  • 1582阅读
  • 8回复
[SandForce]新手开卡失败,召唤大神! [复制链接]
离线c2oud
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-11-05
    新手开卡,点开始就持续了几秒,都没进百分比,不知道什么原因,情大神分析以下。写保护电路和温度传感器都设置了,搞不清原因。
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Mon, 11/05/2018 @ 19:07:26
                  End Time: Mon, 11/05/2018 @ 19:07:45
             OverallResult: FAIL
                  ExitCode: (0x01000002:SF_CONFIG_CONFIG_ID_NOT_FOUND_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 2:0:0:0
                  argv[3]: /root/ssd/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/20024.123456.driveconfig
                  argv[5]: 1234
                  argv[6]: 56
                  argv[7]: LOG=/root/ssd/log/1234_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/ssd/log/1234_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 11/05/2018 19:07:26] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 2:0:0:0
                      argv[5]: 1234
                      argv[6]: 56
[Mon 11/05/2018 19:07:26] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Mon 11/05/2018 19:07:31] - Issuing a discovery command for device: '2:0:0:0'
[Mon 11/05/2018 19:07:36] - Discovery command completed...
[Mon 11/05/2018 19:07:36] - Waiting 5 seconds for the system to settle...
[Mon 11/05/2018 19:07:41] - Device designation string '2:0:0:0' is mapped to node '/dev/sg1'
[Mon 11/05/2018 19:07:41] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/ssd/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/20024.123456.driveconfig
              Serial No. = 1234
         World Wide Name = 56
[Mon 11/05/2018 19:07:41] - Successfully received the IDENTIFY data from the drive...
[Mon 11/05/2018 19:07:41] - Validating Manufacturing Firmware Package: /root/ssd/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 11/05/2018 19:07:44] - Successfully opened the package: /root/ssd/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 11/05/2018 19:07:44] - file  /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/20024.123456.driveconfig Loaded successfully
[Mon 11/05/2018 19:07:45] - B01 Power Management configuration request detected
[Mon 11/05/2018 19:07:45] - B01 Power Management conforms to hardware version 0x200026BB
[Mon 11/05/2018 19:07:45] - Successfully extracted *.DriveConfig file: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/20024.123456.driveconfig
[Mon 11/05/2018 19:07:45] - Extracted Config_ID: 1 (20024) in DriveConfig file: /root/ssd/mpt/FW_SF-2000_MP_3-3-0_Client--123456/20024.123456.driveconfig
[Mon 11/05/2018 19:07:45] - Extracted SerialOutputControl: 0
[Mon 11/05/2018 19:07:45] - FATAL_ERROR: Could not extract configuration record: 20024 from package
[Mon 11/05/2018 19:07:45] - End of Genesis manufacturing log.
[Mon 11/05/2018 19:07:45] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 11/05/2018 @ 19:07:26 </Start_Time>
        <End_Time> Mon, 11/05/2018 @ 19:07:45 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x01000002:SF_CONFIG_CONFIG_ID_NOT_FOUND_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 2:0:0:0
                  argv[5]: 1234
                  argv[6]: 56
        </Input_Parameters>
        <Log_File> /root/ssd/log/1234_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 11/05/2018 19:07:45] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线perter
只看该作者 1楼 发表于: 2018-11-05
离线zanezhang
只看该作者 2楼 发表于: 2018-11-05
离线futurestar
只看该作者 3楼 发表于: 2018-11-05
离线zanezhang
只看该作者 4楼 发表于: 2018-11-05
离线c2oud
只看该作者 5楼 发表于: 2018-11-05
离线c2oud
只看该作者 6楼 发表于: 2018-11-05
离线zanezhang
只看该作者 7楼 发表于: 2018-11-05
离线c2oud
只看该作者 8楼 发表于: 2018-11-05
