Array
  • 2299阅读
  • 3回复
[SandForce]OCZ板 贴 JCNE1 问题 [复制链接]
离线jbzzz
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-01-10
OCZ板子贴了8片29F16B08JCNE1,开卡错误,信息如下:
  1. <?xml version = "1.0"?>
  2. <Genesis_Log>
  3.     <Log_Body>
  4. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  5. Overall Summary:
  6. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  7.                 Start Time: Wed, 01/10/2018 @ 02:27:16
  8.                   End Time: Wed, 01/10/2018 @ 02:28:07
  9.              OverallResult: FAIL
  10.                   ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
  11. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  12. Environment Settings:
  13. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  14.           Input Parameters:
  15.                   argv[1]: -PROCESS_SSD
  16.                   argv[2]: 6:0:0:0
  17.                   argv[3]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  18.                   argv[4]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  19.                   argv[5]: 123
  20.                   argv[6]: 123
  21.                   argv[7]: LOG=/root/Desktop/ssd/LOG/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
  22.                   Log File: /root/Desktop/ssd/LOG/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
  23.                   Hostname: localhost.localdomain
  24.            Host IP Address: 127.0.0.1
  25.                Port Number: 2
  26.                 DeviceName: /dev/sg2
  27.         SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
  28.    SF_Core Library Version: v1.7.1.20130612-fc14-32bit
  29.          SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
  30. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  31. Post Processing Device Information:
  32. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  33.                    WWN OUI: UNKNOWN
  34.               WWN UniqueID: UNKNOWN
  35.                 Serial No.: UNKNOWN
  36.                  Model No.: UNKNOWN
  37.          Firmware Revision: UNKNOWN
  38.               ROM Revision: UNKNOWN
  39.             NAND Page Size: UNKNOWN
  40.      Number Of Chip Enable: UNKNOWN
  41.            Logical Sectors: UNKNOWN
  42.                    NAND ID: UNKNOWN
  43.         Flash Manufacturer: UNKNOWN
  44.               Flash Device: UNKNOWN
  45. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  46. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  47. SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
  48. SF_Core Library: v1.7.1.20130612-fc14-32bit
  49. Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
  50. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  51. [Wed 01/10/2018 02:27:16] - SF_Genesis has been invoked with the following parameters:
  52.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  53.                       argv[1]: -PROCESS_SSD
  54.                       argv[2]: 6:0:0:0
  55.                       argv[3]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  56.                       argv[4]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  57.                       argv[5]: 123
  58.                       argv[6]: 123
  59.                       argv[7]: LOG=/root/Desktop/ssd/LOG/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
  60.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  61. [Wed 01/10/2018 02:27:16] - Instructing the operating system to purge any existing cached data for device: '6:0:0:0'
  62. [Wed 01/10/2018 02:27:21] - Issuing a discovery command for device: '6:0:0:0'
  63. [Wed 01/10/2018 02:27:26] - Discovery command completed...
  64. [Wed 01/10/2018 02:27:26] - Waiting 5 seconds for the system to settle...
  65. [Wed 01/10/2018 02:27:31] - Device designation string '6:0:0:0' is mapped to node '/dev/sg2'
  66. [Wed 01/10/2018 02:27:31] - Proceeding to process SSD device with the following parameters:
  67.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  68.               DeviceName = /dev/sg2
  69.     MFP Package Filename = /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  70.       Configuration File = /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  71.               Serial No. = 123
  72.          World Wide Name = 123
  73.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  74. [Wed 01/10/2018 02:27:32] - Successfully received the IDENTIFY data from the drive...
