  • 1594阅读
  • 1回复
[其他]麻烦高手帮我看看这个开卡是哪里出问题了,非常感谢! [复制链接]
离线zhlaxl
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-17
[zhlaxl@zhlaxl-PC ~]$ su
密码:
[root@zhlaxl-PC zhlaxl]# cd SOFT
[root@zhlaxl-PC SOFT]# ./SF_Genesis -PROCESS_SSD 4:0:0:0 /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis -PROCESS_SSD 4:0:0:0 /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335.123456.driveconfig 12345 www_123  log=/home/zhlaxl/123.log123456.driveconfig log=/home/zhlaxl/123.log
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Tue 04/17/2018 22:59:58] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 4:0:0:0
                      argv[3]: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                      argv[4]: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis
                      argv[5]: -PROCESS_SSD
                      argv[6]: 4:0:0:0
                      argv[7]: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                      argv[8]: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335.123456.driveconfig
                      argv[9]: 12345
                      argv[10]: www_123
                      argv[11]: log=/home/zhlaxl/123.log123456.driveconfig
                      argv[12]: log=/home/zhlaxl/123.log
[Tue 04/17/2018 22:59:58] - Instructing the operating system to purge any existing cached data for device: '4:0:0:0'
[Tue 04/17/2018 23:00:03] - Issuing a discovery command for device: '4:0:0:0'
[Tue 04/17/2018 23:00:09] - Discovery command completed...
[Tue 04/17/2018 23:00:09] - Waiting 5 seconds for the system to settle...
[Tue 04/17/2018 23:00:14] - Device designation string '4:0:0:0' is mapped to node '/dev/sg1'
[Tue 04/17/2018 23:00:14] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis
              Serial No. = -PROCESS_SSD
         World Wide Name = 4:0:0:0
[Tue 04/17/2018 23:00:14] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32:  106216300,(0654BB6C)
     _Package.Header.HeaderCRC32:  106216300,(0654BB6C)
                    OverallCRC32: -1126163474,(BCE01BEE)
    _Package.Header.OverallCRC32: -1126163474,(BCE01BEE)
[Tue 04/17/2018 23:00:28] - Successfully opened the package: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:0.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:1.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:2.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:3.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:4.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:5.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:6.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:7.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:8.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:9.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:10.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:11.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:12.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:13.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:14.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:15.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:16.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:17.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:18.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:19.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:20.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:21.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:22.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:23.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:24.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:25.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:26.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:27.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:28.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:29.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:30.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:31.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:32.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:33.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:34.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:35.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:36.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:37.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:38.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:39.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:40.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:41.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:42.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:43.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:44.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:45.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:46.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:47.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:48.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:49.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:50.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:51.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:52.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:53.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:54.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:55.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:56.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:57.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:58.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:59.000000)
Could not open the file </home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis>....Retrying in 1 second...(Wait:60.000000)
[Tue 04/17/2018 23:01:29] - FATAL_ERROR: Could not access the DriveConfig file: /home/zhlaxl/MPT/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/22335../SF_Genesis (Message: SF_ConfigManager::OpenExistingConfigFile: 183 : ERROR: Can not create the class.  Invalid file specified.)
[Tue 04/17/2018 23:01:29] - End of Genesis manufacturing log.
[Tue 04/17/2018 23:01:29] - Exiting...
[Tue 04/17/2018 23:01:29] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线zhlaxl
只看该作者 1楼 发表于: 2018-04-18
