  • 2575阅读
  • 7回复
[鑫创]我的金士顿量产失败!请高手帮忙看看! [复制链接]
离线pxh117
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-04-24
— 本帖被 mydigit 从 量产工具发布 移动到本区(2012-12-16) —
Starting Time: 18:06:16
Device 1:0xB5
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-55-0C-00
    Found BACKUP Table (000000BB-0001)
    Defect Table (00000200-0004)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x0013
        Original Bad Block - 0:0x0033
        Original Bad Block - 0:0x0035
        Original Bad Block - 0:0x003A
        Original Bad Block - 0:0x0052
        Original Bad Block - 0:0x006B
        Original Bad Block - 0:0x007C
        Original Bad Block - 0:0x00B6
        Original Bad Block - 0:0x00C9
        Original Bad Block - 0:0x00DC
        Original Bad Block - 0:0x00E2
        Original Bad Block - 0:0x0132
        Original Bad Block - 0:0x0133
        Original Bad Block - 0:0x0197
        Original Bad Block - 0:0x019A
        Original Bad Block - 0:0x01AA
        Original Bad Block - 0:0x01C2
        Original Bad Block - 0:0x01DA
        Original Bad Block - 0:0x0202
        Original Bad Block - 0:0x020C
        Original Bad Block - 0:0x0216
        Original Bad Block - 0:0x0255
        Original Bad Block - 0:0x025F
        Original Bad Block - 0:0x0272
        Original Bad Block - 0:0x0278
        Original Bad Block - 0:0x0283
        Original Bad Block - 0:0x0286
        Original Bad Block - 0:0x02A0
        Original Bad Block - 0:0x02BE
        Original Bad Block - 0:0x02DA
        Original Bad Block - 0:0x02E6
        Original Bad Block - 0:0x0304
        Original Bad Block - 0:0x0316
        Original Bad Block - 0:0x031C
        Original Bad Block - 0:0x0336
        Original Bad Block - 0:0x039D
        Original Bad Block - 0:0x03AF
        Original Bad Block - 0:0x0418
        Original Bad Block - 0:0x041E
        Original Bad Block - 0:0x047D
        Original Bad Block - 0:0x04A6
        Original Bad Block - 0:0x04BC
        Original Bad Block - 0:0x04C8
        Original Bad Block - 0:0x04FF
        Original Bad Block - 0:0x0502
        Original Bad Block - 0:0x051F
        Original Bad Block - 0:0x053C
        Original Bad Block - 0:0x059F
        Original Bad Block - 0:0x05CA
        Original Bad Block - 0:0x0613
        Original Bad Block - 0:0x0684
        Original Bad Block - 0:0x06C2
        Original Bad Block - 0:0x0758
        Original Bad Block - 0:0x0759
        Original Bad Block - 0:0x076A
        Original Bad Block - 0:0x07BD
        Original Bad Block - 0:0x07CF
        Original Bad Block - 0:0x0832
        Original Bad Block - 0:0x0910
        Original Bad Block - 0:0x0969
        Original Bad Block - 0:0x0981
        Original Bad Block - 0:0x0998
        Original Bad Block - 0:0x09B4
        Original Bad Block - 0:0x09B6
        Original Bad Block - 0:0x09DD
        Original Bad Block - 0:0x09DF
        Original Bad Block - 0:0x09FB
        Original Bad Block - 0:0x0A07
        Original Bad Block - 0:0x0A2A
        Original Bad Block - 0:0x0A30
        Original Bad Block - 0:0x0A3F
        Original Bad Block - 0:0x0A48
        Original Bad Block - 0:0x0AAA
        Original Bad Block - 0:0x0AE6
        Original Bad Block - 0:0x0B42
        Original Bad Block - 0:0x0B67
        Original Bad Block - 0:0x0B7B
        Original Bad Block - 0:0x0B82
