Starting command:[/root/soft/SF_Genesis -PROCESS_SSD 1:0:0:0 "/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/FW_PPRO_6_0_A_Release.1134440.release.00.mfp" "/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig" 123456 101010 LOG="/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/123456_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 06/18/2018 23:21:25] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 1:0:0:0
argv[3]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/FW_PPRO_6_0_A_Release.1134440.release.00.mfp
argv[4]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig
argv[5]: 123456
argv[6]: 101010
argv[7]: LOG=/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/123456_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Mon 06/18/2018 23:21:25] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Mon 06/18/2018 23:21:30] - Issuing a discovery command for device: '1:0:0:0'
[Mon 06/18/2018 23:21:35] - Discovery command completed...
[Mon 06/18/2018 23:21:35] - Waiting 5 seconds for the system to settle...
[Mon 06/18/2018 23:21:40] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Mon 06/18/2018 23:21:40] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/FW_PPRO_6_0_A_Release.1134440.release.00.mfp
Configuration File = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig
Serial No. = 123456
World Wide Name = 101010
[Mon 06/18/2018 23:21:41] - Successfully received the IDENTIFY data from the drive...
[Mon 06/18/2018 23:21:41] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/FW_PPRO_6_0_A_Release.1134440.release.00.mfp
[Mon 06/18/2018 23:21:41] - Successfully opened the package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/FW_PPRO_6_0_A_Release.1134440.release.00.mfp
[Mon 06/18/2018 23:21:41] - file /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig Loaded successfully
[Mon 06/18/2018 23:21:41] - Warning: Unable to query diagnostics information to perform power management settings check
[Mon 06/18/2018 23:21:41] - B01 Power Management configuration request detected
[Mon 06/18/2018 23:21:41] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig
[Mon 06/18/2018 23:21:41] - Extracted Config_ID: 1 (33058) in DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--00/33058.00.driveconfig
[Mon 06/18/2018 23:21:41] - Extracted SerialOutputControl: 0
[Mon 06/18/2018 23:21:41] - Searching for flashware image for configuration 33058
[Mon 06/18/2018 23:21:41] - Manifest found for configuration 33058
[Mon 06/18/2018 23:21:41] - Flashware image extracted: 33058_fw_cl_mlc_Intel_128Gb_generic_PF29F64B08NCMF3_2Q_2C_1D_PP_R02565_s512.vic
[Mon 06/18/2018 23:21:41] - Searching for manufacturing image for configuration 33058
[Mon 06/18/2018 23:21:41] - Manufacturing image extracted: 33058_mf_mlc_Intel_128Gb_generic_PF29F64B08NCMF3_2Q_2C_1D_PP_R02565_s512.vic
[Mon 06/18/2018 23:21:41] - Proceeding in ROM mode, download feature 3...
[Mon 06/18/2018 23:21:41] - Successfully downloaded MFB to the drive...
[Mon 06/18/2018 23:21:41] - Waiting (5 sec) for the drive to settle...
[Mon 06/18/2018 23:21:46] - Successfully received the IDENTIFY data from the drive...
[Mon 06/18/2018 23:21:46] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Mon 06/18/2018 23:21:46] - Successfully enabled SMART capabilities...
[Mon 06/18/2018 23:21:48] - Successfully issued a diagnostic unlock...
[Mon 06/18/2018 23:21:49] - Performing the flash test of block 0 (0x0000)...
[Mon 06/18/2018 23:21:52] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 2
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 0 | 0 | 1 | 0x0002 | N3 | WARNING |
| 0 | 0 | 0 | 2 | 0x0003 | N1,N3 | WARNING |
| 0 | 0 | 0 | 3 | 0x0003 | N1,N3 | WARNING |
| 0 | 1 | 0 | 0 | 0x0003 | N1,N3 | WARNING |
| 0 | 1 | 0 | 1 | 0x0003 | N1,N3 | WARNING |
| 0 | 1 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 3 | 0x0003 | N1,N3 | WARNING |
| 1 | 0 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 1 | 0x0003 | N1,N3 | WARNING |
| 1 | 0 | 0 | 2 | 0x0003 | N1,N3 | WARNING |
| 1 | 0 | 0 | 3 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 1 | 0x0002 | N3 | WARNING |
| 1 | 1 | 0 | 2 | 0x0023 | N1,N3,N5 | WARNING |
| 1 | 1 | 0 | 3 | 0x0001 | N1 | PASS |
Total Number of test results: 16
Number of failures: 0
Number of Passed with warnings: 10
No. Passed without warnings: 6
[Mon 06/18/2018 23:21:52] - Performing the FORMAT Command with the following parameters:
MemoryWearCycleCapability = 0
CurrentPE_CycleCount = 0
LifeInSeconds = 0
LogicalCapacity = 500118192
SectorSize = 512
SectorAlignmentOffset = 0
ExpectedMemoryID = 33929 (0x8489)
ExpectedNumDies = 0
SerialOutputControl = 0
Time[8] = 0x0000000000000000
MiscFlag_Erase_R_Block = 0
MiscFlag_PanicHandlingEnabled = 0
MiscFlag_PanicOnSATA_Error = 0
MiscFlag_WriteThrottlingTestMode = 0
MiscFlag_DisableUserBandECCX = 1
L_PageSize = 0
E_PageSize = 0
ErrorCorrectionPower = 0
ConfigDeviceReadDisturbCount = 0
ConfigDeviceReadDisturbCountLow = 0
ExtraOptions_0_1 = 0
[Mon 06/18/2018 23:22:16] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Mon 06/18/2018 23:22:16] - End of Genesis manufacturing log.
[Mon 06/18/2018 23:22:16] - Exiting...
[Mon 06/18/2018 23:22:16] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 8
[ 此帖被moshuai2013在2018-06-19 12:10重新编辑 ]
