  • 1811阅读
  • 2回复
[SandForce]SF2281 开卡错误的日志文件 [复制链接]
离线lin3250
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-11-28
<?xml version = "1.0"?>
<Genesis_Log>
<Log_Body>
Overall Summary:
Start Time: Tue, 11/28/2017 @ 23:17:37
End Time: Tue, 11/28/2017 @ 23:18:10
OverallResult: FAIL
ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -PROCESS_SSD
argv[2]: 6:0:0:0
argv[3]: /root/SSD/MPT/FW_PPRO_5_8_2_Release.906190.release--1/FW_PPRO_5_8_2_Release.906190.release.1.mfp
argv[4]: /root/SSD/MPT/FW_PPRO_5_8_2_Release.906190.release--1/Configuration_Files/22327.1.driveconfig
argv[5]: 123
argv[6]: 4
argv[7]: LOG=/root/SSD/123_lin_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
Log File: /root/SSD/123_lin_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
Hostname: lin
Host IP Address: 127.0.0.1
Port Number: 1
DeviceName: /dev/sg1
SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
SF_Core Library Version: v1.7.1.20130612-fc14-32bit
SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
WWN OUI: UNKNOWN
WWN UniqueID: UNKNOWN
Serial No.: UNKNOWN
Model No.: UNKNOWN
Firmware Revision: UNKNOWN
ROM Revision: UNKNOWN
NAND Page Size: UNKNOWN
Number Of Chip Enable: UNKNOWN
Logical Sectors: UNKNOWN
NAND ID: UNKNOWN
Flash Manufacturer: UNKNOWN
Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 11/28/2017 23:17:37] - SF_Genesis has been invoked with the following parameters:
argv[2]: 6:0:0:0
argv[5]: 123
argv[6]: 4
[Tue 11/28/2017 23:17:37] - Instructing the operating system to purge any existing cached data for device: '6:0:0:0'
[Tue 11/28/2017 23:17:42] - Issuing a discovery command for device: '6:0:0:0'
[Tue 11/28/2017 23:17:52] - Discovery command completed...
[Tue 11/28/2017 23:17:52] - Waiting 5 seconds for the system to settle...
[Tue 11/28/2017 23:17:57] - Device designation string '6:0:0:0' is mapped to node '/dev/sg1'
[Tue 11/28/2017 23:17:57] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /root/SSD/MPT/FW_PPRO_5_8_2_Release.906190.release--1/FW_PPRO_5_8_2_Release.906190.release.1.mfp
Configuration File = /root/SSD/MPT/FW_PPRO_5_8_2_Release.906190.release--1/Configuration_Files/22327.1.driveconfig
Serial No. = 123
World Wide Name = 4
[Tue 11/28/2017 23:18:10] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Tue 11/28/2017 23:18:10] - End of Genesis manufacturing log.
[Tue 11/28/2017 23:18:10] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Tue, 11/28/2017 @ 23:17:37 </Start_Time>
<End_Time> Tue, 11/28/2017 @ 23:18:10 </End_Time>
<Overall_Result> FAIL </Overall_Result>
<Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
</Overall_Summary>
<Environment_Settings>
<Input_Parameters>
argv[2]: 6:0:0:0
argv[5]: 123
argv[6]: 4
</Input_Parameters>
<Log_File> /root/SSD/123_lin_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
<Hostname> lin </Hostname>
<Host_IP_Address> 127.0.0.1 </Host_IP_Address>
<Port_Number> 1 </Port_Number>
<Device_Name> /dev/sg1 </Device_Name>
<SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
<SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
</Environment_Settings>
<Post_Processing_Device_Info>
<WWN_OUI> UNKNOWN </WWN_OUI>
<WWN_UniqueID> UNKNOWN </WWN_UniqueID>
<Serial_Number> UNKNOWN </Serial_Number>
<Model_Number> UNKNOWN </Model_Number>
<Firmware_Revision> UNKNOWN </Firmware_Revision>
<ROM_Revision> UNKNOWN </ROM_Revision>
<NAND_Page_Size> UNKNOWN </NAND_Page_Size>
<Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
<Logical_Sectors> UNKNOWN </Logical_Sectors>
<NAND_ID> UNKNOWN </NAND_ID>
<Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
<Flash_Device> UNKNOWN </Flash_Device>
</Post_Processing_Device_Info>
</Genesis_Log>
[Tue 11/28/2017 23:18:10] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线binghaha
只看该作者 1楼 发表于: 2017-11-28
离线perter
只看该作者 2楼 发表于: 2017-11-29
回 binghaha 的帖子
