  • 3385阅读
  • 4回复
[SandForce]SF2281开卡不过FATAL_ERROR: Could not get the IDENTIFY data from the drive... [复制链接]
离线hm7577422
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-10-31
昨晚又重新把英特尔520的板子焊了一遍,结果卡27%那里了,高手帮忙看看是哪里的问题,谢谢了
Starting command:[/root/sf2281/soft/SF_Genesis-v1.5.21.20110919-fc14-32bit/SF_Genesis -PROCESS_SSD 0:0:0:0 "/root/sf2281/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/root/sf2281/mpt/27187.0.driveconfig" 12345 67890  LOG="/root/sf2281/mpt/12345_Linux_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Mon 10/31/2016 01:54:49] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /root/sf2281/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /root/sf2281/mpt/27187.0.driveconfig
                      argv[5]: 12345
                      argv[6]: 67890
                      argv[7]: LOG=/root/sf2281/mpt/12345_Linux_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Mon 10/31/2016 01:54:49] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Mon 10/31/2016 01:54:54] - Issuing a discovery command for device: '0:0:0:0'
[Mon 10/31/2016 01:54:59] - Discovery command completed...
[Mon 10/31/2016 01:54:59] - Waiting 5 seconds for the system to settle...
[Mon 10/31/2016 01:55:04] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Mon 10/31/2016 01:55:04] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/sf2281/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/sf2281/mpt/27187.0.driveconfig
              Serial No. = 12345
         World Wide Name = 67890
[Mon 10/31/2016 01:55:04] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -674898193,(D7C5DEEF)
     _Package.Header.HeaderCRC32: -674898193,(D7C5DEEF)
                    OverallCRC32: -517457266,(E1283A8E)
    _Package.Header.OverallCRC32: -517457266,(E1283A8E)
[Mon 10/31/2016 01:55:13] - Successfully opened the package: /root/sf2281/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 10/31/2016 01:55:13] - Successfully extracted *.DriveConfig file: /root/sf2281/mpt/27187.0.driveconfig
[Mon 10/31/2016 01:55:13] - Extracted Config_ID: 1 (27187) in DriveConfig file: /root/sf2281/mpt/27187.0.driveconfig
[Mon 10/31/2016 01:55:13] - Extracted SerialOutputControl: 0
[Mon 10/31/2016 01:55:13] - Successfully extracted Config record: 27187
[Mon 10/31/2016 01:55:13] - Successfully extracted flashware image: 27187_fw_cl_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_S_PP_R00714_s512.vic
[Mon 10/31/2016 01:55:13] - Successfully extracted manufacturing image: 27187_mf_mlc_Micron_64Gb_MT29F128G08CFAAAWP_2Q_2C_1D_S_PP_R00714_s512.vic
[Mon 10/31/2016 01:55:13] - Proceeding in ROM mode, download feature 1...
[Mon 10/31/2016 01:57:44] - Successfully downloaded MFB to the drive...
[Mon 10/31/2016 01:57:44] - Waiting (5 sec) for the drive to settle...
[Mon 10/31/2016 01:57:49] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Mon 10/31/2016 01:57:49] - End of Genesis manufacturing log.
[Mon 10/31/2016 01:57:49] - Exiting...
[Mon 10/31/2016 01:57:49] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 18
离线dulme
只看该作者 1楼 发表于: 2017-10-31
Re:SF2281开卡不过FATAL_ERROR: Could not get the IDENTIFY data from the drive. ..
离线nightday
只看该作者 2楼 发表于: 2017-11-01
离线hm7577422
只看该作者 3楼 发表于: 2017-11-02
离线527945545
只看该作者 4楼 发表于: 2017-11-02
