  • 1239阅读
  • 1回复
[SandForce]这是啥错呢? [复制链接]
离线ctnet
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-12-04
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 12/04/2018 @ 06:14:17
                  End Time: Tue, 12/04/2018 @ 06:14:38
             OverallResult: FAIL
                  ExitCode: (0x00010007:SF_PACKAGE_INVALID_PARM_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 1:0:0:0
                  argv[3]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
                  argv[5]: 12345
                  argv[6]: www_
                  argv[7]: 123
                  argv[8]: log=/home/ctnet/ssd/ssd.log
                  Log File: SF_Genesis_Main_Log__Tue_12.04.2018_06.14.17.log
                  Hostname: 6
           Host IP Address: 0.0.0.6
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.5.21.20110919-fc14-32bit
   SF_Core Library Version: v1.7.0.20110919-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Tue 12/04/2018 06:14:17] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 1:0:0:0
                      argv[5]: 12345
                      argv[6]: www_
                      argv[7]: 123
[Tue 12/04/2018 06:14:17] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Tue 12/04/2018 06:14:22] - Issuing a discovery command for device: '1:0:0:0'
[Tue 12/04/2018 06:14:27] - Discovery command completed...
[Tue 12/04/2018 06:14:27] - Waiting 5 seconds for the system to settle...
[Tue 12/04/2018 06:14:32] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Tue 12/04/2018 06:14:32] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
              Serial No. = 12345
         World Wide Name = www_
[Tue 12/04/2018 06:14:32] - Successfully received the IDENTIFY data from the drive...
[Tue 12/04/2018 06:14:38] - Successfully opened the package: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Tue 12/04/2018 06:14:38] - Successfully extracted *.DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
[Tue 12/04/2018 06:14:38] - FATAL_ERROR: Could not lookup the Config_ID: 1 in DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/28064.123456.ct.edriveconfig
[Tue 12/04/2018 06:14:38] - End of Genesis manufacturing log.
[Tue 12/04/2018 06:14:38] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Tue, 12/04/2018 @ 06:14:17 </Start_Time>
        <End_Time> Tue, 12/04/2018 @ 06:14:38 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x00010007:SF_PACKAGE_INVALID_PARM_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 1:0:0:0
                  argv[5]: 12345
                  argv[6]: www_
                  argv[7]: 123
        </Input_Parameters>
        <Log_File> SF_Genesis_Main_Log__Tue_12.04.2018_06.14.17.log </Log_File>
        <Hostname> 6 </Hostname>
        <Host_IP_Address> 0.0.0.6 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.5.21.20110919-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.0.20110919-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Tue 12/04/2018 06:14:38] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线韵风竹
只看该作者 1楼 发表于: 2018-12-04
