  • 6666阅读
  • 3回复
[SandForce]Kingston SSDnow 300V 120GB开卡 [复制链接]
离线haaker
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-10-26
Kingston SSDnow 300V 120GB,不认盘,短接识别sandforce{200026bb}
实物如图
Kingston SSDnow 300V 120GB开卡Kingston SSDnow 300V 120GB开卡
开卡日志文件如下,大家帮分析一下哪里问题
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Thu, 10/26/2017 @ 21:09:20
                  End Time: Thu, 10/26/2017 @ 21:09:48
             OverallResult: FAIL
                  ExitCode: (0x10090009:SF_GENESIS_CDU_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 2:0:0:0
                  argv[3]: /home/dafei/ssd/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /home/dafei/ssd/MPT/33192.123456.driveconfig
                  argv[5]: 120G
                  argv[6]: 512AB23000CDFF0A
                  argv[7]: LOG=/home/dafei/ssd/MPT/120G_dafei_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  argv[8]: -EEPROM=/home/dafei/ssd/MPT/33192.123456.edriveconfig
                  Log File: /home/dafei/ssd/MPT/120G_dafei_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: dafei
           Host IP Address: 192.168.0.227
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 10/26/2017 21:09:20] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 2:0:0:0
                      argv[5]: 120G
[Thu 10/26/2017 21:09:20] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Thu 10/26/2017 21:09:25] - Issuing a discovery command for device: '2:0:0:0'
[Thu 10/26/2017 21:09:31] - Discovery command completed...
[Thu 10/26/2017 21:09:31] - Waiting 5 seconds for the system to settle...
[Thu 10/26/2017 21:09:36] - Device designation string '2:0:0:0' is mapped to node '/dev/sg1'
[Thu 10/26/2017 21:09:36] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/dafei/ssd/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/dafei/ssd/MPT/33192.123456.driveconfig
              Serial No. = 120G
         World Wide Name = 512AB23000CDFF0A
[Thu 10/26/2017 21:09:36] - Successfully received the IDENTIFY data from the drive...
[Thu 10/26/2017 21:09:36] - Validating Manufacturing Firmware Package: /home/dafei/ssd/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 10/26/2017 21:09:39] - Successfully opened the package: /home/dafei/ssd/MPT/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 10/26/2017 21:09:40] - file  /home/dafei/ssd/MPT/33192.123456.driveconfig Loaded successfully
[Thu 10/26/2017 21:09:40] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 10/26/2017 21:09:40] - B02 Power Management configuration request detected
[Thu 10/26/2017 21:09:40] - Successfully extracted *.DriveConfig file: /home/dafei/ssd/MPT/33192.123456.driveconfig
[Thu 10/26/2017 21:09:40] - Extracted Config_ID: 1 (33192) in DriveConfig file: /home/dafei/ssd/MPT/33192.123456.driveconfig
[Thu 10/26/2017 21:09:40] - Extracted SerialOutputControl: 0
[Thu 10/26/2017 21:09:40] - Searching for flashware image for configuration 33192
[Thu 10/26/2017 21:09:40] - Manifest found for configuration 33192
[Thu 10/26/2017 21:09:40] - Flashware image extracted: 33192_fw_cl_mlc_Micron_128Gb_FT16B08UCM1-3B_2Q_1C_1D_PP_R02774_s512.vic
[Thu 10/26/2017 21:09:40] - Searching for manufacturing image for configuration 33192
[Thu 10/26/2017 21:09:40] - Manufacturing image extracted: 33192_mf_mlc_Micron_128Gb_FT16B08UCM1-3B_2Q_1C_1D_PP_R02774_s512.vic
[Thu 10/26/2017 21:09:40] - Proceeding in ROM mode, download feature 3...
[Thu 10/26/2017 21:09:40] - Successfully downloaded MFB to the drive...
[Thu 10/26/2017 21:09:40] - Waiting (5 sec) for the drive to settle...
[Thu 10/26/2017 21:09:45] - Successfully received the IDENTIFY data from the drive...
[Thu 10/26/2017 21:09:45] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Thu 10/26/2017 21:09:45] - Successfully enabled SMART capabilities...
