  • 1774阅读
  • 5回复
[SandForce]SF2281  vb1开卡遇问题 不知道如何解决 [复制链接]
离线shpshpyy
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-01-21
Starting command:[/root/Desktop/sf2281/SF_Genesis-v1.7/SF_Genesis -PROCESS_SSD 16:0:0:0 "/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp" "/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig" 11 11  LOG="/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/11_localhost.localdomain_DATETIMESTAMP_16.0.0.0_PROCESS_SSD_RESULT.log"   19:0:0:0]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 01/21/2019 21:37:22] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 16:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig
                      argv[5]: 11
                      argv[6]: 11
                      argv[7]: LOG=/root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/11_localhost.localdomain_DATETIMESTAMP_16.0.0.0_PROCESS_SSD_RESULT.log
                      argv[8]: 19:0:0:0
[Mon 01/21/2019 21:37:22] - Instructing the operating system to purge any existing cached data for device: '16:0:0:0'
[Mon 01/21/2019 21:37:27] - Issuing a discovery command for device: '16:0:0:0'
[Mon 01/21/2019 21:37:32] - Discovery command completed...
[Mon 01/21/2019 21:37:32] - Waiting 5 seconds for the system to settle...
[Mon 01/21/2019 21:37:37] - Device designation string '16:0:0:0' is mapped to node '/dev/sg2'
[Mon 01/21/2019 21:37:37] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig
              Serial No. = 11
         World Wide Name = 11
[Mon 01/21/2019 21:37:37] - Successfully received the IDENTIFY data from the drive...
[Mon 01/21/2019 21:37:37] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Mon 01/21/2019 21:37:38] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Mon 01/21/2019 21:37:38] - File : /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig in processing ...
[Mon 01/21/2019 21:37:38] - file  /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig Loaded successfully
[Mon 01/21/2019 21:37:46] - B01 Power Management configuration request detected
[Mon 01/21/2019 21:37:46] - B01 Power Management conforms to hardware version 0x0
[Mon 01/21/2019 21:37:46] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig
[Mon 01/21/2019 21:37:46] - Extracted Config_ID: 1 (27063) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27063.12345.test.edriveconfig
[Mon 01/21/2019 21:37:46] - Extracted SerialOutputControl: 0
[Mon 01/21/2019 21:37:46] - Searching for flashware image for configuration 27063
[Mon 01/21/2019 21:37:46] - Manifest found for configuration 27063
[Mon 01/21/2019 21:37:46] - Flashware image extracted: 27063_fw_cl_mlc_Intel_64Gb_Async_JS29F32B08JCMF1_2Q_2C_1D_PP_R01055_s512.vic
[Mon 01/21/2019 21:37:46] - Searching for manufacturing image for configuration 27063
[Mon 01/21/2019 21:37:46] - Manufacturing image extracted: 27063_mf_mlc_Intel_64Gb_Async_JS29F32B08JCMF1_2Q_2C_1D_PP_R01055_s512.vic
[Mon 01/21/2019 21:37:46] - Proceeding in ROM mode, download feature 3...
[Mon 01/21/2019 21:37:46] - Successfully downloaded MFB to the drive...
[Mon 01/21/2019 21:37:46] - Waiting (5 sec) for the drive to settle...
[Mon 01/21/2019 21:37:51] - Successfully received the IDENTIFY data from the drive...
[Mon 01/21/2019 21:37:51] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Mon 01/21/2019 21:37:51] - Successfully enabled SMART capabilities...
[Mon 01/21/2019 21:37:53] - Successfully issued a diagnostic unlock...
[Mon 01/21/2019 21:37:54] - Performing the flash test of block 0 (0x0000)...
[Mon 01/21/2019 21:37:55] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 3
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 0    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 1    | 0    | 2    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 12
            Number of failures: 4
         Number of Passed with warnings: 0
      No. Passed without warnings: 8
[Mon 01/21/2019 21:37:55] - End of Genesis manufacturing log.
[Mon 01/21/2019 21:37:55] - Exiting...
[Mon 01/21/2019 21:37:55] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 7
离线fangyinghh
只看该作者 1楼 发表于: 2019-01-21
离线sonic7216
只看该作者 2楼 发表于: 2019-01-21
离线shpshpyy
只看该作者 3楼 发表于: 2019-01-21
回 fangyinghh 的帖子
离线bobde163
只看该作者 4楼 发表于: 2019-01-22
离线shpshpyy
只看该作者 5楼 发表于: 2019-01-22
回 bobde163 的帖子
