  • 4336阅读
  • 15回复
[SandForce]传家宝企业盘挂了,尝试开卡失败,求解 [复制链接]
离线kenvpn
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-01-29
如题,手里的传家宝 OCZ DENEVA2 240GB突然挂了,死前还有82%的命,死的不明不白。不甘心啊,于是尝试开卡。
查到 开卡数据 25612    SF-2581 240GB Intel25 ccMLC TSOP 16xJS29F16B08CCME2
失败,求解。
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 01/29/2019 06:45:32] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 60:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/FW_PPRO_E_A_I_Release.936211.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/Intel/25612.12345.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/log/
[Tue 01/29/2019 06:45:32] - Instructing the operating system to purge any existing cached data for device: '60:0:0:0'
[Tue 01/29/2019 06:45:37] - Issuing a discovery command for device: '60:0:0:0'
[Tue 01/29/2019 06:45:42] - Discovery command completed...
[Tue 01/29/2019 06:45:42] - Waiting 5 seconds for the system to settle...
[Tue 01/29/2019 06:45:47] - Device designation string '60:0:0:0' is mapped to node '/dev/sg2'
[Tue 01/29/2019 06:45:47] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/FW_PPRO_E_A_I_Release.936211.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/Intel/25612.12345.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Tue 01/29/2019 06:45:47] - Successfully received the IDENTIFY data from the drive...
[Tue 01/29/2019 06:45:47] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/FW_PPRO_E_A_I_Release.936211.release.12345.mfp
[Tue 01/29/2019 06:45:47] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/FW_PPRO_E_A_I_Release.936211.release.12345.mfp
[Tue 01/29/2019 06:45:47] - file  /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/Intel/25612.12345.driveconfig Loaded successfully
[Tue 01/29/2019 06:45:55] - B01 Power Management configuration request detected
[Tue 01/29/2019 06:45:55] - B01 Power Management conforms to hardware version 0x0
[Tue 01/29/2019 06:45:55] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/Intel/25612.12345.driveconfig
[Tue 01/29/2019 06:45:55] - Extracted Config_ID: 1 (25612) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_E_A_I_Release.936211.release--12345/Intel/25612.12345.driveconfig
[Tue 01/29/2019 06:45:55] - Extracted SerialOutputControl: 0
[Tue 01/29/2019 06:45:55] - Searching for flashware image for configuration 25612
[Tue 01/29/2019 06:45:55] - Manifest found for configuration 25612
[Tue 01/29/2019 06:45:55] - Flashware image extracted: 25612_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00864_s512.vic
[Tue 01/29/2019 06:45:55] - Searching for manufacturing image for configuration 25612
[Tue 01/29/2019 06:45:55] - Manufacturing image extracted: 25612_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00864_s512.vic
[Tue 01/29/2019 06:45:55] - Proceeding in ROM mode, download feature 3...
[Tue 01/29/2019 06:45:55] - Successfully downloaded MFB to the drive...
[Tue 01/29/2019 06:45:55] - Waiting (5 sec) for the drive to settle...
[Tue 01/29/2019 06:46:00] - Successfully received the IDENTIFY data from the drive...
[Tue 01/29/2019 06:46:00] - Firmware revision reported to be: 'EAIABBM0'.  This indicates MFB download was successful.
[Tue 01/29/2019 06:46:00] - Successfully enabled SMART capabilities...
[Tue 01/29/2019 06:46:02] - Successfully issued a diagnostic unlock...
[Tue 01/29/2019 06:46:03] - Performing the flash test of block 0 (0x0000)...
[Tue 01/29/2019 06:46:05] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0042 | N3,N6                                      | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0062 | N3,N5,N6                                   | WARNING |
| 1    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 32
      No. Passed without warnings: 0
[Tue 01/29/2019 06:46:05] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 468862128
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Tue 01/29/2019 06:48:02] - FORMAT command completed...
[Tue 01/29/2019 06:48:02] - Waiting (2 sec) for the drive to settle...
[Tue 01/29/2019 06:48:04] - Setting up the stamp information through CDU command...
[Tue 01/29/2019 06:48:04] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x00100001:SF_SATA_DEVICE_NOT_PRESENT_ERROR)
[Tue 01/29/2019 06:48:04] - End of Genesis manufacturing log.
[Tue 01/29/2019 06:48:04] - Exiting...
[Tue 01/29/2019 06:48:04] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[root@localhost   SF_Genesis-v1.7]#
本帖提到的人: @localhost
离线orsonzou
只看该作者 1楼 发表于: 2019-01-29
离线云华科技
只看该作者 2楼 发表于: 2019-01-29
离线skyplayer
只看该作者 3楼 发表于: 2019-01-29
离线perter
只看该作者 4楼 发表于: 2019-01-29
离线kenvpn
只看该作者 5楼 发表于: 2019-01-29
离线kenvpn
只看该作者 6楼 发表于: 2019-01-29
回 skyplayer 的帖子
离线fangyinghh
只看该作者 7楼 发表于: 2019-01-29
离线kenvpn
只看该作者 8楼 发表于: 2019-01-30
回 fangyinghh 的帖子
离线fangyinghh
只看该作者 9楼 发表于: 2019-01-30