[Thu 10/26/2017 21:09:47] - Successfully issued a diagnostic unlock...
[Thu 10/26/2017 21:09:47] - Starting to update EEPROM from file /home/dafei/ssd/MPT/33192.123456.edriveconfig
[Thu 10/26/2017 21:09:48] - EEPROMUpdate::  ERROR:Sending the EEPROM data to the device Device IOCTL could not be properly executed.
Sense Key: Command aborted
Status:
Extended Error data:
          ATA COMMAND : 0x00B0  (176)
          ATA FEATURE : 0x00D6  (214)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   1 (0x01)    NA
System Trace:
[ 3534.183848] ata3.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[ 3534.186866] ata3.00: configured for UDMA/133
[ 3534.186873] ata3: EH complete
[ 3534.187000] scsi 2:0:0:0: Direct-Access     ATA      SandForce{200026 402A PQ: 0 ANSI: 5
[ 3534.187347] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 3534.194952] sd 2:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 3534.194955] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 3534.194987] sd 2:0:0:0: [sdb] Write Protect is off
[ 3534.194989] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3534.195002] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3534.195830]  sdb: unknown partition table
[ 3534.198808] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 3534.257140] ata4: hard resetting link
[ 3535.261898] ata4: failed to resume link (SControl 30)
[ 3535.273571] ata4: SATA link down (SStatus 4 SControl 30)
[ 3535.273588] ata4: EH complete
[ 4601.564634] sd 2:0:0:0: [sdb] Stopping disk
[ 4601.564781] ata3.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 4601.564787] ata3.00: failed command: STANDBY IMMEDIATE
[ 4601.564794] ata3.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[ 4601.564796]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[ 4601.564799] ata3.00: status: { DRDY ERR }
[ 4601.564801] ata3.00: error: { ABRT }
[ 4601.564811] ata3.00: device reported invalid CHS sector 0
[ 4601.564824] sd 2:0:0:0: [sdb] START_STOP FAILED
[ 4601.564827] sd 2:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 4601.564830] sd 2:0:0:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
[ 4601.564835] sd 2:0:0:0: [sdb] Add. Sense: No additional sense information
[ 4601.564885] ata3.00: disabled
[ 4606.560208] ata3: hard resetting link
[ 4607.015199] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 330)
[ 4607.015442] ata3.00: ATA-8: SandForce{200026BB}, 402ABBR0, max UDMA/133
[ 4607.015447] ata3.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[ 4607.018440] ata3.00: configured for UDMA/133
[ 4607.018447] ata3: EH complete
[ 4607.018580] scsi 2:0:0:0: Direct-Access     ATA      SandForce{200026 402A PQ: 0 ANSI: 5
[ 4607.018827] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 4607.019016] sd 2:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 4607.019019] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 4607.019072] sd 2:0:0:0: [sdb] Write Protect is off
[ 4607.019075] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 4607.019331] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4607.019559]  sdb: unknown partition table
[ 4607.024327] sd 2:0:0:0: [sdb] Attached SCSI disk
[Thu 10/26/2017 21:09:48] - Write sector failed
[Thu 10/26/2017 21:09:48] - EEPROM update failed /home/dafei/ssd/MPT/33192.123456.edriveconfig
[Thu 10/26/2017 21:09:48] - End of Genesis manufacturing log.
[Thu 10/26/2017 21:09:48] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Thu, 10/26/2017 @ 21:09:20 </Start_Time>
        <End_Time> Thu, 10/26/2017 @ 21:09:48 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090009:SF_GENESIS_CDU_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 2:0:0:0
                  argv[5]: 120G
        </Input_Parameters>
        <Log_File> /home/dafei/ssd/MPT/120G_dafei_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> dafei </Hostname>
        <Host_IP_Address> 192.168.0.227 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Thu 10/26/2017 21:09:48] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线wzcgx
只看该作者 1楼 发表于: 2017-10-27
离线wzcgx
只看该作者 2楼 发表于: 2017-10-27
离线haaker
只看该作者 3楼 发表于: 2017-10-27
回 wzcgx 的帖子
