我的5310XM!
第一次强刷09.42成功!CODE:0565754
第二次想升级下版本!就刷了CODE:0548891
版本是10.10的!刷了以后出现TEST MODE!
然后我就把电池拔了准备重新强刷一边的!结果就全部都是下面的了!
Flashing started
Creating product data items list
Product data items list created
Backup not required
KeepProductInFlashModeAfterFlash is supported only for FPS-X devices. Ignoring the flag
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
--- Press phone's power button! ---
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 296064 bytes
Update server loaded
ERROR:Failed to set phone to flashmode
到了这里就出现红X!然后关闭!
驱动全部正常!电脑都换过了!我的是5310XM!
Flashing started
Backup not required
Flashing phone
Initializing
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
Starting to recover the phone
Recoverying phone
Initializing
ERROR: Unable to detect device 0x8401F145. Check USB connection!
ERROR: Failed to set phone to flashmode
Unable to set the phone to flash mode. Unable to flash.
All operations completed
Product flashing aborted
换了凤凰2010显示是这样的!
用JAY出现这样
JAF version 1.98.62
Detected PKEY: 90009B6C
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.31.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-303\
Searching for default location of ini...
Checking path: \Products\RM-303\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__10.10.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__10.10.ppm_r
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-303\rm303__10.10.image_r_blue
Languages in ppm: English,Chinese Trad ,Chinese Simpl (China)
Detected P-KEY: 90009B6C
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Patching RAW boot step2...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting............................................................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
