  • 5910阅读
  • 18回复
[电教]转贴:上世纪70年代的高科技手工制作 - 计算器 [复制链接]
离线celeron370
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-01-02
原文地址 http://www.nixiebunny.com/malmbergcalc/calc.html
Homebrew Desk Calculator
Back in the good old days of the early 1970s, small desktop calculators were made by several companies.  However, they cost quite a lot of money. The average engineer didn't have that much cash lying around, but still wanted to relieve himself of the burdens of manual mathematical computations.
My twin brother married a lady whose father was just this sort of engineer. He took it upon himself to build a calculator from scratch c. 1972, using one of the then-new single-chip 4-function calculator ICs available at the time.
Back then, "single chip" meant that all the math was done on the chip, not that it could drive a display directly. So a lot of other parts were needed to build such a calculator. He had to design and fabricate several printed circuit boards, using the common method back them of drawing the circuit traces and pads with a Sharpie® pen (sold by Radio Shack at an inflated price as an "etch resist pen") and etching the copper-clad phenolic board using ferric chloride.
The case is made of hardwood, and the keyboard is a hand-lettered paper sheet sandwiched between a couple layers of Plexiglas® and a bunch of little pushbutton switches.
The display is a row of twelve tiny 7-segment vacuum-fluorescent display tubes. These tubes were common in calculators before LEDs had attained reasonable prices of a couple dollars a digit.
Note the wooden card guides to keep all the little PC boards in place.
This gizmo still works great!
本帖最近打赏记录:共7条打赏M币+15
离线gearedbyby
只看该作者 1楼 发表于: 2011-01-02
只看该作者 2楼 发表于: 2011-01-02
离线墨默
只看该作者 3楼 发表于: 2011-01-02
离线桃源客
只看该作者 4楼 发表于: 2011-01-02
离线wei690573821
只看该作者 5楼 发表于: 2011-01-02
离线samhrc
只看该作者 6楼 发表于: 2011-01-02
离线壹陆陆捌
只看该作者 7楼 发表于: 2011-01-02
离线delfman
只看该作者 8楼 发表于: 2011-01-02
离线sjzjiawei
只看该作者 9楼 发表于: 2011-01-02
