  • 3611阅读
  • 6回复
KINGSTON RED 8GB Data Traveler 101 G2 [复制链接]
离线darkmancuban
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-03-18
English
Dear colleagues, a few days ago I bought a 8 GB Kingston Data Traveler 101 G2 red, or of bringing the metal support external memory is genuine but has no problem but I would like to know the tool for repair, Genius chip tells me it is a Phison UP13-19 but none of the tools I have here the identification, and if you can identify me with this error ("Get device error "), I've also used the Get Info faith Phison v 3.2.9.2 and this shows me the tool to be used is the MPV 48.30.30 but this does not identify the memory. I clarify again, the memory is in perfect condition and working well, but it would be nice to have the repair tool on hand in case any problems arise, it is also because many such entan going to Cuba recently and do not want to be without als tools at the moment do not send the pictures because the memory has a friend using it, but then I'll post all this that I mentioned earlier. If any of you have already tested the tool and can share, I thank you very much.
Greetings from Cuba
Traditional Chinese:
親愛的同事們稱,前幾天我買了一個 8 GB的金士頓 G2的數據旅行者101紅色,或使金屬支持外部存儲器是真實的,但沒有問題,但我想知道的工具的維修,
天才芯片告訴我這是一個群聯 UP13 - 19,但沒有這些工具我這裡有認同,如果你能找到我,這個錯誤(“獲得設備錯誤”),我還使用了獲取信息的信仰群聯 v 3.2.9.2這說明我要使用的工具是MPV車型 48.30.30但是這並不能識別的內存。本人再次澄清,內存是在完善的條件和運作良好,但它會是不錯的修復工具在手,以防出現任何問題,這也是因為很多這樣的糾纏將古巴最近不想沒有 ALS的工具此刻不發送照片,因為內存有個朋友使用它,但後來我會後所有這一切,我前面提到的。如果有任何您已經測試工具,可以分享,我非常感謝你。
來自古巴的問候
Yunis Maikel
本帖最近打赏记录:共1条打赏
离线wan06
只看该作者 1楼 发表于: 2011-03-19
本帖最近打赏记录:共1条打赏
离线internelp
只看该作者 2楼 发表于: 2011-03-19
离线czwhehehe
只看该作者 3楼 发表于: 2011-03-19
离线darkmancuban
只看该作者 4楼 发表于: 2011-03-24
离线darkmancuban
只看该作者 5楼 发表于: 2011-05-25
只看该作者 6楼 发表于: 2011-05-25
本帖最近打赏记录:共1条打赏M币+5
