  • 1823阅读
  • 0回复
[综合]sf2281 SLC240G开卡不过去大神来麻烦解下 [复制链接]
离线shooterkb
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-12-24
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-RC-fc14-32bit.tar.zip_FILES/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 1:0:0:0 "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/root/mpt/22536.0.driveconfig" 240 240  LOG="/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/240_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 12/24/2017 20:44:00] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /root/mpt/22536.0.driveconfig
                      argv[5]: 240
                      argv[6]: 240
                      argv[7]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/240_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Sun 12/24/2017 20:44:00] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Sun 12/24/2017 20:44:05] - Issuing a discovery command for device: '1:0:0:0'
[Sun 12/24/2017 20:44:10] - Discovery command completed...
[Sun 12/24/2017 20:44:10] - Waiting 5 seconds for the system to settle...
[Sun 12/24/2017 20:44:15] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Sun 12/24/2017 20:44:15] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/22536.0.driveconfig
              Serial No. = 240
         World Wide Name = 240
[Sun 12/24/2017 20:44:15] - Successfully received the IDENTIFY data from the drive...
[Sun 12/24/2017 20:44:15] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 12/24/2017 20:44:16] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 12/24/2017 20:44:16] - file  /root/mpt/22536.0.driveconfig Loaded successfully
[Sun 12/24/2017 20:44:16] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 12/24/2017 20:44:16] - B01 Power Management configuration request detected
[Sun 12/24/2017 20:44:16] - Successfully extracted *.DriveConfig file: /root/mpt/22536.0.driveconfig
[Sun 12/24/2017 20:44:16] - Extracted Config_ID: 1 (22536) in DriveConfig file: /root/mpt/22536.0.driveconfig
[Sun 12/24/2017 20:44:16] - Extracted SerialOutputControl: 0
[Sun 12/24/2017 20:44:16] - Searching for flashware image for configuration 22536
[Sun 12/24/2017 20:44:16] - Manifest found for configuration 22536
[Sun 12/24/2017 20:44:16] - Flashware image extracted: 22536_fw_cl_slc_Intel_64Gb_PF29F16B16NCNE_2Q_4C_1D_S_PP_R01586_s512.vic
[Sun 12/24/2017 20:44:16] - Searching for manufacturing image for configuration 22536
[Sun 12/24/2017 20:44:16] - Manufacturing image extracted: 22536_mf_slc_Intel_64Gb_PF29F16B16NCNE_2Q_4C_1D_S_PP_R01586_s512.vic
[Sun 12/24/2017 20:44:16] - Proceeding in ROM mode, download feature 3...
[Sun 12/24/2017 20:44:17] - Successfully downloaded MFB to the drive...
[Sun 12/24/2017 20:44:17] - Waiting (5 sec) for the drive to settle...
[Sun 12/24/2017 20:44:22] - Successfully received the IDENTIFY data from the drive...
[Sun 12/24/2017 20:44:22] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Sun 12/24/2017 20:44:22] - Successfully enabled SMART capabilities...
[Sun 12/24/2017 20:44:24] - Successfully issued a diagnostic unlock...
[Sun 12/24/2017 20:44:25] - Performing the flash test of block 0 (0x0000)...
[Sun 12/24/2017 20:44:27] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 32
[Sun 12/24/2017 20:44:27] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 468862128
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 26761 (0x6889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Sun 12/24/2017 20:44:27] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x00B0  (176)
          ATA FEATURE : 0x00D6  (214)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   1 (0x01)    NA
System Trace:
[   18.886362] RPC: Registered udp transport module.
[   18.886364] RPC: Registered tcp transport module.
[   18.886365] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   18.892828] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
[   42.383510] fuse init (API version 7.14)
[   42.392003] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[   42.411567] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[  666.011154] sd 1:0:0:0: [sdb] Stopping disk
[  666.013490] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  666.013494] ata2.00: irq_stat 0x40000001
[  666.013496] ata2.00: failed command: STANDBY IMMEDIATE
[  666.013500] ata2.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[  666.013501]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  666.013503] ata2.00: status: { DRDY ERR }
[  666.013504] ata2.00: error: { ABRT }
[  666.013518] ata2.00: device reported invalid CHS sector 0
[  666.016488] sd 1:0:0:0: [sdb] START_STOP FAILED
[  666.016491] sd 1:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  666.016494] sd 1:0:0:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
[  666.016497] sd 1:0:0:0: [sdb] Add. Sense: No additional sense information
[  666.016626] ata2.00: disabled
[  671.010562] ata2: hard resetting link
[  671.314922] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  671.315068] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[  671.315076] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f683b6d8), AE_NOT_FOUND
[  671.315922] ata2.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  671.315925] ata2.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  671.319474] ACPI Error (psargs-0359): [DSSP] Namespace lookup failure, AE_NOT_FOUND
[  671.319482] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SAT0.SPT1._GTF] (Node f683b6d8), AE_NOT_FOUND
[  671.321606] ata2.00: configured for UDMA/133
[  671.321616] ata2: EH complete
[  671.321757] scsi 1:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  671.325547] sd 1:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  671.325551] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[  671.325605] sd 1:0:0:0: [sdb] Write Protect is off
[  671.325609] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  671.325631] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  671.325675] sd 1:0:0:0: Attached scsi generic sg1 type 0
[  671.334376]  sdb: unknown partition table
[  671.344733] sd 1:0:0:0: [sdb] Attached SCSI disk
[Sun 12/24/2017 20:44:27] - End of Genesis manufacturing log.
[Sun 12/24/2017 20:44:27] - Exiting...
[Sun 12/24/2017 20:44:27] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 8
