  • 2955阅读
  • 5回复
[SandForce]2281上东芝颗粒又遇到新问题 请大神帮忙看看怎么解决 谢谢 [复制链接]
离线cy2cool
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-01-30
此悬赏帖已过期
最佳答案:20 M币,热心助人剩余点数: 3 M币。
                 <?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 01/30/2018 @ 03:12:15
                  End Time: Tue, 01/30/2018 @ 03:14:15
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 2:0:0:0
                  argv[3]: /home/linux/Desktop/mpt/FW_PPRO_E_A_I_Release.936211.release--123456/FW_PPRO_E_A_I_Release.936211.release.123456.mfp
                  argv[4]: /home/linux/Desktop/25030.123456.driveconfig
                  argv[5]: 123
                  argv[6]: 321
                  argv[7]: LOG=/home/linux/Desktop/123_linux-pc_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /home/linux/Desktop/123_linux-pc_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: linux-pc
           Host IP Address: 127.0.1.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 4.4.0-2-deepin-686-pae #1 SMP Deepin 4.4.6-4 (2016-07-01) i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 01/30/2018 03:12:15] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 2:0:0:0
                      argv[5]: 123
                      argv[6]: 321
[Tue 01/30/2018 03:12:15] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Tue 01/30/2018 03:12:20] - Issuing a discovery command for device: '2:0:0:0'
[Tue 01/30/2018 03:12:25] - Discovery command completed...
[Tue 01/30/2018 03:12:25] - Waiting 5 seconds for the system to settle...
[Tue 01/30/2018 03:12:30] - Device designation string '2:0:0:0' is mapped to node '/dev/sg1'
[Tue 01/30/2018 03:12:30] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/linux/Desktop/mpt/FW_PPRO_E_A_I_Release.936211.release--123456/FW_PPRO_E_A_I_Release.936211.release.123456.mfp
      Configuration File = /home/linux/Desktop/25030.123456.driveconfig
              Serial No. = 123
         World Wide Name = 321
[Tue 01/30/2018 03:12:30] - Successfully received the IDENTIFY data from the drive...
[Tue 01/30/2018 03:12:30] - Validating Manufacturing Firmware Package: /home/linux/Desktop/mpt/FW_PPRO_E_A_I_Release.936211.release--123456/FW_PPRO_E_A_I_Release.936211.release.123456.mfp
[Tue 01/30/2018 03:12:31] - Successfully opened the package: /home/linux/Desktop/mpt/FW_PPRO_E_A_I_Release.936211.release--123456/FW_PPRO_E_A_I_Release.936211.release.123456.mfp
[Tue 01/30/2018 03:12:31] - file  /home/linux/Desktop/25030.123456.driveconfig Loaded successfully
[Tue 01/30/2018 03:12:31] - Warning:  Unable to query diagnostics information to perform power management settings check
[Tue 01/30/2018 03:12:31] - B01 Power Management configuration request detected
[Tue 01/30/2018 03:12:31] - Successfully extracted *.DriveConfig file: /home/linux/Desktop/25030.123456.driveconfig
[Tue 01/30/2018 03:12:31] - Extracted Config_ID: 1 (25030) in DriveConfig file: /home/linux/Desktop/25030.123456.driveconfig
[Tue 01/30/2018 03:12:31] - Extracted SerialOutputControl: 0
[Tue 01/30/2018 03:12:31] - Searching for flashware image for configuration 25030
[Tue 01/30/2018 03:12:31] - Manifest found for configuration 25030
[Tue 01/30/2018 03:12:31] - Flashware image extracted: 25030_fw_cl_emlc_Toshiba_32Gb_TH58TAG8E2FBA89_2Q_2C_2D_PP_R00035_s512.vic
[Tue 01/30/2018 03:12:31] - Searching for manufacturing image for configuration 25030
[Tue 01/30/2018 03:12:31] - Manufacturing image extracted: 25030_mf_emlc_Toshiba_32Gb_TH58TAG8E2FBA89_2Q_2C_2D_PP_R00035_s512.vic
[Tue 01/30/2018 03:12:31] - Proceeding in ROM mode, download feature 3...
[Tue 01/30/2018 03:12:31] - Successfully downloaded MFB to the drive...
[Tue 01/30/2018 03:12:31] - Waiting (5 sec) for the drive to settle...
[Tue 01/30/2018 03:12:36] - Successfully received the IDENTIFY data from the drive...
[Tue 01/30/2018 03:12:36] - Firmware revision reported to be: 'EAIABBM0'.  This indicates MFB download was successful.
[Tue 01/30/2018 03:12:36] - Successfully enabled SMART capabilities...
[Tue 01/30/2018 03:12:38] - Successfully issued a diagnostic unlock...
[Tue 01/30/2018 03:12:39] - Performing the flash test of block 0 (0x0000)...
