Starting Time: 22:39:13
Device 1:0xB3
MP Version:2.159
INI_File_Name:6691_TSB_43nm_D2_CDROM.INI
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-54-0C-00
--> ROOT is not found
Scan (0,4148)
Original Defect Block - 0:0:0x0000
Original Defect Block - 0:0:0x1033
---> Max Bad of Plane (793,792)
---> Max BAD/DIE = 793
Total good blocks after SCAN: 979 / 4148, Bad block=3169
==> 2-Plane mode
Adjust Max LBA = 1806336, 1777600
MaxWindows=2/434, MaxLBA=1777600, Size=867 MB
Max BAD of one plane is 793 (795),4148,1,1
RootSector=0x1D4,Sec/Cluster=32, SuperPage=32 ---> Alignment=12
Boot Block=0x0001,0x0002
Lun0(1651312), Lun1(126288), Public=1651312, Secure=0, CDROM=126288
Special FE Config = 56-0B-00
Defect Table Block=0x0004
--- Download ISP Code:E:\DOWNLOADS\USB\SSS_6691_U3S_MP_V2159\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 1651312,0,126288
SN=00235AF05CA1F1409DF714A7
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
CDROM image:D:\aa.iso
Total=1777600,CDROM=126288, PublicArea=1651184, SecureArea=0
Create SECURE(CDROM=1,Public=806 MB,Secure=0 MB)
--- T2 start ---
FW version is: 0xB3
Vendor ID is:0x0930
Product ID is:0x6544
Vendor=Kingston
Product=DataTraveler G2
Device capacity : 0 > 8888 > 0
--- T2 is done ---
Total Capacity: 1777600 sectors, 867 MBytes
Elasped Time = 00:00:18
Ending Time: 22:39:31
黑片,之前量产过一次,第二次量产的时候,发现了3G左右的bad blocks,结果就郁闷地变成800多M的容量了。。。。各位大大们能否解救一下小弟的U盘,变回原来的容量。。。。
