  • 2705阅读
  • 3回复
[SandForce]求助:SP900 64G 开卡失败 [复制链接]
离线jumankai
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-09-21
固态硬盘是ADATA  ASP900S7-64GM。
前天晚上正常关机,转天再开机,固态就直接识别不出来了,于是想自己试试开卡。
我笔记本是DELL INSPIRON 7520,把固态接在硬盘位,从mSATA 引导的win10 64位,用hyper-v虚拟的Fedora 14 32位的系统,其余按照网上的教程操作。其中编辑Config那步写保护试过有或没有,每次都报错Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)。由于颗粒上看不出是哪家的,所以我把所有SF2241, Package Count =8 , Package Density=64的config ID都试了一遍,都是报这个错。想请问大神们,这个是说明是硬盘本身芯片坏了,不仅仅是掉固件的问题导致的,还是我开卡过程有啥问题导致的?有人知道这个盘的Config ID 应该是啥么?
Overall Summary:
                Start Time: Fri, 09/21/2018 @03:35:27
                  End Time: Fri, 09/21/2018 @03:35:43
            OverallResult: FAIL
                  ExitCode:(0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
         Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 1:0:1:0
                  argv[3]:/media/Linux/1/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]:/media/Linux/1/28041.123456.driveconfig
                  argv[5]: 12345
                  argv[6]: www_123
                  argv[7]: log=/media/Linux/1
                  argv[8]: 123.log
                  Log File:SF_Genesis_Main_Log__Fri_09.21.2018_03.35.27.log
                  Hostname: linux
          Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
       SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
  SF_Core Library Version: v1.7.1.20130612-fc14-32bit
        SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 1823:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
        Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
           NAND Page Size: UNKNOWN
    Number Of Chip Enable: UNKNOWN
          Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
       Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utilityv1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, AllRights Reserved Worldwide.
[Fri 09/21/2018 03:35:27] - SF_Genesis hasbeen invoked with the following parameters:
                      argv[2]: 1:0:1:0
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]:log=/media/Linux/1
                      argv[8]: 123.log
[Fri 09/21/2018 03:35:27] - Instructing theoperating system to purge any existing cached data for device: '1:0:1:0'
[Fri 09/21/2018 03:35:32] - Issuing adiscovery command for device: '1:0:1:0'
[Fri 09/21/2018 03:35:38] - Discoverycommand completed...
[Fri 09/21/2018 03:35:38] - Waiting 5seconds for the system to settle...
[Fri 09/21/2018 03:35:43] - Devicedesignation string '1:0:1:0' is mapped to node '/dev/sg2'
[Fri 09/21/2018 03:35:43] - Proceeding toprocess SSD device with the following parameters:
              DeviceName = /dev/sg2
   MFP Package Filename =/media/Linux/1/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
     Configuration File = /media/Linux/1/28041.123456.driveconfig
              Serial No. = 12345
        World Wide Name = www_123
[Fri 09/21/2018 03:35:43] - Successfullyreceived the IDENTIFY data from the drive...
[Fri 09/21/2018 03:35:43] - ValidatingManufacturing Firmware Package:/media/Linux/1/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 09/21/2018 03:35:43] - Successfullyopened the package:/media/Linux/1/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 09/21/2018 03:35:43] - file  /media/Linux/1/28041.123456.driveconfigLoaded successfully
[Fri 09/21/2018 03:35:43] - Warning:  Unable to query diagnostics information toperform power management settings check
[Fri 09/21/2018 03:35:43] - B01 PowerManagement configuration request detected
[Fri 09/21/2018 03:35:43] - Successfullyextracted *.DriveConfig file: /media/Linux/1/28041.123456.driveconfig
[Fri 09/21/2018 03:35:43] - ExtractedConfig_ID: 1 (28041) in DriveConfig file:/media/Linux/1/28041.123456.driveconfig
[Fri 09/21/2018 03:35:43] - ExtractedSerialOutputControl: 0
[Fri 09/21/2018 03:35:43] - Searching forflashware image for configuration 28041
[Fri 09/21/2018 03:35:43] - Manifest foundfor configuration 28041
[Fri 09/21/2018 03:35:43] - Flashware imageextracted:28041_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Fri 09/21/2018 03:35:43] - Searching formanufacturing image for configuration 28041
[Fri 09/21/2018 03:35:43] - Manufacturingimage extracted:28041_mf_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Fri 09/21/2018 03:35:43] - Proceeding innon-ROM mode, Download feature 3...
