  • 1509阅读
  • 3回复
[90年代]LuckyTech P5MVP3 古董电脑主板 显卡 内存条 [复制链接]
离线陶旭明
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-11-17
参考资料:http://www.elhvb.com/mboards/luckytech/p5mvp3.htm
Processor
ZIF Socket 7 for :
Intel Pentium P54C/P55C
AMD K5/K6/K6-2 3D/K6-3 up to 550MHz
Cyrix/IBM 6x86L/M2
Clock ratio 1.5x~5.5x
Speed 50~100MHz
Chipset
VIA MVP3 chipset -100MHz
VIA VP3 chipset - 66MHz
SMC 37M669 I/O chipset controller
System Memory
2 x 168pin DIMM, 2 x 72pin SIMM
8 to 544MB Memory (4 Banks), FPM,EDO RAM & SDRAM
On board L2 512K cache Synchronous RAM
PCI IDE On Board
2 * PCI Bus Master IDE Ports (Up to 4 IDE Devices)
Supports up to Mode 4 Timing for up to 14 Mbytes/s
BIOS
Plug and Play Award BIOS (upgradable)
I/O
1 x AGP slot
3 x 32-bit PCI slot with 4 Masters
3 x 16-bit ISA slot
1 x floppy port, supports 2 x FDD up to 2.88M bytes
2 x Serial ports (16C550 Fast UART Compatible)
1 x Parallel port, supports EPP/ECP modes
2 x USB ports (48MHz)
1 x IrDA
1x PS/2 keyboard port
1x PS/2 mouse port
Additional Features
AT/ATX Dual power for ACPI
Supports Ultra DMA 33/sec
ATX power supply software off
Modem Ring Remote Wake Up
Switching Voltage Regulator
Built in LM75 CPU temperature Auto-Detect (optional)
CPU fan auto-stop in suspend mode
Power Saving ACPI/APM Power Management
Form Factor
AT Form
220mm(L) x220mm(W) * 4 Layer PCB
只看该作者 1楼 发表于: 2018-11-17
离线lingyer1
只看该作者 2楼 发表于: 2018-11-17
离线lws74
只看该作者 3楼 发表于: 2018-11-18
