  • 32601阅读
  • 151回复
[SandForce]求助,SF2281开卡问题 [复制链接]
离线moshuai2013
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-19
回复本帖可获得3M币奖励!
每人最多可获奖1次,奖池剩余0M币 (中奖几率100%)
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 0:0:0:0 "/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp" "/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig" 1 1  LOG="/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/1_0_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 04/22/2018 09:57:08] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
                      argv[4]: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig
                      argv[5]: 1
                      argv[6]: 1
                      argv[7]: LOG=/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/1_0_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Sun 04/22/2018 09:57:08] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Sun 04/22/2018 09:57:13] - Issuing a discovery command for device: '0:0:0:0'
[Sun 04/22/2018 09:57:19] - Discovery command completed...
[Sun 04/22/2018 09:57:19] - Waiting 5 seconds for the system to settle...
[Sun 04/22/2018 09:57:24] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Sun 04/22/2018 09:57:24] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
      Configuration File = /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig
              Serial No. = 1
         World Wide Name = 1
[Sun 04/22/2018 09:57:24] - Successfully received the IDENTIFY data from the drive...
[Sun 04/22/2018 09:57:24] - Validating Manufacturing Firmware Package: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
[Sun 04/22/2018 09:57:32] - Successfully opened the package: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
[Sun 04/22/2018 09:57:32] - file  /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig Loaded successfully
[Sun 04/22/2018 09:57:32] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 04/22/2018 09:57:32] - B01 Power Management configuration request detected
[Sun 04/22/2018 09:57:32] - Successfully extracted *.DriveConfig file: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig
[Sun 04/22/2018 09:57:32] - Extracted Config_ID: 1 (21114) in DriveConfig file: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.1.driveconfig
[Sun 04/22/2018 09:57:32] - Extracted SerialOutputControl: 0
[Sun 04/22/2018 09:57:32] - Searching for flashware image for configuration 21114
[Sun 04/22/2018 09:57:32] - Manifest found for configuration 21114
[Sun 04/22/2018 09:57:32] - Flashware image extracted: 21114_fw_cl_mlc_Intel_64Gb_JS29F16B08CAME1_1Q_2C_1D_PP_R00691_s512.vic
[Sun 04/22/2018 09:57:32] - Searching for manufacturing image for configuration 21114
[Sun 04/22/2018 09:57:32] - Manufacturing image extracted: 21114_mf_mlc_Intel_64Gb_JS29F16B08CAME1_1Q_2C_1D_PP_R00691_s512.vic
[Sun 04/22/2018 09:57:32] - Proceeding in ROM mode, download feature 3...
[Sun 04/22/2018 09:57:32] - Successfully downloaded MFB to the drive...
[Sun 04/22/2018 09:57:32] - Waiting (5 sec) for the drive to settle...
[Sun 04/22/2018 09:57:37] - Successfully received the IDENTIFY data from the drive...
[Sun 04/22/2018 09:57:37] - Firmware revision reported to be: '319ABBM0'.  This indicates MFB download was successful.
[Sun 04/22/2018 09:57:37] - Successfully enabled SMART capabilities...
[Sun 04/22/2018 09:57:39] - Successfully issued a diagnostic unlock...
[Sun 04/22/2018 09:57:40] - Performing the flash test of block 0 (0x0000)...
[Sun 04/22/2018 09:57:42] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0364 | N5,N6,N8,N10                               |    FAIL |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0364 | N5,N6,N8,N10                               |    FAIL |
  Total Number of test results: 8
            Number of failures: 2
         Number of Passed with warnings: 6
      No. Passed without warnings: 0
[Sun 04/22/2018 09:57:42] - End of Genesis manufacturing log.
[Sun 04/22/2018 09:57:42] - Exiting...
[Sun 04/22/2018 09:57:42] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 7
英特尔SF2281的板子和JS29F16B08CAM1芯片
[ 此帖被moshuai2013在2018-04-22 11:34重新编辑 ]
离线perter
只看该作者 1楼 发表于: 2018-04-19
回帖奖励+ 3
离线xuesajiutian
只看该作者 2楼 发表于: 2018-04-19
回帖奖励+ 3
离线moshuai2013
只看该作者 3楼 发表于: 2018-04-19
回 xuesajiutian 的帖子
离线darakiss
只看该作者 4楼 发表于: 2018-04-19
回帖奖励+ 3
离线527945545
只看该作者 5楼 发表于: 2018-04-20
回帖奖励+ 3
离线岳母三千
只看该作者 6楼 发表于: 2018-04-20
回帖奖励+ 3
离线kenvpn
只看该作者 7楼 发表于: 2018-04-20
回帖奖励+ 3
离线omeric4c
只看该作者 8楼 发表于: 2018-04-20
回帖奖励+ 3
只看该作者 9楼 发表于: 2018-04-20
回帖奖励+ 3