[Fri 09/21/2018 03:35:43] - FATAL_ERROR:Could not download MFB to thedrive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
         ATA COMMAND : 0x0092  (146)
         ATA FEATURE : 0x0003  (3)
        Device Status: 0x0001  (1)
        Driver Status: 0x0000  (0)
          Host Status: 0x0008  (8)
Sense Data:
  0-         No Sense: 114 (0x72)    OK
  1-  Recovered Error:  11 (0x0B)   FAIL
  2-        Not Ready:   0 (0x00)   OK
  3-     Medium Error:   0 (0x00)   OK
  4-   Hardware Error:   0 (0x00)   OK
  5-  Illegal Request:   0 (0x00)   OK
  6-   Unit Attention:   0 (0x00)   OK
  7-     Data Protect:  14 (0x0E)   OK
  8-      Blank Check:   9 (0x09)   OK
  9-  Vendor Specific:  12 (0x0C)   OK
10-     Copy Aborted:   0 (0x00)   OK
11-  Aborted Command:   4 (0x04)   FAIL
12 -Equal Comparison:   0 (0x00)    NA
13-  Volume Overflow: 128 (0x80)    NA
14-       Miscompare:   0 (0x00)   OK
15-         Reserved:   0 (0x00)   NA
System Trace:
[   6.646183] dracut: Switching root
[   6.916198] SELinux: initialized (dev usbfs, type usbfs), usesgenfs_contexts
[   7.016154] readahead: starting
[   8.663502] udev[502]: starting version 161
[   9.438688] piix4_smbus 0000:00:07.3: SMBus base address uninitialized -upgrade BIOS or use force_addr=0xaddr
[   9.455735] microcode: CPU0 sig=0x306a9, pf=0x1, revision=0xffffffff
[    9.484135] microcode: Microcode Update Driver:v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[  11.383271] EXT4-fs (dm-0): re-mounted. Opts: (null)
[  11.856497] EXT4-fs (sda1): mounted filesystem with ordered data mode.Opts: (null)
[  11.857849] SELinux: initialized (dev sda1, type ext4), uses xattr
[  12.768983] Adding 2031612k swap on /dev/mapper/vg_linux-lv_swap.  Priority:-1 extents:1 across:2031612k
[  12.773067] SELinux: initialized (dev binfmt_misc, type binfmt_misc),uses genfs_contexts
[  13.264504] NET: Registered protocol family 10
[  13.264725] lo: Disabled Privacy Extensions
[  13.271151] ip6_tables: (C) 2000-2006 Netfilter Core Team
[  14.382744] RPC: Registered udp transport module.
[  14.382746] RPC: Registered tcp transport module.
[  14.382747] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  14.388049] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), usesgenfs_contexts
[  16.484415] mtrr: type mismatch for f8000000,400000 old: write-back new:write-combining
[  25.123528] fuse init (API version 7.14)
[  25.148784] SELinux: initialized (dev fuse, type fuse), usesgenfs_contexts
[  25.164686] SELinux: initialized (dev fusectl, type fusectl), usesgenfs_contexts
[ 111.843996] SELinux: initialized (dev sdb1, type fuseblk), usesgenfs_contexts
[ 321.415136] sd 1:0:1:0: [sdc] Synchronizing SCSI cache
[ 321.428793] sd 1:0:1:0: [sdc] Stopping disk
[ 321.429458] ata2.01: disabled
[ 326.436516] ata2: soft resetting link
[ 326.783395] ata2.00: NODEV after polling detection
[ 326.817522] ata2.01: ATA-8: Virtual HD, 1.1.1, max MWDMA2
[ 326.817524] ata2.01: 64 sectors, multi 128: LBA48
[ 326.854611] ata2.01: configured for MWDMA2
[ 326.854620] ata2: EH complete
[ 326.854846] scsi 1:0:1:0: Direct-Access     ATA     Virtual HD       1.1. PQ: 0 ANSI:5
[ 326.864367] sd 1:0:1:0: Attached scsi generic sg2 type 0
[ 326.867097] sd 1:0:1:0: [sdc] 64 512-byte logical blocks: (32.7 kB/32.0KiB)
[ 326.867099] sd 1:0:1:0: [sdc] 4096-byte physical blocks
[ 326.867126] sd 1:0:1:0: [sdc] Write Protect is off
[ 326.867127] sd 1:0:1:0: [sdc] Mode Sense: 00 3a 00 00
[ 326.867139] sd 1:0:1:0: [sdc] Write cache: enabled, read cache: enabled,doesn't support DPO or FUA
[ 326.867576]  sdc: unknownpartition table
[ 326.879078] sd 1:0:1:0: [sdc] Attached SCSI disk
[Fri 09/21/2018 03:35:43] - End of Genesismanufacturing log.
[Fri 09/21/2018 03:35:43] - Exiting...
   </Log_Body>
   <Overall_Summary>
       <Start_Time> Fri, 09/21/2018 @ 03:35:27 </Start_Time>
       <End_Time> Fri, 09/21/2018 @ 03:35:43 </End_Time>
       <Overall_Result> FAIL </Overall_Result>
        <Exit_Code>(0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
   </Overall_Summary>
   <Environment_Settings>
       <Input_Parameters>
                  argv[2]: 1:0:1:0
                  argv[3]: /media/Linux/1/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[5]: 12345
                  argv[6]: www_123
                  argv[8]: 123.log
       </Input_Parameters>
       <Log_File> SF_Genesis_Main_Log__Fri_09.21.2018_03.35.27.log</Log_File>
       <Hostname> linux </Hostname>
       <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
       <Port_Number> 2 </Port_Number>
       <Device_Name> /dev/sg2 </Device_Name>
       <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit</SF_Genesis_Version>
       <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit</SF_Core_Library_Version>
       <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 1823:56:17 UTC 2010 i686 </SF_OS_Information>
   </Environment_Settings>
   <Post_Processing_Device_Info>
       <WWN_OUI> UNKNOWN </WWN_OUI>
       <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
       <Serial_Number> UNKNOWN </Serial_Number>
       <Model_Number> UNKNOWN </Model_Number>
       <Firmware_Revision> UNKNOWN </Firmware_Revision>
       <ROM_Revision> UNKNOWN </ROM_Revision>
       <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
       <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
       <Logical_Sectors> UNKNOWN </Logical_Sectors>
       <NAND_ID> UNKNOWN </NAND_ID>
       <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
       <Flash_Device> UNKNOWN </Flash_Device>
   </Post_Processing_Device_Info>
</Genesis_Log>
[Fri 09/21/2018 03:35:43] - Overall Result forDevice: /dev/sg2 ****** FAIL ******
离线perter
只看该作者 1楼 发表于: 2018-09-21
离线binghaha
只看该作者 2楼 发表于: 2018-10-02
离线466878778
只看该作者 3楼 发表于: 2018-10-12
