  • 4174阅读
  • 13回复
[SandForce]SF2281开卡71%处失败,错误代码更新 [复制链接]
离线zhgao
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-09-05
先上log
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 8
[Wed 09/05/2018 15:47:33] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 56984 (0xDE98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 09/05/2018 15:47:43] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C04A:SF_SCT (C04Ah): Bad Block List Full  (MFB format))
[Wed 09/05/2018 15:47:43] - End of Genesis manufacturing log.
[Wed 09/05/2018 15:47:43] - Exiting...
这意思大概就是坏块过多了?开卡的时候应该没有检测所有的坏块吧,这样的话拆下来清空一遍也许可以?
清空以后的错误代码变成下面的:
[Fri 09/07/2018 13:43:14] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C049:SF_SCT (C049h): Bad Block in Epage 0  (MFB format))
是不是还是要把坏块标记出来啊
[ 此帖被zhgao在2018-09-07 13:47重新编辑 ]
离线perter
只看该作者 1楼 发表于: 2018-09-05
离线zhgao
只看该作者 2楼 发表于: 2018-09-05
回 perter 的帖子
离线perter
只看该作者 3楼 发表于: 2018-09-05
回 zhgao 的帖子
只看该作者 4楼 发表于: 2018-09-05
离线zhgao
只看该作者 5楼 发表于: 2018-09-06
回 perter 的帖子
离线aeiou88_2000
只看该作者 6楼 发表于: 2018-09-06
离线zhgao
只看该作者 7楼 发表于: 2018-09-07
回 aeiou88_2000 的帖子
离线ddd111222
只看该作者 8楼 发表于: 2018-09-07
回 zhgao 的帖子
离线zhgao
只看该作者 9楼 发表于: 2018-09-07
回 ddd111222 的帖子