        Original Bad Block - 0:0x0C23
        Original Bad Block - 0:0x0C3C
        Original Bad Block - 0:0x0C48
        Original Bad Block - 0:0x0C53
        Original Bad Block - 0:0x0C69
        Original Bad Block - 0:0x0CBB
        Original Bad Block - 0:0x0CD9
        Original Bad Block - 0:0x0CE3
        Original Bad Block - 0:0x0CF8
        Original Bad Block - 0:0x0D16
        Original Bad Block - 0:0x0D24
        Original Bad Block - 0:0x0D3F
        Original Bad Block - 0:0x0D63
        Original Bad Block - 0:0x0DAB
        Original Bad Block - 0:0x0DB3
        Original Bad Block - 0:0x0DC1
        Original Bad Block - 0:0x0E09
        Original Bad Block - 0:0x0E0B
        Original Bad Block - 0:0x0E11
        Original Bad Block - 0:0x0E4E
        Original Bad Block - 0:0x0E5F
        Original Bad Block - 0:0x0E99
        Original Bad Block - 0:0x0ECF
        Original Bad Block - 0:0x0ED9
        Original Bad Block - 0:0x0EFD
        Original Bad Block - 0:0x0F07
        Original Bad Block - 0:0x0F50
        Original Bad Block - 0:0x0FA1
        Original Bad Block - 0:0x0FD1
        Original Bad Block - 0:0x0FE3
    Defect Table shows 3991 Good blocks, 109 Bad blocks
    SafeErase (0,4100)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x0013
        Erase failed Block - 0:0:0x0033
        Erase failed Block - 0:0:0x0035
        Erase failed Block - 0:0:0x003A
        Erase failed Block - 0:0:0x0052
        Erase failed Block - 0:0:0x006B
        Erase failed Block - 0:0:0x007C
        Erase failed Block - 0:0:0x00B6
        Erase failed Block - 0:0:0x00C9
        Erase failed Block - 0:0:0x00DC
        Erase failed Block - 0:0:0x00E2
        Erase failed Block - 0:0:0x0132
        Erase failed Block - 0:0:0x0133
        Erase failed Block - 0:0:0x0197
        Erase failed Block - 0:0:0x019A
        Erase failed Block - 0:0:0x01AA
        Erase failed Block - 0:0:0x01C2
        Erase failed Block - 0:0:0x01DA
        Erase failed Block - 0:0:0x0202
        Erase failed Block - 0:0:0x020C
        Erase failed Block - 0:0:0x0216
        Erase failed Block - 0:0:0x0255
        Erase failed Block - 0:0:0x025F
        Erase failed Block - 0:0:0x0272
        Erase failed Block - 0:0:0x0278
        Erase failed Block - 0:0:0x0283
        Erase failed Block - 0:0:0x0286
        Erase failed Block - 0:0:0x02A0
        Erase failed Block - 0:0:0x02BE
        Erase failed Block - 0:0:0x02DA
        Erase failed Block - 0:0:0x02E6
        Erase failed Block - 0:0:0x0304
        Erase failed Block - 0:0:0x0316
        Erase failed Block - 0:0:0x031C
        Erase failed Block - 0:0:0x0336
        Erase failed Block - 0:0:0x039D
        Erase failed Block - 0:0:0x03AF
        Erase failed Block - 0:0:0x0418
        Erase failed Block - 0:0:0x041E
        Erase failed Block - 0:0:0x047D
        Erase failed Block - 0:0:0x04A6
        Erase failed Block - 0:0:0x04BC
        Erase failed Block - 0:0:0x04C8
        Erase failed Block - 0:0:0x04FF
        Erase failed Block - 0:0:0x0502
        Erase failed Block - 0:0:0x051F
        Erase failed Block - 0:0:0x053C
        Erase failed Block - 0:0:0x059F
        Erase failed Block - 0:0:0x05CA
        Erase failed Block - 0:0:0x0613
        Erase failed Block - 0:0:0x0684
        Erase failed Block - 0:0:0x06C2
