  • 3997阅读
  • 9回复
[SandForce]SF2582东芝16贴7S2F [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-01-16
Starting command:[/root/soft/SF_Genesis-v1.7.5.00620140820-fc14-32bit/SF_Genesis -PROCESS_SSD 23:0:0:0 "/root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp" "/root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig" 399205758 399205758  LOG="/root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/399205758_Linux_DATETIMESTAMP_23.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.5.00620140820-fc14-32bit
SF_Core Library: v1.7.1.20140820-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 01/16/2019 17:20:58] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 23:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
                      argv[4]: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
                      argv[5]: 399205758
                      argv[6]: 399205758
                      argv[7]: LOG=/root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/399205758_Linux_DATETIMESTAMP_23.0.0.0_PROCESS_SSD_RESULT.log
[Wed 01/16/2019 17:20:58] - Instructing the operating system to purge any existing cached data for device: '23:0:0:0'
[Wed 01/16/2019 17:21:03] - Issuing a discovery command for device: '23:0:0:0'
[Wed 01/16/2019 17:21:08] - Discovery command completed...
[Wed 01/16/2019 17:21:08] - Waiting 5 seconds for the system to settle...
[Wed 01/16/2019 17:21:13] - Device designation string '23:0:0:0' is mapped to node '/dev/sg2'
[Wed 01/16/2019 17:21:13] - Power Management enforcement enabled.
[Wed 01/16/2019 17:21:13] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
              Serial No. = 399205758
         World Wide Name = 399205758
[Wed 01/16/2019 17:21:13] - Successfully received the IDENTIFY data from the drive...
[Wed 01/16/2019 17:21:13] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
[Wed 01/16/2019 17:21:17] - Successfully opened the package: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
[Wed 01/16/2019 17:21:17] - file  /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig Loaded successfully
[Wed 01/16/2019 17:21:23] - B01 Power Management configuration request detected
[Wed 01/16/2019 17:21:23] - B01 Power Management conforms to hardware version 0x0
[Wed 01/16/2019 17:21:23] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
[Wed 01/16/2019 17:21:23] - Extracted Config_ID: 1 (25139) in DriveConfig file: /root/mpt/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
[Wed 01/16/2019 17:21:23] - Extracted SerialOutputControl: 0
[Wed 01/16/2019 17:21:23] - Extracted Enable DLC: 0
[Wed 01/16/2019 17:21:23] - Searching for flashware image for configuration 25139
[Wed 01/16/2019 17:21:23] - Manifest found for configuration 25139
[Wed 01/16/2019 17:21:23] - Flashware image extracted: 25139_fw_cl_slc_Toshiba_16Gb_TH58TAG7S2FBA89_4Q_4C_2D_PP_R00468_s512.vic
[Wed 01/16/2019 17:21:23] - Searching for manufacturing image for configuration 25139
[Wed 01/16/2019 17:21:23] - Manufacturing image extracted: 25139_mf_slc_Toshiba_16Gb_TH58TAG7S2FBA89_4Q_4C_2D_PP_R00468_s512.vic
[Wed 01/16/2019 17:21:23] - Proceeding in ROM mode, download feature 3...
[Wed 01/16/2019 17:21:24] - Successfully downloaded MFB to the drive...
[Wed 01/16/2019 17:21:24] - Waiting (5 sec) for the drive to settle...
[Wed 01/16/2019 17:21:29] - Successfully received the IDENTIFY data from the drive...
[Wed 01/16/2019 17:21:29] - Firmware revision reported to be: '618ABBM0'.  This indicates MFB download was successful.
[Wed 01/16/2019 17:21:29] - Successfully enabled SMART capabilities...
[Wed 01/16/2019 17:21:31] - Successfully issued a diagnostic unlock...
[Wed 01/16/2019 17:21:32] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 390721968
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 55192 (0xD798)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                        Enable DLC = 0
                  ExtraOptions_0_1 = 0
[Wed 01/16/2019 17:21:39] - FORMAT command completed...
[Wed 01/16/2019 17:21:39] - Waiting (2 sec) for the drive to settle...
[Wed 01/16/2019 17:21:41] - Setting up the stamp information through CDU command...
[Wed 01/16/2019 17:22:04] - Failure reading drive configuration data: (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Wed 01/16/2019 17:22:04] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x10090109:SF_GENESIS_CDU_ERROR_BAD_TARGET_ERROR)
[Wed 01/16/2019 17:22:04] - End of Genesis manufacturing log.
[Wed 01/16/2019 17:22:04] - Exiting...
[Wed 01/16/2019 17:22:04] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 9
求大神帮忙解决
固件是25139和25140都不行
离线perter
只看该作者 1楼 发表于: 2019-01-16
只看该作者 2楼 发表于: 2019-01-16
回 perter 的帖子
离线perter
只看该作者 3楼 发表于: 2019-01-16
回 程峰网维科技 的帖子
只看该作者 4楼 发表于: 2019-01-16
离线350950537
只看该作者 5楼 发表于: 2019-01-17
只看该作者 6楼 发表于: 2019-01-20
回 350950537 的帖子
只看该作者 7楼 发表于: 2019-01-20
只看该作者 8楼 发表于: 2019-01-20
回 新奇小子007 的帖子
离线jackylv
只看该作者 9楼 发表于: 2019-03-24
