  • 3446阅读
  • 10回复
[SandForce]金士顿300V 固态开卡报错 麻烦帮我看下 [复制链接]
离线466878778
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-10-09
下面是 日志  错误20  同配置文件已经开了4块了  就这块开不过去 是什么情况 。
Starting command:[/SF2000/genesis/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 5:0:0:0 "/SF2000/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig" 8888 8888  LOG="/SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Kingston300V/8888_Sandforce_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 10/10/2018 00:32:44] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 5:0:0:0
                      argv[3]: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig
                      argv[5]: 8888
                      argv[6]: 8888
                      argv[7]: LOG=/SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Kingston300V/8888_Sandforce_DATETIMESTAMP_5.0.0.0_PROCESS_SSD_RESULT.log
[Wed 10/10/2018 00:32:44] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Wed 10/10/2018 00:32:49] - Issuing a discovery command for device: '5:0:0:0'
[Wed 10/10/2018 00:32:54] - Discovery command completed...
[Wed 10/10/2018 00:32:54] - Waiting 5 seconds for the system to settle...
[Wed 10/10/2018 00:32:59] - Device designation string '5:0:0:0' is mapped to node '/dev/sg1'
[Wed 10/10/2018 00:32:59] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig
              Serial No. = 8888
         World Wide Name = 8888
[Wed 10/10/2018 00:32:59] - Successfully received the IDENTIFY data from the drive...
[Wed 10/10/2018 00:32:59] - Validating Manufacturing Firmware Package: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Wed 10/10/2018 00:33:01] - Successfully opened the package: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Wed 10/10/2018 00:33:01] - file  /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig Loaded successfully
[Wed 10/10/2018 00:33:01] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 10/10/2018 00:33:01] - B01 Power Management configuration request detected
[Wed 10/10/2018 00:33:01] - Successfully extracted *.DriveConfig file: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig
[Wed 10/10/2018 00:33:01] - Extracted Config_ID: 1 (27093) in DriveConfig file: /SF2000/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/27093.0.00000000.driveconfig
[Wed 10/10/2018 00:33:01] - Extracted SerialOutputControl: 0
[Wed 10/10/2018 00:33:01] - Searching for flashware image for configuration 27093
[Wed 10/10/2018 00:33:01] - Manifest found for configuration 27093
[Wed 10/10/2018 00:33:01] - Flashware image extracted: 27093_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_2C_1D_S_PP_R01108_s512.vic
[Wed 10/10/2018 00:33:01] - Searching for manufacturing image for configuration 27093
[Wed 10/10/2018 00:33:01] - Manufacturing image extracted: 27093_mf_mlc_MIC_64Gb_MT29F64G08CBABAWPES_2Q_2C_1D_S_PP_R01108_s512.vic
[Wed 10/10/2018 00:33:01] - Proceeding in ROM mode, download feature 3...
[Wed 10/10/2018 00:33:02] - Successfully downloaded MFB to the drive...
[Wed 10/10/2018 00:33:02] - Waiting (5 sec) for the drive to settle...
[Wed 10/10/2018 00:33:07] - Successfully received the IDENTIFY data from the drive...
[Wed 10/10/2018 00:33:07] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Wed 10/10/2018 00:33:07] - Successfully enabled SMART capabilities...
[Wed 10/10/2018 00:33:09] - Successfully issued a diagnostic unlock...
[Wed 10/10/2018 00:33:10] - Performing the flash test of block 0 (0x0000)...
[Wed 10/10/2018 00:33:11] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 3
      No. Passed without warnings: 13
[Wed 10/10/2018 00:33:11] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 25644 (0x642C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 10/10/2018 00:33:30] - FORMAT command completed...
[Wed 10/10/2018 00:33:30] - Waiting (2 sec) for the drive to settle...
[Wed 10/10/2018 00:33:32] - Setting up the stamp information through CDU command...
[Wed 10/10/2018 00:33:35] - Waiting (2 sec) for the drive to settle...
[Wed 10/10/2018 00:33:37] - Downloading the flashware to the drive... feature 3
[Wed 10/10/2018 00:33:37] - FATAL_ERROR: Could not download flashware to the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  248.947947] sd 5:0:0:0: [sdb] 4096-byte physical blocks
[  248.947966] sd 5:0:0:0: [sdb] Write Protect is off
[  248.947967] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  248.947975] sd 5:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  248.948416]  sdb: unknown partition table
[  248.957341] sd 5:0:0:0: [sdb] Attached SCSI disk
[  298.332850] sd 5:0:0:0: [sdb] Stopping disk
[  298.332894] ata6.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  298.332897] ata6.00: irq_stat 0x40000001
[  298.332898] ata6.00: failed command: STANDBY IMMEDIATE
[  298.332901] ata6.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[  298.332901]          res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[  298.332902] ata6.00: status: { DRDY ERR }
[  298.332903] ata6.00: error: { ABRT }
[  298.332907] ata6.00: device reported invalid CHS sector 0
[  298.332922] sd 5:0:0:0: [sdb] START_STOP FAILED
[  298.332923] sd 5:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  298.332925] sd 5:0:0:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
[  298.332927] sd 5:0:0:0: [sdb] Add. Sense: No additional sense information
[  298.332960] ata6.00: disabled
[  303.331508] ata6: hard resetting link
[  303.635596] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  303.636874] ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[  303.636886] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[  303.636894] ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[  303.640076] ata6.00: ATA-8: SandForce{200026BB}, 402ABBR0, max UDMA/133
[  303.640083] ata6.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  303.646155] ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[  303.646163] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[  303.646170] ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[  303.649664] ata6.00: configured for UDMA/133
[  303.649676] ata6: EH complete
[  303.649882] scsi 5:0:0:0: Direct-Access     ATA      SandForce{200026 402A PQ: 0 ANSI: 5
[  303.650248] sd 5:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  303.650255] sd 5:0:0:0: Attached scsi generic sg1 type 0
[  303.650262] sd 5:0:0:0: [sdb] 4096-byte physical blocks
[  303.650337] sd 5:0:0:0: [sdb] Write Protect is off
[  303.650343] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  303.650379] sd 5:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  303.650726]  sdb: unknown partition table
[  303.661881] sd 5:0:0:0: [sdb] Attached SCSI disk
[Wed 10/10/2018 00:33:37] - End of Genesis manufacturing log.
[Wed 10/10/2018 00:33:37] - Exiting...
[Wed 10/10/2018 00:33:37] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 20
离线jxr8619
只看该作者 1楼 发表于: 2018-10-09
离线perter
只看该作者 2楼 发表于: 2018-10-09
离线466878778
只看该作者 3楼 发表于: 2018-10-10
回 perter 的帖子
离线perter
只看该作者 4楼 发表于: 2018-10-10
离线466878778
只看该作者 5楼 发表于: 2018-10-12
回 perter 的帖子
离线466878778
只看该作者 6楼 发表于: 2018-10-14
离线perter
只看该作者 7楼 发表于: 2018-10-14
回 466878778 的帖子
离线perter
只看该作者 8楼 发表于: 2018-10-14
离线466878778
只看该作者 9楼 发表于: 2018-10-16
回 perter 的帖子