[Tue 01/30/2018 03:12:42] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 2
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 1    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 1
      No. Passed without warnings: 31
[Tue 01/30/2018 03:12:42] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 195371568
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 56984 (0xDE98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Tue 01/30/2018 03:14:07] - FORMAT command completed...
[Tue 01/30/2018 03:14:07] - Waiting (2 sec) for the drive to settle...
[Tue 01/30/2018 03:14:09] - Setting up the stamp information through CDU command...
[Tue 01/30/2018 03:14:13] - Waiting (2 sec) for the drive to settle...
[Tue 01/30/2018 03:14:15] - Downloading the flashware to the drive... feature 3
[Tue 01/30/2018 03:14:15] - FATAL_ERROR: Could not download flashware to the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:   5 (0x05)    FAIL
  2 -        Not Ready:  33 (0x21)    FAIL
  3 -     Medium Error:   4 (0x04)    FAIL
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[11500.358649] ata3.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[11500.358655] ata3.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[11500.364306] ata3.00: configured for UDMA/133
[11500.364320] ata3: EH complete
[11500.364669] scsi 2:0:0:0: Direct-Access     ATA      SandForce{200026 BBR0 PQ: 0 ANSI: 5
[11500.365093] sd 2:0:0:0: Attached scsi generic sg1 type 0
[11500.365136] sd 2:0:0:0: [sdb] 64 512-byte logical blocks: (32.8 kB/32.0 KiB)
[11500.365145] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[11500.365273] sd 2:0:0:0: [sdb] Write Protect is off
[11500.365278] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[11500.365313] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[11500.384630] sd 2:0:0:0: [sdb] Attached SCSI disk
[11849.691392] ata3: exception Emask 0x10 SAct 0x0 SErr 0x90200 action 0xe frozen
[11849.691398] ata3: irq_stat 0x00400000, PHY RDY changed
[11849.691402] ata3: SError: { Persist PHYRdyChg 10B8B }
[11849.691408] ata3: hard resetting link
[11850.413540] ata3: SATA link down (SStatus 0 SControl 300)
[11855.412865] ata3: hard resetting link
[11855.732828] ata3: SATA link down (SStatus 0 SControl 300)
[11855.732842] ata3: limiting SATA link speed to 1.5 Gbps
[11860.732159] ata3: hard resetting link
[11861.052120] ata3: SATA link down (SStatus 0 SControl 310)
[11861.052133] ata3.00: disabled
[11861.052152] ata3: EH complete
[11861.052165] ata3.00: detaching (SCSI 2:0:0:0)
[11861.052769] sd 2:0:0:0: [sdb] Stopping disk
[11861.052822] sd 2:0:0:0: [sdb] Start/Stop Unit failed: Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[11873.333833] ata3: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[11873.333840] ata3: irq_stat 0x00000040, connection status changed
[11873.333844] ata3: SError: { CommWake 10B8B DevExch }
[11873.333851] ata3: hard resetting link
[11874.226355] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[11874.227418] ata3.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[11874.227425] ata3.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[11874.233076] ata3.00: configured for UDMA/133
[11874.233090] ata3: EH complete
[11874.233341] scsi 2:0:0:0: Direct-Access     ATA      SandForce{200026 BBR0 PQ: 0 ANSI: 5
[11874.233656] sd 2:0:0:0: [sdb] 64 512-byte logical blocks: (32.8 kB/32.0 KiB)
[11874.233661] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[11874.233708] sd 2:0:0:0: Attached scsi generic sg1 type 0
[11874.233734] sd 2:0:0:0: [sdb] Write Protect is off
[11874.233740] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[11874.233772] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[11874.253493] sd 2:0:0:0: [sdb] Attached SCSI disk
[Tue 01/30/2018 03:14:15] - End of Genesis manufacturing log.
[Tue 01/30/2018 03:14:15] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Tue, 01/30/2018 @ 03:12:15 </Start_Time>
        <End_Time> Tue, 01/30/2018 @ 03:14:15 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 2:0:0:0
                  argv[5]: 123
                  argv[6]: 321
        </Input_Parameters>
        <Log_File> /home/linux/Desktop/123_linux-pc_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> linux-pc </Hostname>
        <Host_IP_Address> 127.0.1.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 4.4.0-2-deepin-686-pae #1 SMP Deepin 4.4.6-4 (2016-07-01) i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Tue 01/30/2018 03:14:15] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线perter
只看该作者 1楼 发表于: 2018-01-30
热心助人奖励:+1 M币
只看该作者 2楼 发表于: 2018-01-30
热心助人奖励:+1 M币
离线cy2cool
只看该作者 3楼 发表于: 2018-01-30
离线perter
只看该作者 4楼 发表于: 2018-01-30
回 cy2cool 的帖子
只看该作者 5楼 发表于: 2018-03-05
