  • 1741阅读
  • 6回复
[SandForce]SF2281开卡求助 [复制链接]
离线moshuai2013
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-13
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 0:0:0:0 "/root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/FW_PPRO_E_A_I_Release.936211.release.0.mfp" "/root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig" 0 0  LOG="/root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/0_0_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sat 04/14/2018 04:25:06] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/FW_PPRO_E_A_I_Release.936211.release.0.mfp
                      argv[4]: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig
                      argv[5]: 0
                      argv[6]: 0
                      argv[7]: LOG=/root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/0_0_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Sat 04/14/2018 04:25:06] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sat 04/14/2018 04:25:11] - Issuing a discovery command for device: '0:0:0:0'
[Sat 04/14/2018 04:25:16] - Discovery command completed...
[Sat 04/14/2018 04:25:16] - Waiting 5 seconds for the system to settle...
[Sat 04/14/2018 04:25:21] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sat 04/14/2018 04:25:21] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/FW_PPRO_E_A_I_Release.936211.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Sat 04/14/2018 04:25:21] - Successfully received the IDENTIFY data from the drive...
[Sat 04/14/2018 04:25:21] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/FW_PPRO_E_A_I_Release.936211.release.0.mfp
[Sat 04/14/2018 04:25:23] - Successfully opened the package: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/FW_PPRO_E_A_I_Release.936211.release.0.mfp
[Sat 04/14/2018 04:25:23] - file  /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig Loaded successfully
[Sat 04/14/2018 04:25:23] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sat 04/14/2018 04:25:23] - B01 Power Management configuration request detected
[Sat 04/14/2018 04:25:23] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig
[Sat 04/14/2018 04:25:23] - Extracted Config_ID: 1 (21114) in DriveConfig file: /root/mpt/FW_PPRO_E_A_I_Release.936211.release--0/21114.12345600.driveconfig
[Sat 04/14/2018 04:25:23] - Extracted SerialOutputControl: 0
[Sat 04/14/2018 04:25:23] - FATAL_ERROR: Could not extract configuration record: 21114 from package
[Sat 04/14/2018 04:25:23] - End of Genesis manufacturing log.
[Sat 04/14/2018 04:25:23] - Exiting...
[Sat 04/14/2018 04:25:23] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 2
离线moshuai2013
只看该作者 1楼 发表于: 2018-04-13
离线sjzjiawei
只看该作者 2楼 发表于: 2018-04-13
离线527945545
只看该作者 3楼 发表于: 2018-04-13
离线99173546
只看该作者 4楼 发表于: 2018-05-29
只看该作者 5楼 发表于: 2018-06-09
离线moshuai2013
只看该作者 6楼 发表于: 2018-06-09
回 新奇小子007 的帖子