        Erase failed Block - 0:0:0x0758
        Erase failed Block - 0:0:0x0759
        Erase failed Block - 0:0:0x076A
        Erase failed Block - 0:0:0x07BD
        Erase failed Block - 0:0:0x07CF
        Erase failed Block - 0:0:0x0832
        Erase failed Block - 0:0:0x0910
        Erase failed Block - 0:0:0x0969
        Erase failed Block - 0:0:0x0981
        Erase failed Block - 0:0:0x0998
        Erase failed Block - 0:0:0x09B4
        Erase failed Block - 0:0:0x09B6
        Erase failed Block - 0:0:0x09DD
        Erase failed Block - 0:0:0x09DF
        Erase failed Block - 0:0:0x09FB
        Erase failed Block - 0:0:0x0A07
        Erase failed Block - 0:0:0x0A2A
        Erase failed Block - 0:0:0x0A30
        Erase failed Block - 0:0:0x0A3F
        Erase failed Block - 0:0:0x0A48
        Erase failed Block - 0:0:0x0AAA
        Erase failed Block - 0:0:0x0AE6
        Erase failed Block - 0:0:0x0B42
        Erase failed Block - 0:0:0x0B67
        Erase failed Block - 0:0:0x0B7B
        Erase failed Block - 0:0:0x0B82
        Erase failed Block - 0:0:0x0C23
        Erase failed Block - 0:0:0x0C3C
        Erase failed Block - 0:0:0x0C48
        Erase failed Block - 0:0:0x0C53
        Erase failed Block - 0:0:0x0C69
        Erase failed Block - 0:0:0x0CBB
        Erase failed Block - 0:0:0x0CD9
        Erase failed Block - 0:0:0x0CE3
        Erase failed Block - 0:0:0x0CF8
        Erase failed Block - 0:0:0x0D16
        Erase failed Block - 0:0:0x0D24
        Erase failed Block - 0:0:0x0D3F
        Erase failed Block - 0:0:0x0D63
        Erase failed Block - 0:0:0x0DAB
        Erase failed Block - 0:0:0x0DB3
        Erase failed Block - 0:0:0x0DC1
        Erase failed Block - 0:0:0x0E09
        Erase failed Block - 0:0:0x0E0B
        Erase failed Block - 0:0:0x0E11
        Erase failed Block - 0:0:0x0E4E
        Erase failed Block - 0:0:0x0E5F
        Erase failed Block - 0:0:0x0E99
        Erase failed Block - 0:0:0x0ECF
        Erase failed Block - 0:0:0x0ED9
        Erase failed Block - 0:0:0x0EFD
        Erase failed Block - 0:0:0x0F07
        Erase failed Block - 0:0:0x0F50
        Erase failed Block - 0:0:0x0FA1
        Erase failed Block - 0:0:0x0FD1
        Erase failed Block - 0:0:0x0FE3
        ---> Max Bad of Plane (29,26)
        ---> Max BAD/DIE = 29
    Total good blocks after SCAN: 3991 / 4100, Bad block=109
    ==> 2-Plane mode
    Max. Bad Block Allowed = 183(109)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 29 (45),4100,1,1
    RootSector=0xD55,Sec/Cluster=32, SuperPage=32 ---> Alignment=11
    Boot Block=0x0001,0x0002
    Lun0(6797476), Lun1(1025820), Public=6797476, Secure=0, CDROM=1025820
    Special FE Config = 56-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\桌面\SSS6691工具\KINSTON G3\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 6797476,0,1025820
    SN=00E04D4F893FF1418BAF14DF
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    LBATest 10M activate
    ### Err: CDROM file too large(00000000<000fa71c).
Ending Time: 18:06:32
本帖最近打赏记录:共1条打赏
离线pxh117
只看该作者 1楼 发表于: 2011-04-24
离线85617179
只看该作者 2楼 发表于: 2011-04-25
离线nongwei
只看该作者 3楼 发表于: 2011-04-26
离线gamester
只看该作者 4楼 发表于: 2011-04-26
离线qsav
只看该作者 5楼 发表于: 2011-04-27
本帖最近打赏记录:共1条打赏
离线gamester
只看该作者 6楼 发表于: 2011-04-27
本帖最近打赏记录:共1条打赏
离线qsav
只看该作者 7楼 发表于: 2011-04-27
回 6楼(gamester) 的帖子
