  • 1478阅读
  • 1回复
[SandForce]大佬能不能指点下迷津 [复制链接]
离线虐猫子
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-01-10
大佬能不能帮看下错误码 卡低级扫描百分之6
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0062 | N3,N5,N6                                   | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 1    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 2    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 0    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 3    | 0    | 1    | 0x0062 | N3,N5,N6                                   | WARNING |
| 0    | 3    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 3    | 0    | 3    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 0    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 3    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 3    | 0    | 0    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 3    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 3    | 0    | 2    | 0x0062 | N3,N5,N6                                   | WARNING |
| 1    | 3    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 32
      No. Passed without warnings: 0
[Thu 01/10/2019 09:09:50] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 500118192
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Thu 01/10/2019 09:10:59] - FORMAT command completed...
[Thu 01/10/2019 09:10:59] - Waiting (2 sec) for the drive to settle...
[Thu 01/10/2019 09:11:01] - Setting up the stamp information through CDU command...
[Thu 01/10/2019 09:11:04] - Waiting (2 sec) for the drive to settle...
[Thu 01/10/2019 09:11:06] - Downloading the flashware to the drive... feature 3
[Thu 01/10/2019 09:11:06] - FATAL_ERROR: Could not download flashware to the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   4 (0x04)    FAIL
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[   14.166689] SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
[   15.505913] NET: Registered protocol family 10
[   15.506102] lo: Disabled Privacy Extensions
[   15.527749] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   19.262531] r8169 0000:03:00.0: eth0: link up
[   19.262539] r8169 0000:03:00.0: eth0: link up
[   19.548986] RPC: Registered udp transport module.
[   19.548989] RPC: Registered tcp transport module.
[   19.548991] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   19.553967] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
[   23.267122] [drm] nouveau 0000:01:00.0: Allocating FIFO number 2
[   23.273590] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 2
[   29.586010] eth0: no IPv6 routers present
[   50.068862] fuse init (API version 7.14)
[   50.072136] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[   50.101945] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[  178.241611] sd 2:0:1:0: [sdb] Stopping disk
[  178.241743] ata3.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  178.241750] ata3.01: failed command: STANDBY IMMEDIATE
[  178.241760] ata3.01: cmd e0/00:00:00:00:00/00:00:00:00:00/b0 tag 0
[  178.241763]          res 51/04:00:00:00:00/00:00:00:00:00/b0 Emask 0x1 (device error)
[  178.241768] ata3.01: status: { DRDY ERR }
[  178.241772] ata3.01: error: { ABRT }
[  178.241785] ata3.01: device reported invalid CHS sector 0
[  178.249954] sd 2:0:1:0: [sdb] START_STOP FAILED
[  178.249960] sd 2:0:1:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  178.249967] sd 2:0:1:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
[  178.249974] sd 2:0:1:0: [sdb] Add. Sense: No additional sense information
[  178.250183] ata3.01: disabled
[  183.258528] ata3: soft resetting link
[  183.420110] ata3.01: ATA-8: SandForce{200026BB}, 402ABBR0, max UDMA/133
[  183.420117] ata3.01: 64 sectors, multi 16: LBA48 NCQ (depth 0/32)
[  183.423292] ata3.01: configured for UDMA/133
[  183.423304] ata3: EH complete
[  183.423458] scsi 2:0:1:0: Direct-Access     ATA      SandForce{200026 402A PQ: 0 ANSI: 5
[  183.426891] sd 2:0:1:0: Attached scsi generic sg1 type 0
[  183.428689] sd 2:0:1:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  183.428694] sd 2:0:1:0: [sdb] 4096-byte physical blocks
[  183.428794] sd 2:0:1:0: [sdb] Write Protect is off
[  183.428800] sd 2:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[  183.428843] sd 2:0:1:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  183.430158]  sdb: unknown partition table
[  183.435588] sd 2:0:1:0: [sdb] Attached SCSI disk
[Thu 01/10/2019 09:11:06] - End of Genesis manufacturing log.
[Thu 01/10/2019 09:11:06] - Exiting...
[Thu 01/10/2019 09:11:06] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 20
离线zanezhang
只看该作者 1楼 发表于: 2019-01-10
