  • 8726阅读
  • 30回复
[SandForce]SF2281看开卡遇到点问题 [复制链接]
离线yanli931016
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-03-30
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Fri, 03/30/2018 @ 14:52:32
                  End Time: Fri, 03/30/2018 @ 14:53:07
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 0:0:0:0
                  argv[3]: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                  argv[4]: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22761.123456.MISAKA.driveconfig
                  argv[5]: 0
                  argv[6]: 0
                  argv[7]: log=/home/asrock/SF/mpt/123.log
                  Log File: SF_Genesis_Main_Log__Fri_03.30.2018_14.52.32.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 3
                DeviceName: /dev/sg3
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 4.13.9-300.fc27.x86_64 #1 SMP Mon Oct 23 13:41:58 UTC 2017 x86_64
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 03/30/2018 14:52:32] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 0:0:0:0
                      argv[5]: 0
                      argv[6]: 0
[Fri 03/30/2018 14:52:32] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Fri 03/30/2018 14:52:37] - Issuing a discovery command for device: '0:0:0:0'
[Fri 03/30/2018 14:52:42] - Discovery command completed...
[Fri 03/30/2018 14:52:42] - Waiting 5 seconds for the system to settle...
[Fri 03/30/2018 14:52:47] - Device designation string '0:0:0:0' is mapped to node '/dev/sg3'
[Fri 03/30/2018 14:52:47] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg3
    MFP Package Filename = /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22761.123456.MISAKA.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Fri 03/30/2018 14:52:47] - Successfully received the IDENTIFY data from the drive...
[Fri 03/30/2018 14:52:47] - Validating Manufacturing Firmware Package: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Fri 03/30/2018 14:52:47] - Successfully opened the package: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Fri 03/30/2018 14:52:47] - file  /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22761.123456.MISAKA.driveconfig Loaded successfully
[Fri 03/30/2018 14:53:02] - B01 Power Management configuration request detected
[Fri 03/30/2018 14:53:02] - B01 Power Management conforms to hardware version 0x0
[Fri 03/30/2018 14:53:02] - Successfully extracted *.DriveConfig file: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22761.123456.MISAKA.driveconfig
[Fri 03/30/2018 14:53:02] - Extracted Config_ID: 1 (22761) in DriveConfig file: /home/asrock/SF/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22761.123456.MISAKA.driveconfig
[Fri 03/30/2018 14:53:02] - Extracted SerialOutputControl: 0
[Fri 03/30/2018 14:53:02] - Searching for flashware image for configuration 22761
[Fri 03/30/2018 14:53:02] - Manifest found for configuration 22761
[Fri 03/30/2018 14:53:02] - Flashware image extracted: 22761_fw_cl_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Fri 03/30/2018 14:53:02] - Searching for manufacturing image for configuration 22761
[Fri 03/30/2018 14:53:02] - Manufacturing image extracted: 22761_mf_ccmlc_Intel_64Gb_JS29F16B08CCME2_2Q_2C_1D_PP_R00426_s512.vic
[Fri 03/30/2018 14:53:02] - Proceeding in non-ROM mode, Download feature 3...
[Fri 03/30/2018 14:53:02] - Successfully downloaded MFB to the drive...
[Fri 03/30/2018 14:53:02] - Waiting (5 sec) for the drive to settle...
[Fri 03/30/2018 14:53:07] - Successfully received the IDENTIFY data from the drive...
[Fri 03/30/2018 14:53:07] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: ' ]     ^', indicating MFB download has failed.
[Fri 03/30/2018 14:53:07] - End of Genesis manufacturing log.
[Fri 03/30/2018 14:53:07] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Fri, 03/30/2018 @ 14:52:32 </Start_Time>
        <End_Time> Fri, 03/30/2018 @ 14:53:07 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 0:0:0:0
                  argv[5]: 0
                  argv[6]: 0
        </Input_Parameters>
        <Log_File> SF_Genesis_Main_Log__Fri_03.30.2018_14.52.32.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 3 </Port_Number>
        <Device_Name> /dev/sg3 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 4.13.9-300.fc27.x86_64 #1 SMP Mon Oct 23 13:41:58 UTC 2017 x86_64 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Fri 03/30/2018 14:53:07] - Overall Result for Device: /dev/sg3 ****** FAIL ******
log贴出来大家看看 intel520的板子 8贴CCME2
离线yanli931016
只看该作者 1楼 发表于: 2018-03-30
只看该作者 2楼 发表于: 2018-03-30
离线john_chuck
只看该作者 3楼 发表于: 2018-03-30
离线sjzjiawei
只看该作者 4楼 发表于: 2018-03-30
离线2017shuma
只看该作者 5楼 发表于: 2018-03-30
离线yanli931016
只看该作者 6楼 发表于: 2018-03-30
回 john_chuck 的帖子
离线yanli931016
只看该作者 7楼 发表于: 2018-03-30
回 sjzjiawei 的帖子
离线yanli931016
只看该作者 8楼 发表于: 2018-03-30
回 2017shuma 的帖子
离线yanli931016
只看该作者 9楼 发表于: 2018-03-30
回 傻xx小魔法师 的帖子
