序号 英文简写 元件英文名 元件中文名
1 Res semi Semiconductor Resistor 半导体电阻
2 Cap semi Semiconductor Capacitor 半导体电容器
3 Cap Var Variable or Adjustable Capacitor 可变或可调电容
4 Cap Pol1 Polarized Capacitor (Radial) 极化电容(径向)
5 Cap Pol2 Polarized Capacitor (Axial) 极化电容(轴向)
6 Cap Capacitor 电容(径向)
7 Cap Pol3 Polarized Capacitor (Surface Mount) 极化电容(表面贴装)
8 Cap Feed Feed-Through Capacitor 馈通电容
9 Cap2 Capacitor 电容
10 Res Varistor Varistor (Voltage-Sensitive Resistor) 压敏电阻(电压敏感电阻)
11 Res Tap Tapped Resistor 抽头电阻
12 Res Thermal Thermal Resistor 热敏电阻
13 Rpot Potentiometer Resistor (侧调或顶调)电位器
14 Rpot SM Square Trimming Potentiometer (顶调)方形电位器
15 Res Bridge Resistor Bridge 电阻桥
16 Bridge1 Full Wave Diode Bridge 整流桥
17 Bridge2 Bridge Rectifier 整流桥集成组件(比1封装较大)
18 Res Adj Variable Resistor 可变电阻
19 Res3 Resistor IPC的高密度贴片电阻
20 D Tunnel2 Tunnel Diode - Dependent Source Model 隧道二极管 - 依赖源模型
21 D Varactor Variable Capacitance Diode 变容二极管
22 D Schottky Schottky Diode 肖特基二极管
23 Diode 1N5402 3 Amp General Purpose Rectifier 3放大器通用整流器