  75. [Wed 01/10/2018 02:27:32] - Validating Manufacturing Firmware Package: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  76. [Wed 01/10/2018 02:27:53] - Successfully opened the package: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  77. [Wed 01/10/2018 02:27:53] - file  /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig Loaded successfully
  78. [Wed 01/10/2018 02:28:01] - B01 Power Management configuration request detected
  79. [Wed 01/10/2018 02:28:01] - B01 Power Management conforms to hardware version 0x0
  80. [Wed 01/10/2018 02:28:01] - Successfully extracted *.DriveConfig file: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  81. [Wed 01/10/2018 02:28:01] - Extracted Config_ID: 1 (22249) in DriveConfig file: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  82. [Wed 01/10/2018 02:28:01] - Extracted SerialOutputControl: 0
  83. [Wed 01/10/2018 02:28:02] - Searching for flashware image for configuration 22249
  84. [Wed 01/10/2018 02:28:02] - Manifest found for configuration 22249
  85. [Wed 01/10/2018 02:28:02] - Flashware image extracted: 22249_fw_cl_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
  86. [Wed 01/10/2018 02:28:02] - Searching for manufacturing image for configuration 22249
  87. [Wed 01/10/2018 02:28:02] - Manifest found for configuration 22249
  88. [Wed 01/10/2018 02:28:02] - Manufacturing image extracted: 22249_mf_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
  89. [Wed 01/10/2018 02:28:02] - Proceeding in ROM mode, download feature 3...
  90. [Wed 01/10/2018 02:28:02] - Successfully downloaded MFB to the drive...
  91. [Wed 01/10/2018 02:28:02] - Waiting (5 sec) for the drive to settle...
  92. [Wed 01/10/2018 02:28:07] - Successfully received the IDENTIFY data from the drive...
  93. [Wed 01/10/2018 02:28:07] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '20DABBR0', indicating MFB download has failed.
  94. [Wed 01/10/2018 02:28:07] - End of Genesis manufacturing log.
  95. [Wed 01/10/2018 02:28:07] - Exiting...
  96.     </Log_Body>
  97.     <Overall_Summary>
  98.         <Start_Time> Wed, 01/10/2018 @ 02:27:16 </Start_Time>
  99.         <End_Time> Wed, 01/10/2018 @ 02:28:07 </End_Time>
  100.         <Overall_Result> FAIL </Overall_Result>
  101.         <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
  102.     </Overall_Summary>
  103.     <Environment_Settings>
  104.         <Input_Parameters>
  105.                   argv[1]: -PROCESS_SSD
  106.                   argv[2]: 6:0:0:0
  107.                   argv[3]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/FW_PPRO_6_0_A_Release.1134440.release.180.mfp
  108.                   argv[4]: /root/Desktop/ssd/60A/FW_PPRO_6_0_A_Release.1134440.release--180/Configuration_Files/22249.180.driveconfig
  109.                   argv[5]: 123
  110.                   argv[6]: 123
  111.                   argv[7]: LOG=/root/Desktop/ssd/LOG/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
  112.         </Input_Parameters>
  113.         <Log_File> /root/Desktop/ssd/LOG/123_localhost.localdomain_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
  114.         <Hostname> localhost.localdomain </Hostname>
  115.         <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
  116.         <Port_Number> 2 </Port_Number>
  117.         <Device_Name> /dev/sg2 </Device_Name>
  118.         <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
  119.         <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
  120.         <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
  121.     </Environment_Settings>
  122.     <Post_Processing_Device_Info>
  123.         <WWN_OUI> UNKNOWN </WWN_OUI>
  124.         <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
  125.         <Serial_Number> UNKNOWN </Serial_Number>
  126.         <Model_Number> UNKNOWN </Model_Number>
  127.         <Firmware_Revision> UNKNOWN </Firmware_Revision>
  128.         <ROM_Revision> UNKNOWN </ROM_Revision>
  129.         <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
  130.         <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
  131.         <Logical_Sectors> UNKNOWN </Logical_Sectors>
  132.         <NAND_ID> UNKNOWN </NAND_ID>
  133.         <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
  134.         <Flash_Device> UNKNOWN </Flash_Device>
  135.     </Post_Processing_Device_Info>
  136. </Genesis_Log>
  137. [Wed 01/10/2018 02:28:07] - Overall Result for Device: /dev/sg2 ****** FAIL ******
请教这是什么原因,谢谢
只看该作者 1楼 发表于: 2018-01-10
离线perter
只看该作者 2楼 发表于: 2018-01-10
离线huakun888
只看该作者 3楼 发表于: 2018-01-10
Array
