 --> ROOT is not found
 Scan (1,4100)
  Original Defect Block - 1:0:0x0738
  Original Defect Block - 1:0:0x0A6F
  Original Defect Block - 1:0:0x0BA0
  Original Defect Block - 1:0:0x0ECC
  Original Defect Block - 1:0:0x0ECE
  Original Defect Block - 1:0:0x0F3A
  Original Defect Block - 1:0:0x0F3C
  Original Defect Block - 1:0:0x0F3E
  Original Defect Block - 1:0:0x0FC9
  Original Defect Block - 1:0:0x0FCB
  ---> Max Bad of Plane (4,2)
  ---> Max BAD/DIE = 4
 Total good blocks after SCAN: 4090 / 4100, Bad block=10
 ==> 2-Plane mode
 Max. Bad Block Allowed = 183(10)
 Adjust Max LBA = 7823360, 7823296
 MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
 Max BAD of one plane is 4 (45),4100,1,1
 RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
 Boot Block=0x0001,0x0002
 Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
 Special FE Config = 54-0B-00
 Defect Table Block=0x0004
 --- Download ISP Code:D:\SSS6691\ISP_CODE\6691_B3-A_20100224_VA10D00_E13E.BIN---
 --- ISP Code installed.
 Public,Secure,CDROM = 7823296,0,0
 SN=0012F02B82F4F110279F14F9
 === Preformat Done ===
 Low Level Format DONE
 Store INI/ERROR MSG to Block-0x0001:79.
 Total=0,CDROM=0, PublicArea=-128, SecureArea=0
 ### Err: SECURE failed(31).
Ending Time: 17:17:41
关键词: NetacSSS6691
离线zy219251
只看该作者 1楼 发表于: 2011-01-02
本帖最近打赏记录:共1条打赏
离线wwwmirage
只看该作者 2楼 发表于: 2011-01-02
离线wwwmirage
只看该作者 3楼 发表于: 2011-01-02
离线wwwmirage
只看该作者 4楼 发表于: 2011-01-02
回 1楼(zy219251) 的帖子
离线dalinn
只看该作者 5楼 发表于: 2011-01-02
离线c00057
只看该作者 6楼 发表于: 2011-01-02
离线gamester
只看该作者 7楼 发表于: 2011-01-02
本帖最近打赏记录:共1条打赏
离线wwwmirage
只看该作者 8楼 发表于: 2011-01-02
离线wwwmirage
只看该作者 9楼 发表于: 2011-01-02
