  • 7471阅读
  • 9回复
[SandForce]2281-vb4已经开卡成功,感谢各位大神的帮助 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-12-02
一直卡在25%这里,不知道是哪里没设置好啊。
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Fri, 12/01/2017 @ 05:07:51
                  End Time: Fri, 12/01/2017 @ 05:08:59
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 5:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/32009.123456.driveconfig
                  argv[5]: PNY07150000701201736
                  argv[6]: 0
                  argv[7]: LOG=/root/mpt/PNY07150000701201736_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/mpt/PNY07150000701201736_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 12/01/2017 05:07:51] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 5:0:0:0
                      argv[6]: 0
[Fri 12/01/2017 05:07:51] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Fri 12/01/2017 05:07:56] - Issuing a discovery command for device: '5:0:0:0'
[Fri 12/01/2017 05:08:01] - Discovery command completed...
[Fri 12/01/2017 05:08:01] - Waiting 5 seconds for the system to settle...
[Fri 12/01/2017 05:08:06] - Device designation string '5:0:0:0' is mapped to node '/dev/sg2'
[Fri 12/01/2017 05:08:06] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/32009.123456.driveconfig
              Serial No. = PNY07150000701201736
         World Wide Name = 0
[Fri 12/01/2017 05:08:07] - Successfully received the IDENTIFY data from the drive...
[Fri 12/01/2017 05:08:07] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 12/01/2017 05:08:07] - Successfully opened the package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 12/01/2017 05:08:07] - file  /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/32009.123456.driveconfig Loaded successfully
[Fri 12/01/2017 05:08:59] - B01 Power Management configuration request detected
[Fri 12/01/2017 05:08:59] - B01 Power Management conforms to hardware version 0x0
[Fri 12/01/2017 05:08:59] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/32009.123456.driveconfig
[Fri 12/01/2017 05:08:59] - Extracted Config_ID: 1 (32009) in DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/32009.123456.driveconfig
[Fri 12/01/2017 05:08:59] - Extracted SerialOutputControl: 0
[Fri 12/01/2017 05:08:59] - Searching for flashware image for configuration 32009
[Fri 12/01/2017 05:08:59] - Manifest found for configuration 32009
[Fri 12/01/2017 05:08:59] - Flashware image extracted: 32009_fw_cl_mlc_MIC_128Gb_MT29F128G08CBCAB_2Q_2C_1D_S_PP_R02222_s512.vic
[Fri 12/01/2017 05:08:59] - Searching for manufacturing image for configuration 32009
[Fri 12/01/2017 05:08:59] - Manufacturing image extracted: 32009_mf_mlc_MIC_128Gb_MT29F128G08CBCAB_2Q_2C_1D_S_PP_R02222_s512.vic
[Fri 12/01/2017 05:08:59] - Proceeding in ROM mode, download feature 3...
[Fri 12/01/2017 05:08:59] - FATAL_ERROR: Could not download MFB to the drive...(0x00100001:SF_SATA_DEVICE_NOT_PRESENT_ERROR)
[Fri 12/01/2017 05:08:59] - End of Genesis manufacturing log.
[Fri 12/01/2017 05:08:59] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Fri, 12/01/2017 @ 05:07:51 </Start_Time>
        <End_Time> Fri, 12/01/2017 @ 05:08:59 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 5:0:0:0
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> /root/mpt/PNY07150000701201736_localhost.localdomain_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Fri 12/01/2017 05:08:59] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[ 此帖被这里随便填在2017-12-03 01:15重新编辑 ]
只看该作者 1楼 发表于: 2017-12-02
离线john_chuck
只看该作者 2楼 发表于: 2017-12-02
离线eboy998
只看该作者 3楼 发表于: 2017-12-02
离线baibo
只看该作者 4楼 发表于: 2017-12-06
只看该作者 5楼 发表于: 2017-12-07
回 baibo 的帖子
离线ctnet
只看该作者 6楼 发表于: 2018-11-26
只看该作者 7楼 发表于: 2018-11-26
回 ctnet 的帖子
离线ctnet
只看该作者 8楼 发表于: 2018-12-02
回 这里随便填 的帖子
离线饭小饭
只看该作者 9楼 发表于: 2019-03-12
